  • MennilTossFlykune
  • MennilTossFlykune
02 Sep 2024 07:09
Replied by MennilTossFlykune on topic Modbus VFD startup delay?
Category: Basic Configuration
what about the gs2_vfd enable pin?
  • Aciera
  • Aciera's Avatar
02 Sep 2024 06:53
Replied by Aciera on topic Modbus VFD startup delay?
So, once the startup procedure has successfully completed, does your component reconnect automatically after a powerloss in the VFD? If so then my comment above would not be accurate and the startup delay was really all that is needed.
  • Aciera
  • Aciera's Avatar
02 Sep 2024 06:47
Replied by Aciera on topic QT Dragon Go Home
QT Dragon Go Home
Category: Deutsch
The error translates to:
'Linear motion in line 0 would exceed negative limit for axis z'
'Linear motion in line 0 would exceed negative limit for joint 2'
02 Sep 2024 05:55
Replied by Cant do this anymore bye all on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
I have an old cnc4pc board with the RJ45 connectors, in all honesty I found them a bit of a PITA. The plugin screw terminals are great. Tho the ones that Mesa uses are really expensive, but unlike the more common ones, which you cant put side by side and have the plug part "straddle" the socket part or use 4x2 way plugs in a 8 socket, the Mesa ones can.
I'm really sold on bootlace ferrules & screw terminals.
I had a think my self about a modular design for my hardware, even had a run of boards made, but then thought going with a Parallel Port compatible setup would make a change over from a Parallel Port s\w stepgen system easier. Tho I'm still running with an EPP interface.
02 Sep 2024 05:44
Replied by Cant do this anymore bye all on topic Pendant with 7i73: question with analog inputs
Category: Driver Boards
Not being entirely familiar with the chip used it's hard to say. It cold be a case of having to give up one feature for an other, can't really say.
  • Ho Er
  • Ho Er
02 Sep 2024 05:35
Exactly - the sserial is working correctly, but I can only access analog I0-I3.
As the card was advertised as having 8 inputs, I wonder how they can be acessed - or are the specs on the Mesa webpage simply wrong?
Thanks for the A/D hint - this should work as a workaround, but making the existing hardware work should only be a software thing...?
  • meister
  • meister
02 Sep 2024 05:21 - 02 Sep 2024 05:21
It all makes a very solid impression on me.
I also find optos on the step/dir outputs excessive, I don't know of any drivers without built-in optos.
The advantage of your board is also the modular design,
so you can easily replace a part if it doesn't suit someone.
I find the 12bit per module more than sufficient, I had already experimented with modular boards and 8bit + enable were actually sufficient for me. The whole thing was actually mostly limited by the number of connectors I could place per module.
02 Sep 2024 05:13
Yeah that's not the issue. From his screen shot of hal show the OP has everything setup correctly. Communication appears to be good.
The issue is that the OP wants to use more than 4 analogue inputs, but the 7i73 is only reporting 4. The question is how to access the other analogue inputs.
Unfortunately reading the 7i73 manual, it appears only the first four of eight are available.
Would it be possible to ditch the analogue joystick, thereby freeing up the 4 inputs and using pots to set up the jog speed ? Not quite as convenient.
Another option could be an SPI A to D and bit bang the data through.
This is an example using the parallel port, but should be adaptable.
www.wallacecompany.com/machine_shop/EMC2/serial_adc/
  • spumco
  • spumco
02 Sep 2024 04:46 - 02 Sep 2024 04:48
Something like:
loadrt [HM2](DRIVER) board_ip=[HM2](IPADDRESS)  config="sserial_port_0=01000000"
After the "=" sign, the first digit is the host board (i.e. 7i96s, 7i76e, etc.), and the 2nd digit is the sserial board connected to the host.
=01000000 - host board mode (7i76e, 7i96S)
=01000000 - sserial daughter board mode (7i73)
Make sure to figure out (i.e not overwite) what your existing host board mode needs to be.
  • spumco
  • spumco
02 Sep 2024 04:33
Replied by spumco on topic Modbus VFD startup delay?
@COFHAL-
Yes, because my VFD is not powered at startup, LCNC shuts down with a modbus error.
What I was asking earlier is if there is a way to delay LCNC trying to communicate with the VFD until after LCNC has finished starting up.  Specifically, after estop is deasserted and machine-on is true.
Ideally, estop-clear would trigger LCNC to attempt communication with the VFD, and perhaps prohibit machine-on if communications weren't established after some time.
  • chrisfischer
  • chrisfischer
02 Sep 2024 02:27 - 02 Sep 2024 02:28
Replied by chrisfischer on topic Marco Reps video on youtube about EtherCAT
Category: EtherCAT
Thanks for the comments guys, running this fixed my issue.(not sure why)
sudo apt update
sudo apt install -y linux-headers-$(uname -r) ethercat-master linuxcnc-ethercat
  • COFHAL
  • COFHAL
  • PCW
  • PCW's Avatar
02 Sep 2024 02:01
Replied by PCW on topic Error while Running Linuxcnc
What is the servo thread period?
  • rajsekhar
  • rajsekhar
02 Sep 2024 01:59
Replied by rajsekhar on topic Error while Running Linuxcnc
Watch dog timer is 5ms, HAL file attached.
Does that require any change?
  • COFHAL
  • COFHAL
02 Sep 2024 01:38
Replied by COFHAL on topic ATC: carousel.comp with Servo drive
I use the carousell component with a stepper motor in step-dir mode without any problem. So I think there is no problem using a servo motor.
Displaying 22036 - 22050 out of 24893 results.
Time to create page: 0.379 seconds
