  • Aciera
  • Aciera's Avatar
01 Jul 2025 13:08
Wait for spindle-halt signal before reversing spindle direction
Category: Basic Configuration
Is there a built-in way in LinuxCNC to delay or block a direction change until this signal becomes active? Or do I need to handle this myself, for example using HAL logic or some custom component?
I'm not aware of a built in solution but this could certainly be handled using HAL logic (or a custom component)
  • langdons
  • langdons
01 Jul 2025 13:04
Replied by langdons on topic Puesta a tierra
Puesta a tierra
Good power supplies have an internal EMI filter.
In your case, probably keep the power supplies isolated.
Power supplies often have a high inrush current, which could blow your 13A fuse.
  • hellvetica
  • hellvetica
01 Jul 2025 11:54
Robot reads the same position every time it is turned on.
Sorry, i realised i didn't upload the correct .hal file
  • Daan96
  • Daan96
  • Daan96
  • Daan96
01 Jul 2025 08:31
Building a 3-axis plasma table with mesa 7i96s, THCad-2 and nema23 steppers
Category: Show Your Stuff
Slowly all components are coming in to be able to build the control cabinet.
For the drive I have ordered pulleys of 12 teeth to do a test with direct drive.
If this does not work well I will switch to a transmission.
  • Hakan
  • Hakan
01 Jul 2025 08:13
Replied by Hakan on topic General Questions about using ethercat
Category: EtherCAT
The line
setp cia402.0.csp-mode 1
should make the cia402 put the drive in csp-mode.
OP is required but not enough. For cia402 drivers, they have their own states on top of OP.
The drive needs to be in stat-op-enabled to start moving.
Easiest is to use halshow and navigate to pins,cia402,0 to check the values from the component.
  • workshop54
  • workshop54
01 Jul 2025 06:38
Hi all,
I have a setup where the spindle drive provides a spindle-halt signal when the spindle has fully stopped. I’d like to make sure LinuxCNC does not reverse the spindle direction (i.e. switch between M3 and M4) until this spindle-halt signal is true.
Curious to hear how others have tackled this.
Thanks in advance.
  • Johnnysacalu
  • Johnnysacalu
01 Jul 2025 05:35 - 01 Jul 2025 05:42
Replied by Johnnysacalu on topic Puesta a tierra
Puesta a tierra
Lo que tengo es esto
Con otro plasma “stamos 125h cnc” con 4 motores paso a paso cada uno con su fuente de alimentación eje z 36v y los demas 60v. Tengo una fuente que me da 5v 12v 24v que alimenta la mesa 7i96s con 5v y los finales de carrera  ESTOP con 24v esta si tiene los mismos negativos y el thc se alimenta de la tarjeta como en el diagrama.
Tengo cables blindados que que están conectados en una sola punta dentro de la caja de controles a un bussbar y de allí va a la tierra de la red AC.
Os explico, mi problema  es que la maquina funciona y corta bien hasta que le pongo el thc “sin configurar ni escala gain ni nada por que en pncconf no me sale para configurarlo y .hal y .ini seme dan muy mal lo intente pero siempre acabo con errores” y me quema el U5 o U7 no se si los dos o solo uno yo cambie los dos y la maquina vuelve a funcionar busque cortocircuito pero no encontre nada asi que pense que seria por la tierra EMI y todo eso
edit:  uso qtplasmac modo 0
  • Johnnysacalu
  • Johnnysacalu
01 Jul 2025 04:39
Replied by Johnnysacalu on topic Lo ejes dejaron de moverse
Gracias le quite el ahorro de energía de bios y ya no aparece.
tambien gracias por decirme lo de la U5 y U7 los cambie y ayer ya estaba cortando otra vez. Asi que problema resuelto
  • Ac1dburn
  • Ac1dburn
01 Jul 2025 02:09
That was it. removed the 0's before the single digit numbers in the hal and it launched as expected. Awesome. Thank you. also, limit switches are triggering as expected now in halshow.
01 Jul 2025 01:47
  • cakeslob
  • cakeslob
01 Jul 2025 01:04
i think we forgot to update the component for the 00.input,
change your inputs to 0.input or 1.input. also the inputs dont go up to 27
  • psy
  • psy
30 Jun 2025 22:44
Flying Probe ATG A5 Not Connecting Message
Hello, Im having some issues with a A5 Neo that cannot connect to the linux unit,doesnt load/find the required file, does anyone have any ideas of what could or shoud I try ?
  • Ac1dburn
  • Ac1dburn
30 Jun 2025 22:05
removed all the remora components/ modules from the Pi. halcompile only the remora_lpc.c module from the directory you showed after I re-cloned it onto the Pi (This is what I had already had installed, I basically re-installed/ compiled it)
tried to boot and watch the serial debug and it did the same thing as before.
Displaying 676 - 690 out of 25325 results.
Time to create page: 0.437 seconds
