07 May 2025 01:33 - 07 May 2025 01:34
Replied by tommylight on topic LinuxCNC download for Debian 12
www.linuxcnc.org/iso/linuxcnc_2.9.4-amd64.hybrid.iso
Debian 12 with LinuxCNC included.
You can also install on Debian 12 just by running this in a terminal:
sudo apt update
sudo apt install linuxcnc-uspace
This will install everything required to run machines, but beware that laptops are usually not good for that due to inherent power saving options.
Do give it a try.
  • Revinvoss
  • Revinvoss's Avatar
07 May 2025 01:29
LinuxCNC download for Debian 12 was created by Revinvoss
Hello to all, I am new here and, do hope to learn what I can for what I intend to do with the CNC Router table and, linuxCNC. found this forum by chance, luck me.
I have Debian 12 on a laptop computer, I will be using this for the CNC router table in the workshop, I hope!
The issue I have is that I can not find a good site that has LinuxCNC that works on Debian 12 for download.
Is there anywhere that has this as a download? I simply need to put it on a flash drive and install it to the laptop.
Any help would be appreciated.
  • snowgoer540
  • snowgoer540's Avatar
07 May 2025 01:20
Replied by snowgoer540 on topic Job not showing in position - 2.9.4 - v2.9-238.315
Category: Plasmac
So I've run this in my virtual machine several times, both in an imperial and a metric simulation on v2.9.238.315.  I cant get it to do anything but cut in the same place over and over.
Perhaps it would be helpful to know more about your workflow?  If it's still a problem, maybe a backup of your config as made from QtPlasmaC would help.
  • PCW
  • PCW's Avatar
07 May 2025 00:53 - 07 May 2025 01:14
mesa 7i73 4x8 keypad problems on KEY8 input
Category: Driver Boards
Unfortunately its a bit more complex, the remote update seems to not work properly
with Rev 14 or earlier base part and Rev 15 and newer user parts, so until
this can be figured out, cards Rev 14 or earlier would need to be updated
to Rev 16 with  a PIC programmer. I will try and figure this out tomorrow
but its a bit subtle...
You can get back the original functionality (with key 8 long wiring bug)
by remote updating to the R14 version
07 May 2025 00:42
Replied by tommylight on topic soft limit error after x homing, does not home y
the one with .ini at the end.
Use a text editor to edit it, not the office suite.
  • Micro2000
  • Micro2000
07 May 2025 00:30
  • Lcvette
  • Lcvette's Avatar
06 May 2025 23:38 - 06 May 2025 23:39
Replied by Lcvette on topic Losing some values after PB restart
Category: QtPyVCP
probe_basic --version
  • Lcvette
  • Lcvette's Avatar
06 May 2025 23:31
Replied by Lcvette on topic config tool setter
config tool setter
Category: QtPyVCP
Double check you have the correct subroutines for the latest update.
  • Lcvette
  • Lcvette's Avatar
06 May 2025 23:29
Probe Basic Documentation and Installation... Start Here!!!
Category: QtPyVCP
Every config is a bit different but mostly the same. You can compare to the sim config for verification.
  • Lcvette
  • Lcvette's Avatar
  • Tntmold
  • Tntmold
06 May 2025 23:09
Replied by Tntmold on topic General Questions about using ethercat
Category: EtherCAT
I made those changes to the xml but I see no difference.
ethercat slaves shows both drives in OP but I can't get them to move and the motor shafts act as if no power is present
  • dbtayl
  • dbtayl
06 May 2025 23:05
Replied by dbtayl on topic free CADCAM
free CADCAM
Category: CAD CAM
For anyone wanting to explore FreeCAD I would highly recommend using the latest development versions. There are nightly builds available through a ppa but I personally would (and do) opt for the near weekly builds of the AppImages from here - github.com/FreeCAD/FreeCAD-Bundle/releases/tag/weekly-builds - Linux, Mac and Window$. No worries about dependences and if any given build has a showstopper bug, you can still have the last weeks to keep going until the next build that will, 99% of the time have that bug fixed. Lots of advanced and more complete features keep showing up. Especially in the CAM workbench.
This is worth reiterating, IMO. Folks seem to be offput by the risk of bugs/crashes in the "weekly" builds, which is both fair and overblown. It's fair in that individual weekly builds occasionally have large issues/bugs (hence Spyderbreath's sound suggestion to not delete your known-working version until you've verified the very latest works). It's overblown in that most of the time they're actually less prone to crashing than 1.0 and have a lot of improvements.
This isn't Microsoft- you can find a weekly build that works for you, and then just not update it if you want a middle ground of getting some of the newer improvements while avoiding most of the instability.
  • CallumRD1
  • CallumRD1
06 May 2025 23:03
Replied by CallumRD1 on topic G-code file loading at G53 instead of G54
Category: Qtvcp
Thank you for the help. I do appreciate it.
In case it helps anyone else willing to give me a hand diagnosing this issue, I've attached my .ini configuration file.
  • Rocky
  • Rocky
06 May 2025 22:56
Replied by Rocky on topic Hi everyone
Hi everyone
hope i did this right
  • Rocky
  • Rocky
06 May 2025 22:38
Hi everyone
Sorry had a family thing come up I'll post my files up in a min so I can get things checked over befor I power it up and not fry my stuff
Displaying 4936 - 4950 out of 24338 results.
Time to create page: 0.343 seconds
