  • langdons
  • langdons
30 Apr 2025 22:12
Is there a bug in the carousel component or am I doing it wrong ATC Denford
Try out QtDragon.
You might find you prefer it.
Better to spend time finding the right path than to start on a wrong path and have to do everything over.
  • Adam Maszynotwór
  • Adam Maszynotwór's Avatar
30 Apr 2025 22:09
I have a few observations:
no pulses are generated for reverse movement when the magazine turns in one direction the stepgen.2.position-cmd value changes by 400 then stepgen.2.position-fb and carousel.0.counts tend to this value. when the moment comes for reverse movement nothing changes in the three above parameters. despite the fact that the Dir pin changes there are no pulses - so for some reason the carousel component does not add pulses resulting from the set carousel reversing time. N .rev-pulse .
I do not know how the mechanism should work the instruction says carousel.N.rev-pulse float in
The duration in seconds for which a ratchet changer (Boxford, Emco) should pulse the reverse pin to lock the holder.
on logic so pulses in an indefinite number for a specified time possibly some mathematics could calculate that if someone wants the reversing to last 5 sec. and the pulse frequency is known, stepgen.2.position-cmd should be increased by the result of these calculations and the pulsation command should be issued.
  • grijalvap
  • grijalvap's Avatar
30 Apr 2025 21:39
Replied by grijalvap on topic Zero Pierce delay After pierce Only
Category: Plasmac
sorry I was no clear What yo mention is the actual process What I stated is the future state if the process can be modified we trying to avoid using 2 materials or 2 gCode files or edit the Gcode file to change PD to 0
30 Apr 2025 21:20
Replied by tommylight on topic Zero Pierce delay After pierce Only
Category: Plasmac
1. make piercing using another material config, for piercing only
2. ok
3. ok
4. start cutting with config for the material you are cutting.
30 Apr 2025 21:18
Replied by tommylight on topic Can I home X and Y axes simultaneously?
What problem?
None of the above are problems, you can set homing pretty much as you like or need or see fit.
30 Apr 2025 21:16
Replied by tommylight on topic [SOLVED]linuxcnc Latency test ambiguous results
Yes that is for parallel port only.
I have to ask, why are you messing with these settings?
What are you trying to do?
What is working and what not?
For configuration you should have asked in the Remora topic, might get better help there.
  • Daz
  • Daz
30 Apr 2025 21:15
I seem to of been wrong about converting the ST-link to DAP. I just went back and watched the video again and there were originally 2 steps in doing the conversion, but there is the post below that video - forum.linuxcnc.org/18-computer/44828-rem...rd?start=2050#321860 - that says to just use that one file?
I am now very confused and the computer says the converted ST link is an unrecognized device and it does not show up. I can not communicate with the link plugged into the USB
At this point I truly do not know what to do.
It might be easiest to buy one for a few $$ on Amazon or Ebay.
  • Daz
  • Daz
30 Apr 2025 21:14
Thank you for the quick reply.
The log you shared is from the Python script, but the important part happens on the EC300 board side.
I can do it, but I need to get hold of a USB to RS232 adapter first. Should have it next week
  • COFHAL
  • COFHAL
30 Apr 2025 20:20
Replied by COFHAL on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
I have those same servos, but the problem is that they don't measure correctly, and the circles turn out oval. How do I adjust the servos?
  • csurimilan
  • csurimilan
30 Apr 2025 20:06
How to change jog speed using joystick buttons (QtDragon + HAL)?
Category: HAL
# Xbox 360 Controller Mapping
loadusr -W hal_input -KRAL Xbox
setp halui.jog-speed 100
net jog-x-axis input.0.abs-x => halui.axis.x.analog
net jog-y-axis input.0.abs-y => halui.axis.y.analog
net jog-z-axis input.0.abs-ry => halui.axis.z.analog
# LB = Feed override -
net feed-dec input.0.btn-tl => halui.feed-override.decrease
# RB = Feed override +
net feed-inc input.0.btn-tr => halui.feed-override.increase
  • csurimilan
  • csurimilan
30 Apr 2025 19:59
Category: HAL
im using a wireless xbox controller for PC. It is working fine
  • csurimilan
  • csurimilan
30 Apr 2025 19:57 - 30 Apr 2025 19:57
  • Jedi
  • Jedi
30 Apr 2025 19:42
Replied by Jedi on topic Losing some values after PB restart
Category: QtPyVCP
I will Check again.
and let you know. Is there a terminal command to see witch version is installed?
Best regards,
Ben
  • PCW
  • PCW's Avatar
30 Apr 2025 19:24
Replied by PCW on topic LinuxCNC S-Curve Accelerations
Indeed if you set acceleration to 200, the scurve max acceleration will be 400 at inflection point.
Exceeding your max acc off 240.
I get the same error even if all accelerations are set to 100 in the ini file
  • PabloSancez
  • PabloSancez
30 Apr 2025 19:06
Replied by PabloSancez on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
Hi! This is a lathe with Lichuan Ethercat and mesa 7i96s servodrivers for controlling the spindle with a mesa digital potentiometer mesa processes three encoders, one spindle and two linear for each axis, and it seems to work fine. I was even able to thread the G76 cycle.
I use absolute encoders how do I set up the machine so that the position of the machine is automatically read from the drivers when the machine is turned on?
Displaying 5761 - 5775 out of 24150 results.
Time to create page: 0.385 seconds
