27 Jun 2025 21:44
Replied by tommylight on topic Blow back plasma torch start timing problem
Category: Plasma & Laser
Should be done in CAM, not in LinuxCNC.
Seems strange to do that on every cut, although i had a Hypertherm that would need a bit of a pause only on short cuts, but 3 sec. max. so i added that to Inkscape.
  • langdons
  • langdons
27 Jun 2025 21:42
Replied by langdons on topic Blow back plasma torch start timing problem
It is almost certainly pssible, but probably not particularly easy to set up.
Why did you decide to switch from Mach 3 to LinuxCNC?
27 Jun 2025 21:40
Replaced Hard drive - now my 'fast move' (SHIFT->arrow |PgUp/PgDn is not working
Set the HOME_FINAL_VELOCITY to something smaller.
If they are not in the ini file, add them for each joint.
  • irwinger
  • irwinger
27 Jun 2025 21:32
I'm not sure if you were asking me to upload a video to YouTube showing what is happening - but that's what I did. The video link is here:
youtube.com/shorts/D5WTf5WWpfo
It's very hard to 'see' or hear - but as part of the homing function, the axis slowly approaches the limit switch, then moves away, then back and finally 'jumps' away from the switch.
I tried changing the MAX_ACCELERATION setting in the .INI - in both the AXIS_X and JOINT_0 sections. I halved them but it made no difference. I also attempted to move the sliders at the bottom of the LinuxCNC screen (below the jog section) way down one at a time - but that made now changes.
If I try to run even a simple shape (gcode for a small rectangle) it just 'locks up' like you see in the video when I attempt to press the 'SHIFT-(any arrow).
I'm just buffalo'd - I cannot figure it out.
Arden
  • pscott
  • pscott
27 Jun 2025 19:42
Hi All,
I am in the process of converting our workshop homebuilt plasma table from MACH3 to LinuxCNC.
So far all the basic things work except for the plasma torch timing. The particular torch & inverter we have
needs a minimum of 15 second delay from the end of one cut to the start of the next. In MACH3 we have a
M3 macro that takes care of that. Is there a feature in QtPlasmaC / plasmac that can do something similar.?
I can do it using the retry logic - but that usually wastes a lot of time between cuts.
Scott.
  • atrex77
  • atrex77's Avatar
27 Jun 2025 19:41
W5100S-EVB-PICO stepgenerator and encoder driver
Category: Driver Boards
The expansion board is "plan to sell it" but the prototypes is in making, so its need more time.
  • lex200
  • lex200
27 Jun 2025 17:44
Issue with Inverse Kinematics Failing During Homing – 3-Axis Robot with LinuxCNC
Category: HAL
Well, you were right. I had to use the modified parameters in the DH method.
  • cmorley
  • cmorley
27 Jun 2025 16:08
[qt_dragon_hd] auto tool probe and gcode display issue
Category: Qtvcp
What version of linuxcnc are you using?
Can you post your config files?
  • Aciera
  • Aciera's Avatar
27 Jun 2025 15:02 - 27 Jun 2025 18:04
Replied by Aciera on topic Referenzierungs Fehler
Category: Deutsch
Nein, bei der Y achse ist die HOME_SEARCH_VELOCITY negativ:
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = -5.000000
HOME_LATCH_VEL = -0.500000
HOME_FINAL_VEL = 2.000000
Das Problem mit den Limiten wird aber erst sichtbar werden, wenn die Achsen erfolgreich referenziert sind.
Für das eigenliche Referenzieren ist wichtig, dass 'joint.n.home-sw-in' False ist wenn der Referenzschalter nicht aktiviert ist.
  • Edi_48
  • Edi_48
27 Jun 2025 14:45
Replied by Edi_48 on topic Referenzierungs Fehler
Category: Deutsch
Verstehe ich nicht bei der Y Achse habe ich die selben Einstellungen
  • Aciera
  • Aciera's Avatar
27 Jun 2025 14:07 - 27 Jun 2025 14:10
Category: Deutsch
Deine Einstellungen widersprechen sich.
HOME_SEARCH_VEL = 3.0000000
bedeuten, dass der Referenzschalter am positiven Ende der X Achse angebracht ist.
Wenn das so ist dann müssten aber
MIN_LIMIT = -315
MAX_LIMIT  = -0.1
HOME =  -10
  • JT
  • JT's Avatar
27 Jun 2025 12:54
Axis view options are not persistant between sessions. Any thoughts?
Category: AXIS
When I open the axis sim the units are inch, when I open the axis_mm sim the units are mm.
In the [TRAJ] section of axis the LINEAR_UNITS are inch and in the axis_mm the LINEAR_UNITS are mm.
JT
  • djones@burketruck.com
27 Jun 2025 12:13
Replied by djones@burketruck.com on topic Probe Basic Not Remembering Current Pocket Number
Category: QtPyVCP
I was able to get the spindle torque figured out. This is how I did it:
loadrt scale names=spindle_load_scale,spindle_rpm_scale
setp spindle_load_scale.gain 10
setp spindle_load_scale.offset 0
net spindle-torque nyx.0.servo-05.trq-fb => spindle_load_scale.in
net spindle-load spindle_load_scale.out => qtpyvcp.spindle-load-indicator.in-f
setp qtpyvcp.spindle-load-indicator.max-val 150
setp qtpyvcp.spindle-load-indicator.min-val 0
  • Edi_48
  • Edi_48
27 Jun 2025 08:24
Referenzierungs Fehler was created by Edi_48
Category: Deutsch
HalloIch habe eine Problem mit  der Referenzierung meiner X Achse.Z und Y fahren richtig , die X-Achse fährt auf den Schalter bleibt kurz stehen und fährt dann in die selbe Richtung.   Egal ob die Vorzeichen bei Home_latch_vel   in minus oder plus mache . Wenn ich Manuel  in die richtige Richtung fahre  ich ins Minus.Anbei meine Einstellungen in der ini.
[AXIS_X]
MAX_VELOCITY = 166.666666667
MAX_ACCELERATION = 1000.0
MIN_LIMIT = 0.1
MAX_LIMIT = 315
[JOINT_0]
TYPE = LINEAR
HOME = 10.0
FERROR = 10.0
MIN_FERROR = 1.0
STEPGEN_MAXVEL = 180
STEPGEN_MAXACCEL = 1500
# these are in nanoseconds
DIRSETUP   = 2500
DIRHOLD    = 2500
STEPLEN    = 2500
STEPSPACE  = 2500
STEP_SCALE = 640
MIN_LIMIT = 0.1
MAX_LIMIT = 315
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS=yes
HOME_SEQUENCE = 1
 mfg
Hilton
  • nieyinsheng@gmail.com
27 Jun 2025 08:20
Replied by nieyinsheng@gmail.com on topic NVEM V5 LINUXCNC REMORA FIRMWARE[SOLVED]
Hello, friend. First of all, congratulations on successfully using NVEM V5 on linuxcnc.
I have the same control card as yours, but I read scotta's reply and read the 230 pages, but still can't find a solution, and I don't see a complete process. Can I ask for your help?
Displaying 826 - 840 out of 25292 results.
Time to create page: 0.208 seconds
