  • Leuo_
  • Leuo_
08 May 2025 15:33
Help to configure external start button and external emergency button, EK1100
Category: EtherCAT
Hello,
Iam using EK1100 coupler and EL1008 for inputs and EL2008 to outputs, i try make in .hal file the configuration to use external buttons for Start and Emergency, how i can make in .hal file to link the rights io's ins .hal file.
Thanks for the help.
  • langdons
  • langdons
08 May 2025 15:33
Can I have 2 seperate interfaces on the same computer?
If you are using stepconf, just change the GUI dropdown and save changes.
(Make a copy of config first just in case)
  • Catch22
  • Catch22's Avatar
08 May 2025 15:30
  • langdons
  • langdons
08 May 2025 15:22
Replied by langdons on topic Which kernel version is best for real time?
Perhaps try this:
Save your config files somewhere very safe.
Open your PC and remove all unnecessary hardware (except the GPU).
Reinstall LinuxCNC from the official ISO. (The latest version, or perhaps some earlier version).
Set CPU governor to performance.
Run latency test.
See if latency is improved.
Changing the scaling govenor to performance reduced my latency a noticable amount.
  • DarkPhoinix
  • DarkPhoinix
08 May 2025 15:20
Replied by DarkPhoinix on topic TB6560 jp-1635a driver pin connection to NVEM v5
Category: Driver Boards
Signal Power <-------------> com+
Pul- <---------------------> cpx- ​​ ​
Dir- <---------------------> dix-
Solved need editing txt to upload to NVEM with DMA options, but for make signals need oscilloscope and function generator.
  • Spyderbreath
  • Spyderbreath's Avatar
08 May 2025 15:10
Replied by Spyderbreath on topic Moving from Axis to QtDragon?
Category: Qtvcp
I regret to inform you, but maybe a better closing statement would be - "and there is almost no chance it starts up. A starting point"
Attached is the LinuxCNC Errors report that comes from trying to run the config with "DISPLAY = qtvcp qtdragon". The forum will not let me put the error in the code quotes as it thinks it's spam being posted. Any suggestions as to what needs to be done to start to fix the mess?
  • langdons
  • langdons
  • vre
  • vre
08 May 2025 14:58 - 08 May 2025 15:04
Replied by vre on topic Run/Step Hold/Resume Buttons
Category: HAL Examples
This config if you push start and it is in manual mode changes to auto automatically and runs the code.
How to do it not change to auto automatically?
I have changed this
net run-sig halui.mode.auto halui.program.run <= and2.2.out
to this
net run-sig halui.program.run <= and2.2.out
but continues to run the program even it is in manual mode.
Also this must uncommented or not ?
# net pause.on and 2.3.in1 <= halui.program.is-paused
  • fery15sty
  • fery15sty
08 May 2025 14:51
Replied by fery15sty on topic Axis Position Logger
Category: AXIS
ok, i have tried editing the code to change it to R. after many errors finally it worked..
and the results
  • bobwolf
  • bobwolf
08 May 2025 14:51
Replied by bobwolf on topic mesa 7i90hd
mesa 7i90hd
thank you very much
i loaded the new firmware and everything works.
in the folder that i downloaded from the official mesanet site i saw that there are many .bit files
is there a way to know what the various configurations do?
i searched around a bit but i didn't find anything...
ciao
Roberto
  • DarkPhoinix
  • DarkPhoinix
08 May 2025 14:47
Which kernel version is best for real time? was created by DarkPhoinix
I tried several times even asking for help to solve the latency problems even by changing the video card.
I opened a post here:
forum.linuxcnc.org/38-general-linuxcnc-q...st-ambiguous-results
So I decided to do it my way and not Debian's way.
www.kernel.org/
I have always used Debian but as always this time I will have to compile the kernel by hand, hoping that there are not too many changes since the last time I did it, but I doubt it.
Can anyone please tell me which kernel is best for RT?
Thanks a lot.
  • Catch22
  • Catch22's Avatar
08 May 2025 14:33
Hello Everyone,
I have a question about using 2 interfaces on the same computer.
Right now I have my milling machine and it works on is axis 2.8.2 running on linux mint 19.3
But I really want to try Probe Basic but I don't want to ruin whats already working, can I
Install the latest version of Linuxcnc and Probe Basic and go back and forth between the two
to see if I can get it working on Probe Basic without deleting axis 2.8.2?
Thanks Mike
  • Aciera
  • Aciera's Avatar
08 May 2025 14:25
Replied by Aciera on topic Axis Position Logger
Category: AXIS
Not as it is. It would have to be added to this part of the code (unfortunately I'm rather busy with other things right now):
  • vre
  • vre
08 May 2025 14:17
Replied by vre on topic free CADCAM
free CADCAM
Category: CAD CAM
What is the status of blendercam ?
  • PCW
  • PCW's Avatar
08 May 2025 13:31
Replied by PCW on topic mesa 7i90hd
mesa 7i90hd
You can read the current firmware pinout and change the installed firmware with mesaflash
something like:
sudo mesaflash --device 7i90hd --epp --addr 0x378 --readhmid
To read the currents firmwares pinout.
or
sudo mesaflash --device 7i90hd --epp --addr 0x378 --write 7i90_epp_svst8_12_2x7i47.bit
To change the firmware to 7i90_epp_svst8_12_2x7i47.bit
Displaying 4846 - 4860 out of 24335 results.
Time to create page: 0.296 seconds
