  • BlownCorona
  • BlownCorona
01 Jun 2025 21:40
Replied by BlownCorona on topic Mesa 7i97T & LinuxCNC setup struggles
Category: Installing LinuxCNC
Thanks everyone, ill dig into the above suggestions.
And yes, i should have been a little clearer, im not worried about the following error stuff, i was just happy to be seeing signs of life.
  • h_munktell
  • h_munktell
01 Jun 2025 20:45 - 01 Jun 2025 20:48
Replied by h_munktell on topic Dust Collection Shoe with independent Z control
Ok, think I have figured it out, most of it at least. Had to make a visual representation of the HAL finnstrom posted. See attachement. Also got it sort of working on my machine. Tanks so much!Some things I'll try to adopt
  • Instead of controlling with coolant-mist, I would do it with a motion.digital-out pin controlled with M62 and M63
  • Trying to get the w_offset from actual w0 in current coordinate system. My thought is to touch of both Z to the work piece, and set w0 in G54 (for example) at the desired height. Then, somehow in HAL, calculate the w0 offset from w joint zero. In the (unlikely) event that I need dust shoe for G55 etc, this should enable this to work.
  • In conjunction with above, I think I need jogging to work (in qtdragon) to easy set w0 current coordinate system.
  • akim14
  • akim14
01 Jun 2025 20:14
LinuxCNC Dual-Head Gantry Setup Assistance Request
Thank you so much I am still having problems setting up the limit and home switches in the main hal , I used mesa CT here are my files, I noticed you used the code down below but i cant seem to replicat it without error
# --- MIN-HOME-X ---
net min-home-x <= hm2_5i25.0.7i77.0.0.input-00-not
# --- MAX-X ---
net max-x <= hm2_5i25.0.7i77.0.0.input-01-not
# --- MIN-HOME-Y ---
net min-home-y <= hm2_5i25.0.7i77.0.0.input-02-not
# --- MAX-Y ---
net max-y <= hm2_5i25.0.7i77.0.0.input-03-not
# --- MIN-Z ---
net min-z <= hm2_5i25.0.7i77.0.0.input-07-not
# --- MAX-HOME-Z ---
net max-home-z <= hm2_5i25.0.7i77.0.0.input-06-not
# --- MIN-W ---
net min-w <= hm2_5i25.0.7i77.0.0.input-05-not
# --- MAX-HOME-W ---
net max-home-w <= hm2_5i25.0.7i77.0.0.input-04-not
# --- X_READY ---
#net X_Ready <= hm2_5i25.0.7i77.0.0.input-08
# --- Y_READY ---
#net Y_Ready <= hm2_5i25.0.7i77.0.0.input-09
# --- Z_READY ---
#net Z_Ready <= hm2_5i25.0.7i77.0.0.input-10
# --- W_READY ---
#net W_Ready <= hm2_5i25.0.7i77.0.0.input-11
# --- Z_SPINDLE_RUNNING ---
net Z_Spindle_running <= hm2_5i25.0.7i77.0.0.input-12 => and2.0.in0
# ---setup home / limit switch signals---
net min-home-x => axis.0.home-sw-in
net min-home-x => axis.0.neg-lim-sw-in
net max-x => axis.0.pos-lim-sw-in
  • kworm
  • kworm
01 Jun 2025 18:00
Replied by kworm on topic Merging operations NGC files Fusion 360
Category: CAD CAM
You are correct I have a paid license. I used to use the free version some time ago and I don't remember it having that limitation but I know they have made multiple license changes over time for the free version which is unfortunate. Glad to see you have made a solution to work around it.
I don't use axis but this post may be similar to what you are looking for:
forum.linuxcnc.org/20-g-code/36186-use-m...messages-my-solution
  • poesel
  • poesel
01 Jun 2025 17:46
Position: relative expected was created by poesel
I'm trying to run a little test program, and it aborts with the fault message: 'Motor 0 Positionssfehler (sic!) Position: relativ erwartet' ('motor 0 positioning error position: relative expected').
The program is this:
(G90: Set to Absolute Positioning)
G90
(G94: Feed Rate Mode Units per Minute)
G94
(G17: Select XY plane for arc moves for G2 G3)
G17
(G21: Set Units to Millimeters)
G21
(G54: Select coordinate system 1)
G54
G1 X0 Y0 F1000
G1 X10 Y0
G1 X10 Y10
G1 X0 Y10
G1 X0 Y0
M30
I'm a bit surprised since I'm setting G90. What am I doing wrong?
Thanks!
P.S. little typo: 'Positionssfehler' should be 'Positionsfehler'
  • langdons
  • langdons
01 Jun 2025 16:36
Replied by langdons on topic LinuxCNC compatible industrial PC
Try this:
askubuntu.com/questions/1021748/set-cpu-...performance-in-18-04
It reduced latency for me.
Make sure your PC is not home to vast quantities of dust, it will block fans and airflow, and makes stuff work less well.
  • Hypnotoad
  • Hypnotoad
01 Jun 2025 16:35
Confused about how to set up Probe Basic on a Raspberry Pi
Category: QtPyVCP
I have a working configuration with LinuxCNC using AXIS and would like to try switching to Probe Basic.  I've gone thru the Pncconf trying to create a Probe Basic configuration and it seems to require configuration of Mesa cards which I don't have.  I'm using direct GPIO into a Rpi hat, which isn't directly supported from the standard stepconf tool either, but I was hoping to do what I did with stepconf -- make a config that assumes normal Linux parallel port configuration, and then modify that to use the Rpi GPIO HAL.
I saw a reference to a Probe Basic sim configuration in another thread with the suggestion that someone with a working normal stepconf config could look at the Probe Basic sim config and see what modifications need to be made.  But I can't find that sim config.
Could someone point me in the right direction?
  • langdons
  • langdons
01 Jun 2025 16:34 - 02 Jun 2025 15:19
  • Doc_emmet
  • Doc_emmet
01 Jun 2025 15:41
Replied by Doc_emmet on topic QTDragon stop & pause run
Category: Qtvcp
Hello,
I found the file qtdragon_handler.py on my hard drive and copied it to my machine folder, and now it works.
So, it seems there's a path missing from my .INI file?
  • wusel0464
  • wusel0464
01 Jun 2025 15:38
Replied by wusel0464 on topic Reading variable from ini no longer works?
Category: Qtvcp
Hello,
Thanks for the quick help.
Now I just deleted the comments in the Ini and the mistake has disappeared. But the comments were at least half a year without problems.
Something must have changed lately.
I left the comments in the change routine.
Very strange.
Many greetings and thanks, Frank
  • unknown
  • unknown
01 Jun 2025 15:30
installing linuxCNC 2.7.14 under Hyper-V Manager
I'll have a look tomorrow, what ISO are you using, exact filename will make life easier, any particular reason for 2.7.14 ?
Windows or Linux host ?
  • proff
  • proff
01 Jun 2025 15:23
Replied by proff on topic home build cnc cutting fabric machine
Category: Plasma & Laser
hello every one thank's a lot for your supporting reviews
I will try to reply all your questions
maximumm Y length : could be mostly infinite but more probably arround 10 to 50 m as I'm mainly intrested in kite building (or hot air balloons if it works ;)
fabric to be cut will be mainly spinaker nylon witch is unstrechable and has 2 different sizes of frame that make a small patern easyly sens by optical mouse sensors
ESP cam is a great idea if it could keep track of move even when speed rising up mouse sensor is mainly a very low res grey scale cam
fabric tension : first idea was only to add a bit aof static friction on non pulling side motors but torque management is a good point too
it could also avoid me to do somthing I've not explain yet I was planning to make in cutting back plate 2 serries of holes and hook it to small but enough vacuum source to suck the fabric on the back plate and cut between tow lines of holes
to avoid wrinkles and other disasters when roolling and unrolling already cut parts I was thinking doing some kind of timestamping or tabs like on pcb pannels or others flat milling machines or wood or composites pannels
thank's for all your advice
now I think the best thing is to try few things
can you please advise me some harware in order to connect all of this
6 stepper controller (may be I will use one more small stepper to focus laser beam)
and 2 or 3 esp cam or mouse sensors (may be I can also get a closed loop on X axis)
  • clayton2ndtry
  • clayton2ndtry
01 Jun 2025 15:15
Replied by clayton2ndtry on topic installing linuxCNC 2.7.14 under Hyper-V Manager
I am now trying to install under VirtualBox. It never completes. End of log:
00:01:24.910162 VUSB: Detached 'HidMouse' from port 1 on RootHub#1
00:01:24.910963 E1000#0: Interrupt attempts: 1
00:01:24.910970 E1000#0: Interrupts raised : 0
00:01:24.910972 E1000#0: Interrupts lowered: 0
00:01:24.910974 E1000#0: ICR outside ISR : 0
00:01:24.910976 E1000#0: IMS raised ints : 0
00:01:24.910980 E1000#0: Interrupts skipped: 0
00:01:24.910983 E1000#0: Masked interrupts : 1
00:01:24.910985 E1000#0: Early interrupts : 0
00:01:24.910986 E1000#0: Late interrupts : 0
00:01:24.910988 E1000#0: Lost interrupts : 0
00:01:24.910990 E1000#0: Interrupts by RX : 0
00:01:24.910991 E1000#0: Interrupts by TX : 0
00:01:24.910993 E1000#0: Interrupts by ICS : 0
00:01:24.910995 E1000#0: Interrupts by RDTR: 0
00:01:24.910996 E1000#0: Interrupts by RDMT: 0
00:01:24.910998 E1000#0: Interrupts by TXQE: 0
00:01:24.911000 E1000#0: TX int delay asked: 0
00:01:24.911001 E1000#0: TX delayed: 0
00:01:24.911003 E1000#0: TX delay expired: 0
00:01:24.911005 E1000#0: TX no report asked: 0
00:01:24.911006 E1000#0: TX abs timer expd : 0
00:01:24.911008 E1000#0: TX int timer expd : 0
00:01:24.911009 E1000#0: RX abs timer expd : 0
00:01:24.911011 E1000#0: RX int timer expd : 0
00:01:24.911013 E1000#0: TX CTX descriptors: 0
00:01:24.911015 E1000#0: TX DAT descriptors: 0
00:01:24.911018 E1000#0: TX LEG descriptors: 0
00:01:24.911020 E1000#0: Received frames : 0
00:01:24.911021 E1000#0: Transmitted frames: 0
00:01:24.911023 E1000#0: TX frames up to 1514: 0
00:01:24.911025 E1000#0: TX frames up to 2962: 0
00:01:24.911028 E1000#0: TX frames up to 4410: 0
00:01:24.911029 E1000#0: TX frames up to 5858: 0
00:01:24.911031 E1000#0: TX frames up to 7306: 0
00:01:24.911032 E1000#0: TX frames up to 8754: 0
00:01:24.911034 E1000#0: TX frames up to 16384: 0
00:01:24.911036 E1000#0: TX frames up to 32768: 0
00:01:24.911037 E1000#0: Larger TX frames : 0
00:01:24.911039 E1000#0: Max TX Delay : 0
00:01:24.911911 GIM: KVM: Resetting MSRs
00:01:24.912967 vmmR3LogFlusher: Terminating (VERR_OBJECT_DESTROYED)
00:01:24.913083 Changing the VM state from 'DESTROYING' to 'TERMINATED'
00:01:24.913094 Console: Machine state changed to 'PoweredOff'
00:01:24.942548 GUI: Request for async QApp quit.
00:01:24.944297 GUI: Cannot notify guest about VM window out-of-focus event
00:01:24.956701 GUI: UICommon: Handling aboutToQuit request..
00:01:26.425803 GUI: UICommon: aboutToQuit request handled!
  • npostma
  • npostma's Avatar
01 Jun 2025 15:14 - 01 Jun 2025 15:59
Replied by npostma on topic Merging operations NGC files Fusion 360
Category: CAD CAM
I’m guessing you’re using Fusion 360 with a paid license? I’m just a hobbyist and only use the free version (not for commercial work), which is much more limited. When I try to export multiple operations with different tools at once, Fusion 360 warns me that this isn’t possible in the free version—I have to save each operation as a separate file as suggested by fusion360. So, for LinuxCNC/Fusion360 users like me, the options are either to load each file separately in LinuxCNC (after each one ends), or to merge all files into a single program, which is what I do with my own script.
Even as a hobbyist, I often need toolchanges: most of my projects require a roughing pass with a large end mill and then finishing with a smaller tool.
Question:
Does anyone know if it’s possible to display a popup or notification when running an M0 or M1 g-code in the AXIS GUI? I’d like to give myself (or any user of my script) a clear notification to change tools, especially since when remapping M6 I lose the standard toolchange popup.
Thanks!
  • Doc_emmet
  • Doc_emmet
01 Jun 2025 15:13 - 01 Jun 2025 15:14
Category: Qtvcp
Hello,
I'm using the file pause_pin_2023-09-18.py and I'm getting an error message.
I started LinuxCNC in the terminal with "linuxcnc -v My-Machine.ini" and I get this message:
User command file for pause pin found
[QTvcp.QTVCP.QT_MAKEGUI][ERROR]  No module named 'qtdragon_handler' (qt_makegui.py:361)
  File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 359, in call_user_command_
    exec(compile(open(rcfile, "rb").read(), rcfile, 'exec'),local)
  File "pause_pin.py", line 5, in <module>
    import qtdragon_handler as SELF
ModuleNotFoundError: No module named 'qtdragon_handler'
How can I fix the error?
Displaying 2581 - 2595 out of 24953 results.
Time to create page: 0.220 seconds
