  • snowgoer540
  • snowgoer540's Avatar
13 May 2025 17:10
Replied by snowgoer540 on topic Job not showing in position - 2.9.4 - v2.9-238.315
Category: Plasmac
I apologize, this fell off my radar. I’m not sure what I’m looking at exactly, but a few observations:
1. That’s not the file you posted above
2. Are you showing a cut run and then clicking on framing? Everything happens so fast in that video and it doesn’t show the whole screen so it’s hard for me to follow what exactly is going on
I’ll try to simulate your setup this evening if time allows.
  • jochen91
  • jochen91
13 May 2025 16:48
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
I figured it out now and could fix it.
There is one more thing. The key binding.
I found: forum.linuxcnc.org/21-axis/14675-keyboar...key-binding?start=20
and implemented the .py file. It works, but i want to use page up/down for the X axis. How should one know how the correct name/definition in the .py file has to be? Do you have an idea ?
Z and Y works.
  • DarkPhoinix
  • DarkPhoinix
13 May 2025 16:44
Replied by DarkPhoinix on topic Which kernel version is best for real time?
You should really mention you keep using the remote desktop, not everyone here knows what RustDesk is.
And that begs the question, how is the NVEM wired to the PC?
So yes, rustdesk is causing issues, but if you are using a hub/switch, that is a big nono for machine control.
So why do they do these tests with 4 YouTube videos in 4k in the forum? in direct connection with stress test 100 GLXgears I can work safely even with NVIDIA! I got this AMD VGA and now I also bought a motherboard with HDMI output to pass the YouTube 4K video test!
  • billykid
  • billykid's Avatar
13 May 2025 16:01
Replied by billykid on topic sanmotion rs2a03a0al0w00
Category: Driver Boards
the strange thing is that they are the usual PCs and software that worked a year ago... then my brother had a serious health problem I gave up everything, now everything is better I wanted to look for some motors to use them and I am no longer able to connect them to the PC. I ordered a cable with the right plug when it arrives I will try again. last year I had soldered the GND RXD TXD wires and screen only on the servo side and it worked perfectly.
thanks Tom
  • jochen91
  • jochen91
13 May 2025 15:55 - 13 May 2025 16:00
Replied by jochen91 on topic Deckel-Maho DMU 50T
Deckel-Maho DMU 50T
Category: Milling Machines
I used this IC:
www.ichaus.de/product/ic-nv/
I had a Heidenhain rotary encoder with the same 1VSS signal. The IC converted it to TTL. Worked (and still does) flawlessly.
Included is a Layout for 2 and 4 Layers. I used the 2 layer board. But with prices so cheap, i would order the 4 layer for better signal integrity.
  • Aciera
  • Aciera's Avatar
13 May 2025 15:50
Linuxcnc will save the work offset on shut down. Also G54 is the default offset system on startup. Since the example code contains ' g10 l2 p0 x0 y0 z180' the G54 z-offset is set to 180 which is then stored on shutdown and restored on restart.
As far as I know it has always restored the last offset values but I have only ever worked with Versions 2.8 or later.
13 May 2025 15:35
Replied by tommylight on topic Which kernel version is best for real time?
  • jochen91
  • jochen91
13 May 2025 15:31
But how is G54 active after homing and no G-code execution? I have two machines running LCNC (2.7.4) an both don't do that. That's confusing me a little bit.
RS274NGC_STARTUP_CODE = G17 G21 G40 G49 G64 P0.001 G80 G90 G92.1 G94 G97 G98
# G54
I commented the G54 out of the .ini File but the behavior does not change.
13 May 2025 15:29
Replied by tommylight on topic Moving from Axis to QtDragon?
Category: Qtvcp
You are welcomed, always.
Sorry for the short and lacking replies, but when i am busy i try to at least point to a direction.
13 May 2025 15:26
Replied by tommylight on topic sanmotion rs2a03a0al0w00
Does the software work on XP?
If yes, find and download "userport.exe", it was/is for granting access to ports on Win98/2000/XP. No idea if it works for 7 and up.
You could also try to run the software in Linux using Vine, does not always work, but worth a try.
  • kello711
  • kello711's Avatar
13 May 2025 15:24
Replied by kello711 on topic 7i96 with THCAD-2 setup on Everlast 82i
Category: Plasma & Laser
Looks like the /32 setting was the ticket. Between that and making the offset/scale changes, it appears my voltage readings are in order. Next step is getting the voltage/height adjustments in setup.
Do you happen to have any material libraries for the Everlast 82i? IIRC, you were using that before. I haven't been able to find anything reliable online yet.
  • DarkPhoinix
  • DarkPhoinix
13 May 2025 15:21 - 13 May 2025 15:24
sudo apt-get install r8168-dkms
Lettura elenco dei pacchetti... Fatto
Generazione albero delle dipendenze... Fatto
Lettura informazioni sullo stato... Fatto
r8168-dkms è già alla versione più recente (8.051.02-2).
0 aggiornati, 0 installati, 0 da rimuovere e 3 non aggiornati.
The module is this, they are update...
NO RUSTDESK
sudo chrt 99 ping -i .001 -q -c 60000 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
--- 10.10.10.10 ping statistics ---
60000 packets transmitted, 60000 received, 0% packet loss, time 59999ms
rtt min/avg/max/mdev = 0.154/0.210/0.417/0.027 ms
WITH RUSTDESK
60000 packets transmitted, 60000 received, 0% packet loss, time 60006ms
rtt min/avg/max/mdev = 0.131/0.213/2.341/0.035 ms
13 May 2025 15:20
Replied by tommylight on topic LinuxCNC via ethernet w5500 and esp32
Category: Show Your Stuff
Did a bit of tweaking and got this to run reliably at 40KHz on all 3 stepgens, got rid of some fuzzy issues where at higher speeds after a jog the motor/output would dither back/forth all the time, adjusted PID so it tracks under 0.1mm at 24M/M always, changed pins (as i have an ESP32 on a Arduino Uno form factor) for the stepper shield, etc.
This uses the HAL2UDP, the older version from github, the new version has something messed up with some "ready" checks, did not feel like dropping into that rabbit hole.
  • Spyderbreath
  • Spyderbreath's Avatar
13 May 2025 15:12
Replied by Spyderbreath on topic Moving from Axis to QtDragon?
Category: Qtvcp
MAX_VELOCITY on both.
That works. My confusion was thinking there should of been and _OVERRIDE function like rapid. Thanks, that solved several problems with my setup.
  • DarkPhoinix
  • DarkPhoinix
13 May 2025 15:11
  33  s32   RW       16640759  remora.read.tmax
I don't know the CPU clock frequency but if it's say 3 GHz, this is ~5 ms
so if you have a 1 ms servo thread, you are likely dropping packets
This indicates a network latency issue.
So possible the DKMS patch did not apply or there is still something
remaining wrong with the network setup.
I would run the ping test again, as it will show these issues clearly
60000 packets transmitted, 60000 received, 0% packet loss, time 60017ms
rtt min/avg/max/mdev = 0.128/0.215/3.609/0.047 ms
sudo lsmod | grep r8
r8168                 581632  0
sudo dmesg | grep r8
[    0.024413] percpu: Embedded 62 pages/cpu s217088 r8192 d28672 u524288
[    0.024419] pcpu-alloc: s217088 r8192 d28672 u524288 alloc=1*2097152
[    0.936673] r8168: loading out-of-tree module taints kernel.
[    0.936799] r8168: module verification failed: signature and/or required key missing - tainting kernel
[    0.949871] r8168 Gigabit Ethernet driver 8.051.02-NAPI loaded
[    0.982399] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[    0.982420] r8168  Copyright (C) 2022 Realtek NIC software team <nicfae@realtek.com>
[    0.996908] r8168 0000:03:00.0 enp3s0: renamed from eth0
[    8.722135] r8168: enp3s0: link up
Displaying 4426 - 4440 out of 24338 results.
Time to create page: 0.615 seconds
