  • endian
  • endian's Avatar
11 Oct 2024 20:29
Replied by endian on topic Ethercat, EL6751 and CANOpen
Category: EtherCAT
check this Thread .. I am currently using a canopen master el6751 as a gateway for my spindle vfd ..
It is great way to setup them over twincat3 .. write config pdos to el6751 pdo setup and after get it to free run... Set free run period to the 1ms cycle time which is same as lcec .. default is 4ms and components in the thread has 4ms delay temp...
When everything is green in twincat 3 a running disconnect it from the twincat3 master rj45 socked a connect it to the lcec pc master rj45 socket where is ethercat service running
When is everything ccorrect after command
ethercat pdos -v
u should see working pdo config for the el6751 master ... Copy paste them
This is a PDOs side of setup...
U will need a SDOs setup of PDOs which is psossible to export from twincat to .csv file ale after copy paste to your .xml file before the SMs
Take inspiration from my thread before and create your own .xml file ..
From experiences from servostars .. you will need custom component to run them, because of incremental commands and homing subroutines are pain... But over ethercat I did ds402.comp similar to cia402.comp from dominik where are all stuff working ... But only for S3xx/S7xx with fw 5.18 and higher ... Because of flexible mapping object limitations
  • matasbuk
  • matasbuk
11 Oct 2024 19:39
Tool marker disappears when using negative diameter.
Category: AXIS
Ok, I tried it out. It works, but then using very small offsets like 0.25mm it is still hard to see compared to the original marker.
  • matasbuk
  • matasbuk
11 Oct 2024 19:38
Adding a DRO and want to integrate with linuxcnc, recommended hardware?
Category: CNC Machines
Mesa 7i95T should do the job. As for the encoders, you need regular TTL linear glass scales. No need to shell out money for Heidenhain stuff. Chinese ones will work just fine for this application.
11 Oct 2024 19:13
Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
Category: Installing LinuxCNC
No, it should do the rotation of both the screen and touch.
At least that is what it says, i have not used it, i did it the old way and it is long and painful, so if this works, do report back, please.
11 Oct 2024 19:08
7i96S ?
When you add the 50 pin cable for the above, it gets right up to 7i96S and this is neater.
  • PCW
  • PCW's Avatar
11 Oct 2024 18:10
Replied by PCW on topic Eingänge anschließen 7i96s
Category: Deutsch
The input common on a 7I96 or 7I96S is TB3 pin 12
  • ihavenofish
  • ihavenofish
11 Oct 2024 18:06
Replied by ihavenofish on topic linuxcnc trajectory planner
Yay!
Take you time...
... Is it done yet?
  • Aciera
  • Aciera's Avatar
11 Oct 2024 18:00 - 11 Oct 2024 18:12
Replied by Aciera on topic Python stat toolinfo
Looking at the python module documentation in the 2.9 source:
github.com/LinuxCNC/linuxcnc/blob/2.9/do...ython-interface.adoc
it seems that these sites are showing the documentation for master instead of 2.9:
linuxcnc.org/docs/stable/html/config/python-interface.html
linuxcnc.org/docs/2.9/html/config/python-interface.html
[edit]
I'll file this as an issue on github
github.com/LinuxCNC/linuxcnc/issues/3149
  • jacgri24
  • jacgri24
11 Oct 2024 17:56
Eingänge anschließen 7i96s was created by jacgri24
Category: Deutsch
Guten Tag,
ich habe ein 7i96 Board und möchte eingänge anschließen. Bislang habe ich einen ESTLCAM Klemmenadapter genutzt. Dieser hatte pro Eingang zwei Klemmbuchsen für Hin und Rückleiter. Bei der 7i96s ist pro Eingang nur eine Klemmbuchse vorhanden. Nun frage ich mich ob ich einen gemeinsamen Rückleiter für alle Eingänge anlegen muss und wenn das so ist, wo ich diesen schließen soll.
Ich würde mich freuen, wenn mir jemand helfen kann.
Danke im Vorraus
  • PCW
  • PCW's Avatar
11 Oct 2024 17:45
Replied by PCW on topic Mesa 7i96s --USB error finishing read
Category: Driver Boards
Do you get the errors if the VFD is not powered?
  • nartburg
  • nartburg
11 Oct 2024 17:41
Replied by nartburg on topic Mesa 7i96s --USB error finishing read
checked cables:
vfd grounded;
motor wires shielded and grounded on both sides;
cables not running parallel to each other;
all that shenegans
moved the rs485 to usb adapter from inside the cabinet to the laptop side --
better --at least the messages of finding a new usb device have disapeared -- but still mesa7i96s.0:error finishing read!
This getting better seems to confirm that it is a EMV problem
next step would be to find an optical isolated adapter any other ideas?
  • JT
  • JT's Avatar
11 Oct 2024 17:30
Replied by JT on topic Python stat toolinfo
Looks like it is only in master so having it in the 2.9 docs is an error.
JT
  • JT
  • JT's Avatar
11 Oct 2024 17:21
Python stat toolinfo was created by JT
Following the directions in the docs for toolinfotoolinfo(toolno)(returns dict of tooldata for toolno) - An initial stat.poll() is required to initialize. toolno must be greater than zero and less than or equal to the highest tool number in use. Dictionary items include all tooldata items: toolno, pocketno, diameter,frontangle,backangle,orientation, xoffset,yoffset, … woffset, comment#!/usr/bin/env python3
# -*- coding: utf-8 -*-
import linuxcnc
s = linuxcnc.stat()
s.poll()
toolno = 1
print(s.toolinfo(toolno))
>>> s.poll()
>>> toolno = 1
  File "<stdin>", line 1, in <module>
AttributeError: 'linuxcnc.stat' object has no attribute 'toolinfo'
I'm running 2.9.2-64-abunchofletters
Anyone know when this was added?
JT
  • xenon-alien
  • xenon-alien's Avatar
11 Oct 2024 17:15
Can you tell me how can I rotate the touch part of the screen too?
Try this, otherwise it is a mess to sift through endless posts on several forums to get the right answer, been there and done that, twice.
gist.github.com/mildmojo/48e9025070a2ba40795c
Do I have to return it in landscape mode before rotating it with this script?
  • Todd Zuercher
  • Todd Zuercher's Avatar
11 Oct 2024 16:24
Replied by Todd Zuercher on topic spindle won't reverse
If the Probotix box has just a household outlet to plug in the "spindle or router" it would almost certainly be just an ordinary consumer home router motor.
Displaying 20326 - 20340 out of 24277 results.
Time to create page: 0.783 seconds
