  • lgrfbs
  • lgrfbs's Avatar
03 Nov 2024 18:12
Z axis goes in the wrong direction, so after home-all
Category: StepConf Wizard
I have finally started to work with LinuxCNC
Tried using the Mach import feature in LinuxCNC but it didn't work very well for me, but I was fortunate enough to have both systems' monitors on the same shelf side by side which resulted in a nearly working LinuxCNC system.
The LinuxCNC system is able to run the home-all routine, but I find that the Z axis goes in the wrong direction, so after home-all I need to enter a positive value (G0 Z10) to get the tool to move towards the workpiece.
This is wrong in my mind, as it should be a negative value like: G0 Z10.
I find that the X and Y axes work as I thought, it is only Z I have problems with.
What do you think is the error?
  • anfänger
  • anfänger's Avatar
03 Nov 2024 15:12
Replied by anfänger on topic Ignore hard and or softlimits for toolchange
Many thanks! this sounds way easier than I tought.
  • Aciera
  • Aciera's Avatar
03 Nov 2024 14:02
A 'queuebuster' is a command that tells the interpreter to stop parsing Gcode until actual code execution has caught up (ie the command queue is empty). After such an event the new ini.* values are reloaded and Gcode parsing restarts.
The queue buster (eg reading an analog input) needs to be right after the change
in the ini values (eg done in the 'M123'). I usually put a queue buster in front as well:
   M66  E0 L0                           ; queuebuster
   M123                                    ; switch limits
  • fletch
  • fletch's Avatar
03 Nov 2024 14:00
Replied by fletch on topic Ini File Clarification/Roadmap?
The underlying problem may be that GUIs handle this differently (ie have not been updated to the new [SPINDLE_n] section) but I'm not sure.
Please raise an issue so it does not get lost.
I have raised an issue here: github.com/LinuxCNC/linuxcnc/issues/3171
  • Aciera
  • Aciera's Avatar
03 Nov 2024 13:43
Replied by Aciera on topic Ini File Clarification/Roadmap?
I vaguely remembered there being a discussion about this and I just found it. This may explain some of the issues:
github.com/LinuxCNC/linuxcnc/issues/2335
  • anfänger
  • anfänger's Avatar
03 Nov 2024 13:41
Thanks that already helped a lot.
linking and unlinking Hal I can mange in a bash script.
I would switch reference and limit switch for toolchenge and Bach afterwards.
What I don't understand is the queuebuster command.
What I understand ist the the limits are part of the milltask an I can alter the values with halcmd without altering the infile.
Where and how do I need the queuebuster?
Patrick
  • fletch
  • fletch's Avatar
03 Nov 2024 12:50
Many of the later GUI's introduced a ton of extra ini settings, the authors of those GUI's should update the docs if they moved from display to spindle. I really don't understand why they didn't use the existing ini entries...
JT
There does seem to be a bit of inconsistency, duplication and ambiguity in the ini files used and/or generated by either GUIs or configuration tools - is there available guidance on how to use the in file (or is that something I could try to contribute?).
I am planning to create a separate [MANUALMATIC] section where its ini options take priority over values set elsewhere - perhaps the GUIs should each use their own section and keep [DISPLAY] for purely generic/official display options?
The moving of (say) spindle options to a spindle section makes sense initially but should it also include purely UI options like INCREMENT? I don't really have a view on that, but it depends on what the ini sections are supposed to define. eg. TRAJ has options that apply to both the machine and the UI (eg MAX_LINEAR_VELOCITY) but others that it could be argued only apply to the UI (eg DEFAULT_LINEAR_VELOCITY).
I'm not really qualified to have an opinion on any of the above, hence the question, but would be happy to try to document the views of those who are qualified!
  • Aciera
  • Aciera's Avatar
03 Nov 2024 12:42 - 03 Nov 2024 12:43
Softlimit values are accessible in the ini.* hal pins after startup has completed.
If changed during gcode execution (eg by using a custom mcode) they need a queuebuster command to be updated internally.
Limit switches can be disconnected/reconnected in hal.
  • Aciera
  • Aciera's Avatar
03 Nov 2024 12:30
Replied by Aciera on topic Homing lichuan
Homing lichuan
Category: EtherCAT
1. Open the 'show halconfiguration' tool and check if the 'cia402_homecomp' component and its pins have been created.
2. Start linuxcnc from a terminal, select your config and check for errors:
linuxcnc
  • JT
  • JT's Avatar
03 Nov 2024 12:26
Replied by JT on topic Flex GUI Tutorials
Flex GUI Tutorials
Category: Other User Interfaces
Tutorial 15
JT
  • fletch
  • fletch's Avatar
03 Nov 2024 12:26 - 03 Nov 2024 12:28
Would this be better in the "LinuxCNC documents" section?
This is a very sensible suggestion - not sure why I didn't but probably because my question evolved as I wrote it!
  • JT
  • JT's Avatar
03 Nov 2024 11:42
Replied by JT on topic Ini File Clarification/Roadmap?
JT
  • Creative25
  • Creative25
03 Nov 2024 11:34
Replied by Creative25 on topic Building a chain driven Plasma table.
What resistor value would you use between positive of the isolated power supply and the positive input of the THCAD ?
03 Nov 2024 11:31
Replied by tommylight on topic 10.5 x 25 cnc plasma table retrofit
Get the Mesa 7i85, without the S.
And THCAD5 or 10 and 2 of 1MOhm/2W resistors, it is most probably a HF/HV pilot start plasma, and 300 is not recomended for those, although i am sure it works, i have several of those in daily use.
For power supplies, 5V and 24V, both at 5A should do just fine, MeanWell or Delta preferably.
  • martin2day
  • martin2day
03 Nov 2024 11:21
Knuth Mark Super CNC Retrofit - need some help with my first LinuxCNC
Category: Milling Machines
Hello,
okay thank you. :-)
One other question about the G-Code. Where can I read about the supported G-Code for Linux CNC and what kind of postprozessor I have to use or setup.
I need some bore cycles and helix in all 3 axis...
Have a nice day
Martin
Displaying 18781 - 18795 out of 24118 results.
Time to create page: 0.632 seconds
