  • andreabonuc
  • andreabonuc
27 Sep 2024 14:23 - 27 Sep 2024 14:35
Replied by andreabonuc on topic Constant loss of position
same problem.. It didn't change anything
If I go F1000 or F10000 the error are the same...
  • Todd Zuercher
  • Todd Zuercher's Avatar
27 Sep 2024 14:19
Replied by Todd Zuercher on topic Make arc in W axis
Make arc in W axis
The problem isn't so much with Linuxcnc, it is more an inherent limitation of G-code itself.
To do what I think your asking for, you would almost have to have two separate G-code interpreters executing two separate, yet some how synchronized g-code files. I think there are some high end control systems that can do such things, but it is currently beyond the scope of Linuxcnc.
That said, I think I can imagine two separate Linuxcnc control computers on one machine linked with some of digital io bits to synchronize a set of parallel processed files. It could work, but would require some experimentation, and there may be unforeseen pitfalls.
  • Todd Zuercher
27 Sep 2024 14:07
Email Notification? was created by Todd Zuercher
Email Notification?
Category: Forum Questions
I would like to change the email address.  I changed it in the profile settings.  However I don't think notifications from topics I've subscribed to are being sent to my new address.  Is there something else that I must do?
  • PCW
  • PCW's Avatar
27 Sep 2024 14:06
Replied by PCW on topic Error while Running Linuxcnc
Category: Driver Boards
Does LinuxCNC run without error? maybe installing the driver is sufficient.
  • PCW
  • PCW's Avatar
27 Sep 2024 14:04
Replied by PCW on topic Constant loss of position
Yes, set those both to 20000 (for all joints)
  • rajsekhar
  • rajsekhar
27 Sep 2024 14:00
Replied by rajsekhar on topic Error while Running Linuxcnc
Realtek driver R8168 installed. It certainly improved tmax parameter (hm2 read tmax was 3330000, now 1300000).
But IRQ could not be set to CPU1 automatically. PCW script sets it manually, but mozmck script did not work, at least till now.
  • B.Reilly01
  • B.Reilly01
27 Sep 2024 13:56
Replied by B.Reilly01 on topic Vertical Screen with ProbeBasic?
Category: QtPyVCP
Yeah, I'd like to share and potentially contribute. I'll admit I kinda hacked together the conversational portion. What do you need from me to check it out?
  • andreabonuc
  • andreabonuc
27 Sep 2024 12:04
DIRSETUP = 6000
DIRHOLD = 4000
 This?
  • Lcvette
  • Lcvette's Avatar
27 Sep 2024 11:58
Replied by Lcvette on topic Probe cancellation does not move the axes.
Category: QtPyVCP
That would be a great addition to Probe Basic.
I'm not sure it can be done - but I'm no expert.
My initial thought is that the on_abort subroutine is run while LCNC is in auto mode... so there's no way for a program to switch to manual (or MDI) mode.
I'll dig around a little and open a new thread - the issue (or solution) may not be specific to PB.
Thanks Spumco,  I briefly looked and saw there is a python module to for the status but i don't see a method of issueing a mode change from within a subroutine, at least not at first glance, if there is a method im not sure how it would handle changing the state from within an auto mnode program to manual mode and close the running subroutine which would need to be done in auto mode.. chicken/egg scenario maybe?
task_mode
(returns integer) - current task mode. one of MODE_MDI, MODE_AUTO, MODE_MANUAL.
i used this for some of the display button states in probe basdic but not sure how much help they would be.  may need a module added or perhaps there is a feature function somewhere else im not aware of.  I also have previously considered having some way to abort to manual mode, but then i think well thats a safety thing too so you don't inadvertently move the machine when it is in a precarious spot, such as the probe down in a hole where it errors from max distance non probe trigger,   so.. while a minor inconvenience, maybe saves a major cost or crash?
  • rajsekhar
  • rajsekhar
27 Sep 2024 11:40
Replied by rajsekhar on topic Latency, error finishing read, and IRQ affinity
I downloaded lcnc_irqpolicy.sh.txt.
My NIC is "enp4s0" and Mesa ip=10.10.10.10.
I made the modification in the above file and modified file attached. Please check whether any further correction required or it is ok.
NIC=`awk 'BEGIN{nic="enp4s0 "} {if ($1=="iface") {tmpnic = $2} if ($1=="address") {if ($2 == 10.10.10.10 ) {nic = tmpnic}}} END{print(nic)}' /etc/network/interfaces`
  • Lcvette
  • Lcvette's Avatar
27 Sep 2024 11:35
Category: QtPyVCP
you are not in full screen mode, hit F11 to allow the display to correctly fit the screen.
  • MarkoPolo
  • MarkoPolo
27 Sep 2024 07:08
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
Yes, it's ok now, thanks..
  • PhilipME
  • PhilipME's Avatar
27 Sep 2024 05:37
interresting surge protection view was created by PhilipME
below text copied from
www.plctalk.net/threads/surge-protection...ng%20are%20at%20risk.
First, eliminate the idea that any protector does protection. Did you really think a protector would somehow block or absorb a destructive surges? Anything that might do that must already be inside electronics.
Second, a destructive surge does damage if that PLC is the best connection to earth. If a surge can blow through a PLC, then it easily blows through 'blocking' or 'energy absorbing' protectors. But if connected low impedance to single point ground, then nobody even knows a surge existed. That energy dissipates harmlessly in earth.
In most facilities, single point ground means wires inside every incoming cable connect low impedance (ie 'less than 10 foot') to the single point ground. All wires enter at the common (service entrance) location. All connect low impedance to one ground. Make that connection either directly or via a protector.
  • Creative25
  • Creative25
27 Sep 2024 05:35
Replied by Creative25 on topic Building a chain driven Plasma table.
Thanks for the info.
Mine is an Intel MacBook 2012
Could you point me to some info on how to disable IRQ?
  • cmorley
  • cmorley
27 Sep 2024 05:02
Replied by cmorley on topic Error in tool_offsetview.py
Category: Qtvcp
Ok. try again :) should work now.
Displaying 20881 - 20895 out of 24484 results.
Time to create page: 0.411 seconds
