  • Waldemar
  • Waldemar's Avatar
26 Aug 2026 09:32 - 26 Aug 2026 09:42
GrooveCam was created by Waldemar
GrooveCam
Category: Show Your Stuff
Hello all.
Just thought I'd share this little app I had ChatGPT write for me.  In a nutshell - it generates GCode for side operations on a standing cylinder using a lollipop style of cutter when you don't have a rotary axis available.  It's fairly limited in scope, but may prove useful from time to time.  True G2/G3 helices too.  I'll add some more features as and when.
groovecam.smallscalecnc.co.uk
  • MarkoPolo
  • MarkoPolo
26 Aug 2026 08:39
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
Yes, I tested it and it works fine.
Thanks for reporting the issue.
  • meister
  • meister
26 Aug 2026 07:49
Replied by meister on topic Xilinx Zynq 7010 fpga crypto windfall boards
Category: Driver Boards
nice, it's time to build an addon board with IO's :)
  • murdemon
  • murdemon
26 Aug 2026 07:48 - 26 Aug 2026 07:49
Replied by murdemon on topic Xilinx Zynq 7010 fpga crypto windfall boards
It all working now. Have to change tri-state block in vivad. Will be update on cloud project Vivado and so on
  • cmorley
  • cmorley
26 Aug 2026 00:12
Replied by cmorley on topic Error in tool_offsetview.py
Category: Qtvcp
This should be fixed in master now.
Another Dev figured it out quick!
  • PCW
  • PCW's Avatar
25 Aug 2026 22:41
If the driver does not find a Sserial remote, it reverts the pins to GPIO
so that's expected if there is no remote connected/discovered.
  • think_j
  • think_j
25 Aug 2026 20:10
Replied by think_j on topic Hydraulic press brake control
Category: CNC Machines
Hi, kind of a late message but I am in the process of retrofitting an old hydraulic press brake. Currently, I'm looking to buy a hydraulic proportional valve for the cylinder. Do you have any tips for this purchase? I really appreciate any advice. I am a bit intimidated by this project.
  • PCW
  • PCW's Avatar
25 Aug 2026 18:36 - 25 Aug 2026 22:36
7i95T PktUART: no usable TX output with either official bitfile
I've gone through the parity options before but Its been a while
That said, I have not seen  any other parity complaints,
I can try and duplicate this sometime this week but I think it's something more basic.
Edit:
Just tried the GS10 at 8E1 (still 38400 baud) and it works as expected on master.
  • Otatiaro
  • Otatiaro
25 Aug 2026 17:28
  • PCW
  • PCW's Avatar
25 Aug 2026 17:21
Unlikely, The V2 firmware does not support 2 stop bits and it runs the same
(the driver complains that it cannot set 2 stop bits so drops back to 1 stop bit)
I can try the same setup with 1 stop bit but I doubt that's the issue
  • Logthor
  • Logthor
25 Aug 2026 17:16
Replied by Logthor on topic Breakout Board Speed Control
Category: Basic Configuration
Alright, fair enough. I've already purchased a separate supply and a PWM to analog converter. I'll just use the pot on the board to make it send out a max of 7 volts and use the basic stepconf to set up the spindle RPM.
  • Otatiaro
  • Otatiaro
25 Aug 2026 17:11
Hello,
I just checked your zip and the only real difference is you use 8N2, I need 8E1 (and 38400 vs 19200bps).
Could that be the problem ?
Thanks !
  • tuxcnc
  • tuxcnc
25 Aug 2026 16:23
Replied by tuxcnc on topic Breakout Board Speed Control
So I need a separate power supply for this converter?
If a device is not isolated from the power grid, it may cause fatal shock, damage to the electronics or its incorrect operation.
What's worse, it all depends on which wire you connect where.
The machine can operate safely and without failure for years, and when connected to another wall socket, it may burn itself or kill the operator.
To prevent this from happening, all you need to do is spend a few dollars more on an already expensive machine.
I really don't know what to discuss here...
  • trackwhack
  • trackwhack
25 Aug 2026 16:22
Replied by trackwhack on topic Thank You!
Thank You!
Understood, apologies for hijacking.
Kind Rgds.
George
25 Aug 2026 15:58
Replied by tommylight on topic Thank You!
Thank You!
This is an open source project and subsequently open source forum, so anything proprietary does not have a place here, as noted by the lack of such section on this forum.
You can show it on the "show your stuff" section, but you must also note the pricing and license terms and conditions, you might also add the link to it, but beware that if that link points to anything remotely suspicious you will be banned, meaning no tracking scripts, no loggers, no permanent cookies, and no collecting user information without their prior consent.
As for free licenses, if anyone is interested you can sort that there, not privately, no private messaging on this forum.
I am sure i do not want anything licensed, but thank you for the offer.
Displaying 1081 - 1095 out of 12957 results.
Time to create page: 0.526 seconds
