  • PCW
  • PCW's Avatar
02 Nov 2025 15:53
Mesa sserial cards combination for 3 analog servos + I/O
Category: Driver Boards
You would need an encoder interface as well (7I85,7I85S,7I89)
Might be simpler/cheaper to use a 7I97T
  • kostas
  • kostas's Avatar
02 Nov 2025 15:36
I'm looking at the Mesa cards available now for driving 3 servos with +/-10V and thinking to go with a 7I94T, one 7I83 for the servo drives and one 7I84U for various I/O like limits and buttons. Since I have not worked with this combination before, I would like your input if this is going to work. Are one of these ready made firmwares going to work, or I will need to create a new one (I have done it more than 10 years ago for creating a custom one for a 5i22, but not sure what I did back then  )
7i94t_16m_fallback.bin
7i94t_5abobd.bin
7i94t_7i74_ss_bissd.bin
7i94t_7i74_ss_bissd.pin
7i94t_7i74ssd.bin
7i94t_7i74ssd.pin
7i94t_7i76d.bin
7i94t_7i77d.bin
7i94t_7i85sd.bin
7i94t_7i89d.bin
7i94t_7i89d.pin
7i94t_bissd.bin
7i94tss_bissd.bin
7i94tss_bissd.pin
7i94t_ssd.bin
7i94t_ssid.bin
  • sparviero
  • sparviero's Avatar
02 Nov 2025 15:02
Replied by sparviero on topic EtherCAT with OMRON R88D-1SN servo drive
Category: EtherCAT
Hello again,
just a little update. On the repository i have added more information about current configuration but still a lot of work need to be done. Unlikely I have only one motor so i can't scale along 3 axes.
I have also updated a video on YouTube.
Next steps are:
  • resolve joint 0 amplifier fault when toggle machine power. This seems to happen only one time after LinuxCNC opening.
  • run and understand LinuxCNC / HAL Latency Test for a better configuration of LinuxCNC
  • set machine configuration parameters like: encoder resolution, velocity, acceleration, pitch of leadscrew...
  • implement PID control
  • customizing using PyVCP
  • DerKlotz
  • DerKlotz
  • Grandberg
  • Grandberg
02 Nov 2025 13:51
7i97T stepgen outputs dead, encoders & I/O OK - suspect damaged P2 interface
Thank you for the contact of the Eusurplus store. They responded instantly at any time of day, shipped quickly, and everything arrived quite fast — from Portugal to Bulgaria in just one day! Although people in Bulgaria aren’t the fastest, and local delivery took another three days, that’s a minor thing — plus there were weekends — still much faster than waiting for a shipment from the U.S. I’ve connected everything, and it’s all working now. I got a 7i95 board to replace my 7i97, so I can connect the motors directly in stepper mode. Now all that’s left is fine-tuning the machine’s logic.
  • PCW
  • PCW's Avatar
02 Nov 2025 13:40
MESA 7i76eu – I/O - Spannungsversorgung
Category: Deutsch
The drive manual shows that the alarm output is an optocoupler
This can connect directly to the 7I76UE field inputs
+24V --> ALM+
ALM- --> 7I76EU field input
  • Hakan
  • Hakan
02 Nov 2025 13:33
Ethercat, Canopen over Ethercat Lichuan Cl57E
Category: EtherCAT
Interesting concept, one driver supports 4 motors.
No problem with Canopen over ethercat. It is actually required for the device to use
Canopen over ethercat, CoE with linuxcnc. So all devices use it even the Beckhoffs.
No problem with coexistance.
There is no specific driver for the 57E but since it almost certainly is a cia402 drive there is a general driver to use.
The only a bit unique thing is to figure out the PDOs for motor 2, 3 and 4.
Can be done from the manual or from the drive itself.
02 Nov 2025 13:32
Replied by tommylight on topic MESA 7i76eu – I/O - Spannungsversorgung
Category: Deutsch
Mesa 7i76 should have 4 analog inputs (do check if EU has) that you can use for amplifier fault at 5V, but it will require some HAL editing.
Should be field inputs 0-3
  • kor
  • kor
02 Nov 2025 13:14
Category: EtherCAT
i like to build a new control cabinett for my cnc machine. based on ethercat.
I am currently in the planing stage. I think the Lichuan CL57E are a great fit since from what I can read they can already do prettymuch everything I need. upto 4 closed loop stepper and tons of DIO.
de.aliexpress.com/item/1005009644510600.html
My problem is that it says it is canopen over ethercat. Does that mean other ethercat devices also need to be canopen? Or can I just connect my Beckhoff EK1100 and my servodrive to the same ethercat line?
Are there already drivers for lichuan ethercat devices?
Thanks for your help
  • 2tinker
  • 2tinker
02 Nov 2025 13:02
Replied by 2tinker on topic MESA 7i76eu – I/O - Spannungsversorgung
Category: Deutsch
Meinst du ein mechanisches Relay?
  • kate
  • kate
02 Nov 2025 12:44
RaspberryPi 4/5 Ethercat Rtelligent ECT60 Synchronization error
Category: EtherCAT
I maintained series cabling, switch is just between rpi and first ECT60. Only purpose for switch was isolate Ethernet disconnect to side or other. After adding switch i cant see ethernet disconnect messages in rpi kernel logs any more. I am having RTT60V202 versions.
Identity:
  Vendor Id:       0x00000a88
  Product code:    0x0a880002
  Revision number: 0x00000202
  • rodw
  • rodw's Avatar
02 Nov 2025 11:45
Replied by rodw on topic motion.so not found error ...
Review this working hal file against yours
github.com/rodw-au/showstopper/blob/master/my_Plasma.hal
nowhere is there a loadrt motion command
  • rodw
  • rodw's Avatar
02 Nov 2025 11:30
Replied by rodw on topic Any progress on QTLazerC or
Category: Other User Interfaces
Hypersening allows you to probe surface so quick its scary, I use Hypersensing to set tool height offsets on my router had to modify the g38s with digita on offs to stop the probing erros i think theorically it is the most accurate method with known physics.
Interesting feedback but may not be relevant here. Any switch or relay introduces hysteresis. Switches have hysteresis from physical travel mechanical relays add delays from contact travel, even digital relays have hysteresis between their on and off voltages eg turn on at 15 volts and off at 5 volts. Hypersening on the other hand uses moving averages and eliminates hysteresis because it is triggered at a voltage threshold you set and turns off as soon as the voltage is trending downwards hence your scary probing times!
  • Hakan
  • Hakan
02 Nov 2025 11:22
Help with Inovance IS620N Servo Drive - Stays in PREOP
Category: EtherCAT
You need to add the vid and pid item in the <slave line.
You find the numbers with "ethercat slaves -v"
  • lorenzing
  • lorenzing
02 Nov 2025 10:06
Replied by lorenzing on topic Festo CMMT-ST
Festo CMMT-ST
Category: EtherCAT
Thank you so much, now looks good.
Can someone help me with "setp cia402.X.pos-scale 3600" value?
I've this type of motor with the same encoder: EMMB-ST-87-M-SM (X), EMMB-ST-87-M-SMB (Z1,Z2,Y1,Y2).
Z1, Z2 5mm/rev; X, Y1, Y2 180mm/rev.
Displaying 76 - 90 out of 22545 results.
Time to create page: 0.567 seconds
