  • Aciera
  • Aciera's Avatar
01 Aug 2024 18:43
Replied by Aciera on topic Trajectory Planner using Ruckig Lib
Hm, as usual I'm concerned about unwanted path distortion:
I presume these splines were added by the algorithm, if so it seems like a lot of distortion for 'G64 P0.1 Q0.1'?
  • tjtr33
  • tjtr33's Avatar
01 Aug 2024 18:24
Running Axis remotely with Nomachine's NX v3.5
Category: AXIS
Hello, I just heard of this software,
Seen it in Youtube video
"Building The 5-Axis CNC Machine in a Small Room: A DIY Journey. (Part12)"
Does the software reduce the RPi's cpu load?
or,
Does the RPi still run X and OpebGL and Axis gui?
(I _think _ nhose are the alternatives )
Thx
TomP
01 Aug 2024 18:17
Replied by tommylight on topic help with installation
Category: Installing LinuxCNC
sudo apt purge linuxcnc-uspace linuxcnc-uspace-dev
  • trisa25
  • trisa25
01 Aug 2024 18:01
Replied by trisa25 on topic Ebosa 140 CNC retrofit
Category: Turning
Thank you Mark!
Here is a picture of the back side of the panel, 7i73 reading switches, 2 potentiometers and mpg encoder.
It also drives 30 LEDs under switches (multiplexed). The multiplexing is currently done in hal but I will try to write a component for it.
And this is a custom power detection board. Basically just 12 AC optocouplers and a relay output to detect a open breaker or motor overloads.
Also do you insert pictures in posts as attachments or someway different. On some pictures even if I compress them, forum still complains about large file size.
  • meister
  • meister
01 Aug 2024 18:01
i tryed RMII with the tangnano9k, bitfile generation works, but get no connection :(
better go with esp32:
github.com/multigcs/LinuxCNC-RIO/tree/main/UDP2SPI-Bridge
i prefer the WT32-ETH01, cheap and available
  • slowpoke
  • slowpoke
01 Aug 2024 17:59 - 01 Aug 2024 18:18
Data transfer LinuxCNC to / from custom board - Solved
I knew there was another HAL component that might be relevant, I don't know how I missed it:
linuxcnc.org/docs/stable/html/man/man1/sendkeys.1.html
Andy,
I need some clarity on a few points for sendkeys.
At this point I have an Arduino board that can trigger events in halshow, So when I activate an Arduino connected push button, the jog-x-pos and the halui.axis.x.plus changes from yellow to red. I expect the actual X-axis to jog when I press that button, however other than the yellow to red indication nothing happens. (the system is NOT in Estop, and the machine is enabled on the manual control tab. If I mouse click on the "+" button, the x axis does jog.
Do I need to enable/invoke SENDKEYS, to actually get the yellow to red indication of jog-x-pos to do something?
Assuming that I do need to enable SENDKEYS, I need a little help with a few points in the SENDKEYS documentation.
 Instructions say "Create a new entry in .B/etc/udev/rules.d/99-input.rules"
I'm not sure where ".B" is?
I did find       /etc/udev/rules.d/70-persistent-cd.rules
So neglecting the missing ".B"  I assumed this is the file I'm supposed to update?
However when I add "sudo echo KERNEL=="uinput", GROUP="uinput", MODE:="0660" | sudo tee /etc/udev/rules.d/70-persistent-cd.rules" to that file I get the attached error message. So lots of possible mistakes here: wrong location, wrong file, adding the uinput group did not work even though it seemed to (see last attachment) the discrepancy between 99-input.rules ,77-persistant-cd.rules , 88-input.rules?
Please advise.
  • Grotius
  • Grotius's Avatar
01 Aug 2024 17:54 - 01 Aug 2024 18:04
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
Hi Arciera,
Ok, I will not worry about it.
I tried a free gcode file, a griffins logo. File about 14000 lines.
www.cnccookbook.com/g-code-examples-file...for_Milling_Machines
In the file no G64 P.. Q.. was given. Raw output :
Then i added G64 P0.1 Q0.1
The output :
Then without the velocity display :
The purple are all clothoids. Cyan is spline, White is line.
File specs :
items G64 P.. Q.. before:14151 after:28292 diff:-14141
So the gcode file is increased by 14141 segments.
Maybe test some more files?
  • Mecanix
  • Mecanix
01 Aug 2024 17:42
At the moment a UDP2SPI bridge (esp32) is still the best solution.
This one?
WT32-ETH01 ESP32 Ethernet Development Board
  • Aciera
  • Aciera's Avatar
01 Aug 2024 17:35
Don't worry about it, it's really not important.
  • Mecanix
  • Mecanix
01 Aug 2024 17:34
@meister
Late on and I got it to work. However and as you've pointed out, the comm needs fine tuning! Can I bother you once more and ask for a detailed hardware desc for the ESP32 you've mentioned? Is there a UDP module in particular you'd like us to use and dev around? I'm also happy to get a RMII breakerboard as a second option. Both would be ideal though. All-in-all it's working well. Congrats!!
Visual of the w5500 output:
  • trisa25
  • trisa25
01 Aug 2024 17:32 - 01 Aug 2024 17:36
Replied by trisa25 on topic LinuxCNC and Beckhoff AX5000 servo drives
Category: EtherCAT
Yes, i saw some posts but they did not share any clear results.
Thank you.
  • Grotius
  • Grotius's Avatar
01 Aug 2024 17:30
Hi Arciera,
I can write gcode file output tomorrow, but clothoids & splines must then be converted to a G1 linestrip.
Then the overall output is G1,G2 or G3.
Is this ok for you?
  • cnbbom
  • cnbbom
01 Aug 2024 16:46
Replied by cnbbom on topic help with installation
this says it is conflicting
  • cnbbom
  • cnbbom
01 Aug 2024 16:38
following the steps indicated, it says that I must uninstall any traces of Linux, but I receive the following message.
To install on Debian 12 with linuxcnc-uspace already installed use : sudo apt purge linuxcnc*  and wait for apt to completely remove every trace of LCNC.
but it happens this way
01 Aug 2024 16:30
1 linux image
2 linux headers
3 linuxcnc
4 rtai modules
OR
3 rtai modules
4 linuxcnc
Gdebi will tell you if there is something that needs to be installed.
Displaying 24061 - 24075 out of 25070 results.
Time to create page: 1.121 seconds
