  • juliankoenig87
  • juliankoenig87
10 Nov 2024 13:41
Replied by juliankoenig87 on topic Suggestion for a PCI EPP card for 7i43
All resistors and caps should be fine. There is a short in the 3,3V rail. But since now i cant find it (with ice). Maybe I have to wait for the smoke...
ICs looks fine nevertheless.
  • endian
  • endian's Avatar
10 Nov 2024 13:21
Replied by endian on topic Ethercat, EL6751 and CANOpen
Category: EtherCAT
Cau you share your twincat3 project ... Which stuff you need to run? I can check it and create working configuration of ethercat-conf.xml...
That should be more helpful then writing a tons of posts...
10 Nov 2024 11:40
Replied by tommylight on topic Run LinuxCNC, but terminated with an error
"Could not connect to display 0.0"
That points to a failing graphic card, but can also be caused by failing power supply and memory module/controller.
  • drzasiek90
  • drzasiek90's Avatar
10 Nov 2024 11:36
Linumeric-LPT V3 - Ethernet to LPT controller for LinuxCNC
Category: Driver Boards
If anyone is interested, a new version of the device has been released.
More information is available on my website:
machmaker.pl/linumeric-lpt-v3.2
  • rammfr
  • rammfr
10 Nov 2024 11:34
Replied by rammfr on topic Ethercat, EL6751 and CANOpen
Category: EtherCAT
Unfortunately I get a Config error, when trying to use the startup SDO stuff.
Here the error in Twincat, obviously via ethercat xml I get a similar one (SDO download 0x8000 (58 bytes9 aborted
 'Klemme 4 (EL6731)' (1004) 'PS': CoE ('InitDown' 0x8000:00) - SDO Abort ('Value range of parameter exceeded (only for write access).', 0x06090030): 'EL67xx CoE Init Cmd 3 (8000:00)'.
BR Franz
  • angelnu
  • angelnu
10 Nov 2024 11:19
Replied by angelnu on topic hm2/hm2_7i92.0: Error finishing read!
The parameters are:
angel@orangepi5:~$ halcmd show param *.tmax
Parameters:
Owner Type Dir Value Name
61 s32 RW 292 AND2-Y-eoffset.tmax
61 s32 RW 292 AND2-Y-jog.tmax
61 s32 RW 292 AND2-Z-eoffset.tmax
61 s32 RW 292 AND2-Z-jog.tmax
61 s32 RW 292 AND2-inicio.tmax
61 s32 RW 292 AND2-reanuda.tmax
61 s32 RW 292 AND2-spindle-manual-CCW.tmax
61 s32 RW 292 AND2-spindle-manual-CW.tmax
58 s32 RW 292 AND3-spindle-manual-stop.tmax
58 s32 RW 875 NOR3-alarma-ejes.tmax
67 s32 RW 292 NOT-mode-is-auto.tmax
67 s32 RW 292 X-not.tmax
67 s32 RW 292 Y-not.tmax
67 s32 RW 292 Z-not.tmax
30 s32 RW 11083 base-thread.tmax
55 s32 RW 292 conv_float_s32-feed.tmax
55 s32 RW 584 conv_float_s32-rapid.tmax
76 s32 RW 583 debounce.0.tmax
73 s32 RW 7875 hal_op5_io.read.tmax
73 s32 RW 8166 hal_op5_io.write.tmax
37 s32 RW 0 hm2_7i92.0.read-request.tmax
37 s32 RW 198039 hm2_7i92.0.read.tmax
37 s32 RW 18666 hm2_7i92.0.write.tmax
64 s32 RW 292 ilowpass-encoder-X.tmax
64 s32 RW 292 ilowpass-encoder-select.tmax
70 s32 RW 292 invert.0.tmax
29 s32 RW 1167 motion-command-handler.tmax
29 s32 RW 12833 motion-controller.tmax
52 s32 RW 292 mult2-1-feed.tmax
52 s32 RW 292 mult2-1-jog.tmax
52 s32 RW 583 mult2-1-rapid.tmax
52 s32 RW 292 mult2-2-feed.tmax
52 s32 RW 292 mult2-2-jog.tmax
52 s32 RW 292 mult2-2-rapid.tmax
52 s32 RW 583 mult2-escala.tmax
52 s32 RW 292 mult2-voltaje.tmax
49 s32 RW 584 mux8-escala-mpg.tmax
40 s32 RW 9333 pid.s.do-pid-calcs.tmax
40 s32 RW 9334 pid.x.do-pid-calcs.tmax
40 s32 RW 9625 pid.y.do-pid-calcs.tmax
40 s32 RW 9333 pid.z.do-pid-calcs.tmax
31 s32 RW 235371 servo-thread.tmax
  • GDTH
  • GDTH's Avatar
10 Nov 2024 10:44
Lichuan LC20E Homing, End switches, Probing
Category: EtherCAT
So i am retrofitting my Bridgeport 412 with ethercat 1kw 17bit incremental servo's (LC20E) from lichuan. I have been able to achieve a fully moving machine.I am at the stage where i want to home all axis.  To achieve this i want to use the homing feature in the driver. So i am going to try rodw's homecomp to do this. I was wondering if i press the e-stop during homing does it stop the homing operation on the driver? Asking for safety reasons :)
Also my BP412 has a shared limit switch. I was wondering should i do this through the driver or linuxcnc? The issue i see with the driver is that it doesn't have a function for a shared limit switch. I guess i am kind of answering my own question but i am wondering how everone else is thinking about it.
Also the manual talkes about a probe function. I was wondering if someone could tell me about what the purpose of this is or for what it can used for?
Kind regards,
Andries
  • Edi_48
  • Edi_48
10 Nov 2024 09:51
Dragon settings was created by Edi_48
Dragon settings
Category: Qtvcp
Hallo wie kann ich die Einstellungen in Settings speichern
mfg
Hilton
  • Paul66
  • Paul66
10 Nov 2024 09:23
I got an error message when I ran LinuxCNC two weeks ago."LinuxCNC terminated with an error. When reporting problems, please create a report file and include in your message."Previous Sunday I try LinuxCNC again for my weekend project, ran successfully without any error message.Today Sunday I run LinuxCNC again, but the error message appears again. Thanks for any suggestions.
  • Aciera
  • Aciera's Avatar
10 Nov 2024 06:48
Replied by Aciera on topic Configure the vfdb_vfd driver for direction
Category: Basic Configuration
Sounds like you need to change the 'spindle.0.speed-out..-abs' pin in your hal file to the non absolute variant:
  • darrylb123
  • darrylb123
10 Nov 2024 06:44
I am trying to get the vfdb_vfd MODBUS driver working for reversing (M4) . It is otherwise working. Linuxcnc expects some forward/reverse pins but (looking at the source code) vfdb_vfd expects a negative speed number to send a reverse command to the VFD.
    if (*(haldata->speed_command) >= 0) {
        cmd1_reg |= CMD_FORWARD;
    } else {
        cmd1_reg |= CMD_REVERSE;
My current configuration always send positive numbers and asserts the fwd/rev pins instead.
I can find no reference to configuring linuxcnc to send negative speed numbers to the driver for reverse.
  • juliankoenig87
  • juliankoenig87
10 Nov 2024 06:39 - 10 Nov 2024 06:49
I live in germany. So it was past midnight :-)
Yes. I will try that. Hopefully it is a cap...
Is the voltage of 1,2x V correct?
  • Levi
  • Levi
10 Nov 2024 05:24
Qtvcp GUI and hal pins was created by Levi
Category: Qtvcp
Im not quite understanding how hal pins are associated with a gui button. if i look a qtdragon is there a simple way to look at say the estop and see what pins are directly associated with it? Or in axis there is axisui.jog.increment pin and i can use this to make my mpg work by outputting the scale but i don't see anything like this in qtdragon. Would this pin have to be added in the qtdragon handler file like the other qtdagon specific pins? In 12.5.4 Build A Simple Clean-sheet Custom Screen stops short of giving examples of the pins. The widigits look to hove some pins as part of them, is the manual the only way to see, how does this end come together?
Can anyone give me some direction, Thanks.p { line-height: 115%; margin-bottom: 0.25cm; background: transparent }
  • d3m0n54in7
  • d3m0n54in7
10 Nov 2024 03:24
Replied by d3m0n54in7 on topic Raspberry Pi4B and Mesa7C80 setup for a beginner
Thank you very much for the response. It was indeed the hm2_eth that I needed to change to hm2_rpspi. I also needed to change the CARD0=hm2_7c80 to CARD0=hm2_7c80.0
The next hurdle to surmount is a simple syntax issue. Terminal blocks 1 and 2 are inmux which has gone over my head. After reading the HOSTMOT2 documentation (www.linuxcnc.org/docs/html/man/man9/hostmot2.9.html
inmuxes have names like "hm2_<BoardType>.<BoardNum>.inmux.<Instance>". "Instance" is a two-digit number that corresponds to the HostMot2 inm or inmux instance number. There are "num_inms" or numx_inmuxs" instances, starting with 00. So if I want to use TB1 pin 7 for a "door closed" signal, following the manual, it's INPUT6. Would it be hm2_7c80.0.inmux06 ? What about activating TB2 pin 1 for INPUT COMMON 0?
  • mBender
  • mBender
10 Nov 2024 03:13 - 10 Nov 2024 13:59
And another interesting thing. The Tang is performing way better as my parallel port! I can go high speed with much more microstepping. The motors sound better, but somehow I hit a wall when I wanted to go higher speeds. I am not sure what the reason for this is. If I run with the Tang, I can go up to 2000mm/min (400rpm on my motors) with my Y axis. No matter if I have 10 or 16 microsteps. If I go over the that speed the motor go for like 50mm than they start sounding weird until one of the 2 motors stalls. I first thought that was a mechanical issue and detached the gantry, but still same behavior. I checked with my osciloscope the output of the Tang, the level shifter, the BOB and finally I measured directly at the drives. All seems good. My drives need 2ns low period before the detect the next raising edge. All I measured was within the tolerance of the drives...
I almost gave up since it seems like independent from the microsteps. Then I tried my parallel port set up again and pushed as much as I could. I had to go down to 10 microsteps again and was able to achieve without the stalling around 2700mm/min. Could not go higher due to cycle time limitations, then I got a joint following error in linuxcnc.
I measured again at the drives and saw that the duty cycle high and low of the parallel port signal are almost equal at 50%. The tang produces 80% 20%. I believe this could be a reason why I can't go higher. Is it possible? and if so, change be changed?
In the picture of the parallel port you can see the jitter. Where the Tang performance is much better!
Displaying 18376 - 18390 out of 24129 results.
Time to create page: 1.854 seconds
