  • emresensoy
  • emresensoy
29 Apr 2025 07:05
Replied by emresensoy on topic QtPyVCP designer plugin fails
Category: QtPyVCP
I have same issue,
QT5 designer doesnt load custom linuxcnc widgets,
what should I do?
  • bkt
  • bkt's Avatar
29 Apr 2025 07:05
First time to try build my xml for not listed ethercat in-out component
Category: EtherCAT
Really situation is these: S1-M20 is a coupler based on Hishler chips as multiprotocol demux. You can set from ethercat modbus and other .... there are not a real connection from DI, DO module. Hishler chips drive the right master in module with correct register used from various protocol type. So if bus is not inizialize on Hishler, no comunication with DI DO, no pdos no sdo .... only comunication established. Need to know right inizialization sdo i think, and producer not know that because not usual with IGH. Really not sure Hishler is supported from IGH. SO for sure need to load original xml file on tiwincat, after check if usable xml is produced .... but probabily need to write a new component based on file that producer share with me. For sure that "driver" as it is write is not possible to build inside ethercat component forlder ... wrong library used and wrong structures. If someone have some suggest on these (whitout writing new component ... that become a sort of copy of one used for EL1xxx or EL2xxx) is welcome.
Real thanks for attention on these.
  • Aciera
  • Aciera's Avatar
29 Apr 2025 06:40
Replied by Aciera on topic Gmoccapy G54 Offsets
Category: Gmoccapy
What does one do if the machine cannot be physically moved to its Home position ?
For example, a large job mounted prior to machine start-up, or a vice.
It is possible to set up 'Immediate Homing' in the INI file:
www.linuxcnc.org/docs/html/config/ini-ho...ml#_immediate_homing
You could then use a probe to jog the machine to the origin of your work piece and issue MDI:
G10 L20 P0 X0 Y0 Z0
or. if you already know the offset between the machine position on startup and the work piece origin (example x:1 y:2 z:3):
G10 L2 P0 X1 Y2 Z3
Note though that without properly homing the machine (ie in reference to the physical limits of travel) you will also need to adjust the joint/axes limits.
  • Jedi
  • Jedi
29 Apr 2025 05:19
Replied by Jedi on topic Losing some values after PB restart
Category: QtPyVCP
Good Day,
What is the correct way to update ProbeBasic from a very old version?
sudo apt-get update/sudo apt-get upgrade does nothing.
Best Regards,
Ben
  • dannym
  • dannym
29 Apr 2025 03:36
Replied by dannym on topic Z axis is being controlled by A
Category: Basic Configuration
I don't know if it's a Leadshine knockoff, I got it a long time ago.
I knew Leadshine as a cheap but pretty good mfg- I never heard of any "knockoffs" of the Leadshine name.
It was a long time ago, but IIRC I ordered it straight from the mfg or at least a legit distributor.
The only thing that could matter would be if they actually wired the Z channel to DB 8/9. I did look up the manual again, Z is 6/7 and I can't imagine them just skipping it over and using 8/9, but, ok, I'll put that on the list of things to try. since it's easy- move the servo to pin 6/7 and see if it moves independently of Z.
  • dannym
  • dannym
29 Apr 2025 03:16
The DB25 is IDCs stamped on a ribbon cable. The 0.1" end plugs into P2 of the 7i92, the first DB25 goes to the 3 axis MX3660 and the cable goes on a few more inches to a DB25 that has a breakout board on it and pins 8/9 are STEP-/DIR- for a servo for the A-axis. The servo has an onboard driver. +5V is STEP+/DIR+ sourced from an RPi power pin.
  • Mother Canucker
  • Mother Canucker
29 Apr 2025 02:49
Replied by Mother Canucker on topic Tandem Y Axis in stepconf assistance.
Category: StepConf Wizard
Well I'm quite sure it has 2 limits on the gantry. I will check tomorrow and I will check if they work tomorrow. sorry for the confusion here I Rod just said read through the configuration manual.
29 Apr 2025 02:36 - 29 Apr 2025 02:39
Replied by tommylight on topic Tandem Y Axis in stepconf assistance.
Rod, why?
He did not confirm that the machine has switches on both sides yet, so why send him that way, he will end up with a mangled machine.
Then again, i wonder why is it not possible to answer such a simple question...
Again, do not set -1 to anything if you are not sure the machine has switches on both sides of the gantry and that those switches are properly wired, configured, and working.
EDIT:
You posted while i was answering, there are no home stuff set in that ini file.
  • Mother Canucker
  • Mother Canucker
29 Apr 2025 02:36
I did do what RodW said to do and from that I figured to add "HOME_SEQUENCE = -1" to the two Y motors. would there be anything else I need to add in the INI files?
Also I don't know if you want to take a look but if you do here it is
# Generated by stepconf 1.1 at Fri Apr 25 14:44:59 2025
# overwritten when you run stepconf again
[EMC]
MACHINE = 22222222222222
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = gmoccapy
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm 1in 2in 5in 10in
MAX_FEED_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_LINEAR_VELOCITY = 0.10
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 1.00
CYCLE_TIME = 0.100
INTRO_TIME = 5
PROGRAM_PREFIX = /home/probotix/linuxcnc/nc_files
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
[KINS]
JOINTS = 4
KINEMATICS = trivkins coordinates=XYYZ kinstype=BOTH
[FILTER]
PROGRAM_EXTENSION = .nc,.tap G-Code File
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
BASE_PERIOD = 100000
SERVO_PERIOD = 1000000
[HAL]
HALFILE = 22222222222222.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
[TRAJ]
COORDINATES = X Y Y Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
#*** AXIS_X *******************************
[AXIS_X]
MAX_VELOCITY = 1.0
MAX_ACCELERATION = 30.0
MIN_LIMIT = -0.01
MAX_LIMIT = 8.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.01
MAX_LIMIT = 8.0
MAX_VELOCITY = 1.0
STEPGEN_MAXACCEL = 37.5
SCALE = 8000.0
FERROR = 0.05
MIN_FERROR = 0.01
HOME_OFFSET = 0.0
#*** AXIS_Y *******************************
[AXIS_Y]
MAX_VELOCITY = 1.0
MAX_ACCELERATION = 10.0
MIN_LIMIT = -0.01
MAX_LIMIT = 8.0
[JOINT_1]
HOME_SEQUENCE = -1
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.01
MAX_LIMIT = 8.0
MAX_VELOCITY = 1.0
STEPGEN_MAXACCEL = 12.5
SCALE = 4000.0
FERROR = 0.05
MIN_FERROR = 0.01
HOME_OFFSET = 0.0
[JOINT_2]
HOME_SEQUENCE = -1
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.01
MAX_LIMIT = 8.0
MAX_VELOCITY = 1.0
SCALE = 4000.0
FERROR = 0.05
MIN_FERROR = 0.01
HOME_OFFSET = 0.0
#*** AXIS_Z *******************************
[AXIS_Z]
MAX_VELOCITY = 1.0
MIN_LIMIT = -4.0
MAX_LIMIT = 0.01
[JOINT_3]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -4.0
MAX_LIMIT = 0.01
MAX_VELOCITY = 1.0
SCALE = 8000.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
  • Mother Canucker
  • Mother Canucker
29 Apr 2025 02:23
Ok so what im getting is that if two joints have a HOME_SEQUENCE = -1 then that tells the two motors to run together right?
29 Apr 2025 01:39
Replied by tommylight on topic [SOLVED]linuxcnc Latency test ambiguous results
No, not yet.
Now is that point where you upload your configuration files here so we can have a look, joint errors are usually miss configuration on stepper systems.
What board are you using?
  • Soccer Kid
  • Soccer Kid's Avatar
29 Apr 2025 00:42
Replied by Soccer Kid on topic General Questions about using ethercat
Category: EtherCAT
Please check your ethercat.xml file to see if it contains this pin. Similar to...... <pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="cia-controlword" halType="u32"/>
  • DarkPhoinix
  • DarkPhoinix
29 Apr 2025 00:13 - 29 Apr 2025 01:03
Replied by DarkPhoinix on topic [SOLVED]linuxcnc Latency test ambiguous results
Junction error 1: This error only occurs when I watch YouTube videos. With only LinuxCNC running and CPU stress test (and rustdesk remote desktop), the job runs without errors until the end.
this is the end of my machine?
  • langdons
  • langdons
28 Apr 2025 23:55
Replied by langdons on topic Z axis is being controlled by A
How are you controlling 4 axes with a 3-axis driver?
28 Apr 2025 23:39
Replied by tommylight on topic Gmoccapy G54 Offsets
Category: Gmoccapy
OK then, feel free to poke around, you are always welcomed.
I was thinking you have some non standard stuff or end result, hence my jumping in.
Thank you.
Displaying 6001 - 6015 out of 24099 results.
Time to create page: 0.300 seconds
