  • Muftijaja
  • Muftijaja
05 Nov 2024 11:48 - 05 Nov 2024 11:56
QT Dragon - Funktionstaste mit "Override limits" belegen?
Category: Deutsch
Hallo cmorley, großartig! Danke für dein Script, das werde ich heute installieren. Mal sehen ob ich das schaffe :) Ich gebe noch Feedback. Danke für Deine Mühe!
CU Arno
  • CNC_Tux
  • CNC_Tux
05 Nov 2024 11:48
Replied by CNC_Tux on topic XHC WHB04b-6 - Disconnects / freezes?
Category: Basic Configuration
Hello zmrdko,
have you an example for me, how is to do?
Thank you so much in advance
Best regards
Reinhard
  • daveyr
  • daveyr
05 Nov 2024 10:27
Error getting packages on fresh install on Raspberry Pi 5
Category: QtPyVCP
Good morning.
for some reason it seemed like it would be fun to set up Ethercat and LinuxCNC and ProbeBasic so here we go.  Downloaded the 2.9.3 image from (forum.linuxcnc.org/9-installing-linuxcnc...or-raspberry-pi-4b-5), Then went to follow the standard instructions for installing probe basic from the install site Probe Basic Install.
Followed the instructions for the Arm64 (kcjengr.github.io/probe_basic/stable_quick_start_apt.html) but get the following error message on trying to do the Apt update before installing
N: Skipping acquire of configured file 'main/binary-arm64/Packages' as repository 'repository.qtpyvcp.com/apt stable InRelease' doesn't support architecture 'arm64'
I have checked the kcjengr.list file at /etc/apt/sources.list.d and it lists the arch type as arm64
  • zmrdko
  • zmrdko's Avatar
05 Nov 2024 08:46
Replied by zmrdko on topic XHC WHB04b-6 - Disconnects / freezes?
i have the same MPG and on linuxcnc 2.9.3 and I am experiencing same disconnects.
I support Mecanix opininon - the MPG should be hard wired.
  • stickys
  • stickys
05 Nov 2024 07:56
So its same as the older version board, thank you!
  • CNC_Tux
  • CNC_Tux
05 Nov 2024 07:00
Hello Community,
i ve the same problem with disconnects and freezes of the WHB04-6 and i think its not a matter of the Linuxcnc Version, its a matter of the source code of the WHB04.
I use Linuxcnc 2.8.4 and gmoccapy with a XHC-WHB04-6 and its working in manual mode very well, but if i move the Jogwhheel in the Mode MDI or in Auto will switch the WHB04 to manual mode.
The problem start if i use the mode Auto and a program is running and i move in this time the Jogwheel ... then i get a fault message " its impossible to switch from Auto to manual mode in a running program" after will freeze the WHB04 in.
I search in the HAL for a solution, but the switch function is programed ( so i suppose ) in the source code.
I think the fault chain start earlier, with the functions "mpg" , "con" and "stp"
With the function "mpg" (directly after start of gmoccapy) is working the Jogwheel at the feeding rate ..... after press on the Button "con" or "stp" is impossible to switch back to "mpg".
Have anybody a solution for this kind of problem?
Best regards
Reinhard
  • Aciera
  • Aciera's Avatar
05 Nov 2024 06:49
Replied by Aciera on topic To forum member Aciera
Aciera would you like to be a moderator?
Sure.
Thanks for the offer.
  • Micro2000
  • Micro2000
05 Nov 2024 06:23
LinuxCNC Error was created by Micro2000
LinuxCNC Error
I have 2.9.3 with the 5.4.258 RTAI kernal and am getting an error when starting my mill program.
     insmod: ERROR: could not load module /usr/realtime-5.4.258-rtai-amd64/modules/rtai_hal.ko: no such file or directory
  • Creative25
  • Creative25
05 Nov 2024 06:11
Controlling a compressor with Linuxcnc. was created by Creative25
Category: Plasmac
I have a serious problem with our power company.
The 60 amps connection to our house is not what they say. I have serious voltage drops between utilities transformer and our house and they will not fix it. Looks like common practice in our area.
I can reliably cut at 35 amps.
if I go higher depending how much power my neighbors are using The plasma cutter gets an undervoltage and cuts out.
So the table happily cuts until the compressor starts.
Then the plasma cuts out because it gets an undervoltage.  Qtplasmac pauses and gives an arc lost warning.
If the torch is off during the probing and the compressor kicks in the program keeps running until the compressor cuts out because of undervoltage.
So I can not run plasma and compressor at the same time.
So I was wandering If I add a relay an electric unloaded valve and a pressure sensor to the compressor. Would it be possible to control the compressor with Linuxcnc.
I was thinking about the following. When pressure drops to a certain level. Well above what the plasma needs the program pauses. Preferably at the end of a cut.
then the compressor starts. When the tank is full the program resumes.
Is that possible?
  • cmorley
  • cmorley
05 Nov 2024 04:23
Category: Deutsch
Der Anhang sollte umbenannt werden in: qtdragon_handler.py
  • cmorley
  • cmorley
05 Nov 2024 04:21
Category: Deutsch
Hallo Arno!
(Google translated)
Hier ist eine angepasste Handlerdatei, mit der Sie mit f5 das Kontrollkästchen „Grenzwerte überschreiben“ aktivieren können.
Siehe hier (2.8.2. Handler-Patching):
linuxcnc.org/docs/devel/html/gui/qtvcp.h...cp:modifying-screens
Anweisungen zum Hinzufügen der Datei zu Ihrem Konfigurationsordner finden Sie hier.
Chris
  • mBender
  • mBender
05 Nov 2024 03:30
Good idea, I tried setting the feedrate low, but no difference.
Then I measured with my oscilloscope. The Tang outputs all work as intended. Direction, Enable and Step. Focusing on Step the signal looked really good no matter what feedrate. However, the issue is the logic converter. I am using the Texas Instruments TX0108E. www.ti.com/lit/ds/symlink/txs0108e.pdf?ts=1730734048833 But the step output signal is only 0-2.5V and not the intended 0-5V. Sometimes the output goes up to 5V, but not very often. The enable and direction pin are a bit more reliable but even they are not always 0 or 5V and are sometimes in between. I thought I made something wrong or the level shifter are damaged, but found this video.
The issues he has are very similar to mine and even all the comments under the video don't give an solution.
Anyone an idea how to get the TX0108E working correctly ??
I ordered last time some of those as well, the order is supposed to be here this week. I have 1x 3.3V to 5V and 2x 3.3V to 12V in the order. I wonder if i can use the 3.3V to 12V with just 5V for the stepper driver www.aliexpress.us/item/3256803586254541.html
  • tcbmetalworks
  • tcbmetalworks
05 Nov 2024 01:55
Replied by tcbmetalworks on topic 10.5 x 25 cnc plasma table retrofit
Hey Tom good day to you, my names Tom as well BTW
(theres never enough Toms on the job! haha)
So THCAD5 would be for a divider board with a 0-5v range and thc10 would be for a divider board with a 0-10v range correct? So I will need to see what the voltage output of the divider board on my hypertherm is if there is one or purchase a divider board and wire it up to the raw arc voltage correct? I apologize for bugging you guys with so many questions but I really don't want to order the wrong components so it is very much appreciated.
05 Nov 2024 00:53
Replied by Cant do this anymore bye all on topic Pi-5, NVMe and Mesa
Pi-5, NVMe and Mesa
Category: Installing LinuxCNC
Please supply more information "does not work" isn't very helpful.
What IP addresses are you using ?
Have you tried to
sudo menu-config
to configure the pi ?
Have you looked at the announcement thread for the RPi 5 image ?
Keep in mind that the image is somewhat different to a standard Raspbian OS iamge, so a lot of the info you'll find for that is not applicable.
Tommy has given good advice, older PCs a so much better and easier than an RPi to setup for Linuxcnc.
But to help you we will need more information, what have you tried ? What has happened ? Do you have any error messages.
  • Askjerry
  • Askjerry's Avatar
04 Nov 2024 23:30 - 04 Nov 2024 23:33
Replied by Askjerry on topic ERROR: Button to run a simple routine
Category: pyVCP
ERROR - INSERT COFFEE!!! Thanks Aciera !!
DERP...
What it is SUPPOSED to be... like in My Laguna config...
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
SUBROUTINE_PATH = ./ROUTINES/
FEATURES = 12
What did I have???
[RS274NGC]
Jeeze... ok then... problem resolved!
Thanks for the kick in the head to get me restarted!!!
Displaying 18706 - 18720 out of 24122 results.
Time to create page: 0.418 seconds
