  • Evgeny
  • Evgeny
31 Aug 2024 21:16
Replied by Evgeny on topic Marco Reps video on youtube about EtherCAT
Category: EtherCAT
Guys, tell me how to set up a search for a home position with a torque limitation on mechanical stops as in the video by Marco Reps, onceloved   helped me a lot to get the configuration up and running, but I still have one problem
onceloved , Thank you very much for your help!
Please see my configuration, it starts and can control the motors! But I can't set up the home position detection with torque limitation
File Name: linuxcnc_l..._EL8.zip
File Size:21 KB
  • ustaL
  • ustaL
31 Aug 2024 21:09
Spindle Step/Dir and as C axis one the same Servo
Category: Basic Configuration
The joint feedback could be looped
back from the C joint commanded position this case. Finally, a homing
to index move would be done to re-synchronize the spindle position to
absolute C coordinates.
The question is how? As I understand there is no command like UNlink signal with pin.
I cannot use mux2 to switch source of pos-fb (that was my first idea), because if I have position-fb = 300 in stepgen AND joint AND pid, and then somehow stepgen position-fb became 0.0 (or source of this value became 0.0 and joint/pid have 300) -> joint error occur.
  • Limo
  • Limo
31 Aug 2024 21:06
Replied by Limo on topic Problems Spindle Synchronisation
After checking everything. I think I found the culprit. Since I am using a quadrature encoder. The direction of it was reversed. I fixes that and it works. Thank you a lot for your help.
  • RotarySMP
  • RotarySMP's Avatar
31 Aug 2024 20:35
Replied by RotarySMP on topic Is there an easy way to swap axes?
Normally, I use the vertical head, which bolts on to the Y axis. But If I remove that vertical head, there is a second SK40 spindle directly in the Y axis, facing straight forward, so in that configuration, Y become -Z and Z becomes Y.
Cheers,
Mark
  • PCW
  • PCW's Avatar
31 Aug 2024 19:12 - 31 Aug 2024 19:13
in spindle mode, the stepgen velocity command comes directly from
the (perhaps scaled) spindle velocity. The stepgen feedback position
would be ignored in spindle mode. The joint feedback could be looped
  • Mr_rookie
  • Mr_rookie
31 Aug 2024 19:01 - 31 Aug 2024 19:02
5 Axis configuration on linuxcnc was created by Mr_rookie
Hi Guys, thanks for you time.
I've been doing my own search, but without much look to find some tutorial that explain me how to configure files, I know that something may have to be change on hal and ini but after that no much idea. If you guys could explain me what file have to be re-writted or changed with some explanation would be appreciated .
details:
sim axis vismach 5axis.table-rotary-tilting
using vasmich "would like to design my own machine is that is posible"
7c80  "hm2_rpspi"
connection /dev/spidev0.0
linuxcnc 2.9.3
raspberry pi 4
uname -a
Linux pi 6.6.44-rt39 #1 SMP PREEMPT_RT Mon Aug 12 21:10:13 AEST 2024 aarch64 GNU/Linux
let me know if you need more details
thanks!!
  • COFHAL
  • COFHAL
31 Aug 2024 18:58
Replied by COFHAL on topic servo motor for a spindle
Category: Milling Machines
I have another question: what control card are you going to use, mesa or a parallel port?
  • COFHAL
  • COFHAL
31 Aug 2024 18:55
Next Monday I will send you the configuration to use this servo motor as a spindle, I don't have it here at home.
  • ustaL
  • ustaL
31 Aug 2024 18:53
position feedback must be unconnected in spindle mode
That would be ideal. And how should I do that?
  • aaamil13
  • aaamil13
31 Aug 2024 18:47
I read everything posted in the forum regarding UART settings and didn't find anything specific, so I also spent quite some time trying to connect the EC500 to the computer's COM port. However, I was lucky enough to finally make the connection via the serial port. To connect the EC500 and the computer, you need a suitable RS232 adapter and to connect pin 2 (RX) of the adapter to pin 3 of the EC500, and pin 5 of the adapter to the corresponding pin on the EC500. The terminal settings are 115200 BPS, no parity check, 8-bit length, ASCII. The important thing is that in this case, the UART is not using TTL levels (3.3 or 5 volts), but rather requires an adapter for RS232 voltage levels.
  • Trevy3
  • Trevy3's Avatar
31 Aug 2024 17:31
Mesa Config Tool 7i96s MPG Firmware Flash Error
Category: Configuration Tools
Ok, just did the flash using mesaflash. Seemed to have worked. Not sure what's up with mesact. It worked fine the first time I did it. Oh well, easy enough to do from the terminal.
sudo mesaflash --device 7i96s --addr 10.10.10.10 --readhmid
sudo mesaflash --device 7i96s --addr 10.10.10.10 --write name.bin
sudo mesaflash --device 7i96s --addr 10.10.10.10 --reload
  • Ismacr63
  • Ismacr63
31 Aug 2024 17:19
Replied by Ismacr63 on topic help to connect alarm signal driver hbs86h
Category: Driver Boards
I have managed to get linuxcnc to stop when an alarm goes off, but the driver does not turn on the red LED, so I will never know which driver is faulty...
  • arijitdutta
  • arijitdutta
31 Aug 2024 17:16
Replied by arijitdutta on topic Sliders for overrides in gmoccapy
Thank you for the detailed walkthrough. I understand now how to set things up. Though it will take sometime.
But before that, when I run lsusb in terminal, it shows me "command not found". I have to run that through less /proc/bus/input/devices .. to see the unique name for my keyboard. After I add the loadusr command to my ini file in the HAL section, the keyboard button still doesn't show up in my HALshow (I am currently trying all of this on axisgui). It only shows up my gamepad. I tried to input the command directly into the HAL file, but it still doesnt show up. Am I doing anything wrong? As I feel 'lsusb' should have shown something in the terminal
  • itsbrian
  • itsbrian
31 Aug 2024 16:34
Skew correction/perpendicularity correction (millkins or millkins_xyz)
I know this thread is old, but it shows up at the top in Google search when you're looking for "LinuxCNC skew". I'd like to say that the millkins.c works for me in LinuxCNC 2.8.4.
Steps:
  1. Download the millkins.c file here: wiki.linuxcnc.org/cgi-bin/wiki.pl?Contri...y_XY_skew_correction
  2. In LinuxCNC open up the terminal to compile/install the file. Replace code block below to where actual millkins.c file is located.
    sudo halcompile --install /path/to/millkins.c
  3. The command above compiles and creates a millkins.so file located at /usr/lib/linuxcnc/modules
  4. You can go ahead and close the terminal and now open up your hal file. Find the line (should be at the top) "loadrt [KINS]KINEMATICS" and replace with millkins info. Replace #.### in example below with your actual skew factor.
    # Comment out the kinematics in case you want to roll back and add the two lines after installing millkins.so
    #loadrt [KINS]KINEMATICS
    loadrt millkins
    setp millkins.skew #.###
  5. That's it, but here is the big gotcha: This skew factor will not work when you are jogging! If you actually do a gcode command you should see it work.
Hope this helps for anyone searching this! This has been working great for me as I have a 4'x8' gantry and it is quite difficult to get this perfectly mechanically square. I have been squaring by offsetting the home position of my dual steppers on a single axis, but this is a nice alternative.
  • Ismacr63
  • Ismacr63
31 Aug 2024 16:03
Yes, they are connected
Displaying 22111 - 22125 out of 24893 results.
Time to create page: 0.433 seconds
