  • john.obrien
  • john.obrien
02 Nov 2025 19:09
A suggestion for the 7i76 documentation was created by john.obrien
Category: Driver Boards
I am looking to try to wire a Gecko G320x to the 7i76U. I found this diagram , which I am planning on using to complete the wiring.
Now, in the manual , there is a diagram of the board on page 3 and a list of the pins ordered by DB25 pin on page 4. The layout of the diagram and pins ordered by DB25 is not as helpful as the diagram I alluded to which another user created.
I have another BOB from CNC4PC, the C11G. In its  documentation  on page 18 you can the pins are labeled on the board diagram making it much easier to figure out which pins to use to wire a stepper/servo driver to the board.
@PCW, after some googling, I believe you are the owner of Mesa Electronics. Is that correct?
If so, I'd like to humbly suggest updating your documentation for the 7i76U to include something like the diagram I found on the forum to make it easier for people to figure out the pins for the 7i76U.
  • conman
  • conman
02 Nov 2025 19:03
Help with Inovance IS620N Servo Drive - Stays in PREOP
Category: EtherCAT
Hello, thank you for that, I added it but still the same result.
<masters>
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
<slave idx="0" type="generic" name="IS620N_ECAT_v2.6.8" vid="0x00100000" pid="0x000C0108" configPdos="true">
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
<syncManager idx="2" dir="out">
<pdo idx="1701">
<pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="cia-controlword" halType="u32"/>
<pdoEntry idx="6060" subIdx="00" bitLen="8" halPin="OperationMode" halType="s32"/>
<pdoEntry idx="607A" subIdx="00" bitLen="32" halPin="TargetPosition" halType="s32"/>
<pdoEntry idx="60FF" subIdx="00" bitLen="32" halPin="TargetVelocity" halType="s32"/>
</pdo>
</syncManager>
<syncManager idx="3" dir="in">
<pdo idx="1b01">
<pdoEntry idx="6041" subIdx="00" bitLen="16" halPin="cia-statusword" halType="u32"/>
<pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="ActualPosition" halType="s32"/>
<pdoEntry idx="6061" subIdx="00" bitLen="8" halPin="ActualOperationMode" halType="s32"/>
<pdoEntry idx="606C" subIdx="00" bitLen="32" halPin="ActualVelocity" halType="s32"/>
<pdoEntry idx="6077" subIdx="00" bitLen="32" halPin="ActualTorque" halType="s32"/>
</pdo>
</syncManager>
</slave>
</master>
</masters>
  • CADdy
  • CADdy's Avatar
02 Nov 2025 17:16
Replied by CADdy on topic mqtt-publisher
mqtt-publisher
yes, you are right. I'll do it.
  • snowgoer540
  • snowgoer540's Avatar
02 Nov 2025 17:11
Replied by snowgoer540 on topic Laser Button Doesn't toggle to mark edge and origin
Category: Plasmac
To close the loop here, this commit (to the Master branch) clarifies when the LASER and CAMERA buttons become visible:
github.com/LinuxCNC/linuxcnc/commit/ce1e...442d1e9b634e2eb8c5a7
  • unknown
  • unknown
02 Nov 2025 17:09
Replied by unknown on topic mqtt-publisher
mqtt-publisher
Like I said it may be worth raising an issue on GitHub as the actual behaviour does not match the behaviour in the docs.
  • CADdy
  • CADdy's Avatar
02 Nov 2025 16:37 - 02 Nov 2025 16:44
mqtt-publisher
With your settings, I only receive 7 values.
After removing the axes and joints that are not present on my milling machine, the result is the same - only 7 values are received. Sorry, I don't understand the principle of keys entries.
I have now shortened the list to 9 entries and am only using one key= statement. This allows me to transfer all 9 values.
loadusr -W mqtt-publisher \
--mqtt-broker=[MQTT]BROKER --mqtt-user=[MQTT]USERNAME \
--mqtt-password=[MQTT]PASSWORD \
keys=halui.axis.x.pos-relative,halui.axis.y.pos-relative,halui.axis.z.pos-relative,\
halui.joint.0.is-homed,halui.joint.1.is-homed,halui.joint.2.is-homed,\
halui.estop.is-activated,halui.machine.is-on,halui.program.is-running \
Peter
  • Aciera
  • Aciera's Avatar
02 Nov 2025 16:25 - 02 Nov 2025 16:32
Try to activate Gladevcp with setp gladevcp -> Linuxcnc
Category: GladeVCP
1. usually a good idea to post the files
2. start your config from a terminal ($ linuxcnc) and check output for clues
3. I would recommend using a simple texteditor to edit the files not a word processor like the one in your screen shot.
  • PCW
  • PCW's Avatar
02 Nov 2025 16:15
Mesa sserial cards combination for 3 analog servos + I/O
If you are on the US, mesaus has some.
if in the EU, eusurplus shows stock
We will have more 7I97T stock in 7-8 weeks
  • kostas
  • kostas's Avatar
02 Nov 2025 16:11
Right! Well, I was sure as I wrote this that the 7I83 also has encoder inputs as well!
7i97T here says it's out of stock though:
store.mesanet.com/index.php?route=produc...t_id=397&search=7i97
Do you know when are you going to have it back in stock?
Also, on the previous subject, if I decided to go the sserial route adding e.g. a 7I85, is one of the stock firmwares going to work without modifications?
  • gardenweazel
  • gardenweazel's Avatar
02 Nov 2025 16:08
Motor Driver Electrical Question was created by gardenweazel
Category: Basic Configuration
Hello All,
I am currently driving my stepper motors via DMT556T's with a 48vdc source.
The motors are from Stepper-Online model 23HS45-4204S .
They can handle 4.2A based on the specs provided.
The current settings offered by the DMT556T are as follows:
My question, which Peak Current setting should I be using?
  • PCW
  • PCW's Avatar
02 Nov 2025 15:53
You would need an encoder interface as well (7I85,7I85S,7I89)
Might be simpler/cheaper to use a 7I97T
  • kostas
  • kostas's Avatar
02 Nov 2025 15:36
I'm looking at the Mesa cards available now for driving 3 servos with +/-10V and thinking to go with a 7I94T, one 7I83 for the servo drives and one 7I84U for various I/O like limits and buttons. Since I have not worked with this combination before, I would like your input if this is going to work. Are one of these ready made firmwares going to work, or I will need to create a new one (I have done it more than 10 years ago for creating a custom one for a 5i22, but not sure what I did back then  )
7i94t_16m_fallback.bin
7i94t_5abobd.bin
7i94t_7i74_ss_bissd.bin
7i94t_7i74_ss_bissd.pin
7i94t_7i74ssd.bin
7i94t_7i74ssd.pin
7i94t_7i76d.bin
7i94t_7i77d.bin
7i94t_7i85sd.bin
7i94t_7i89d.bin
7i94t_7i89d.pin
7i94t_bissd.bin
7i94tss_bissd.bin
7i94tss_bissd.pin
7i94t_ssd.bin
7i94t_ssid.bin
  • sparviero
  • sparviero's Avatar
02 Nov 2025 15:02
Replied by sparviero on topic EtherCAT with OMRON R88D-1SN servo drive
Category: EtherCAT
Hello again,
just a little update. On the repository i have added more information about current configuration but still a lot of work need to be done. Unlikely I have only one motor so i can't scale along 3 axes.
I have also updated a video on YouTube.
Next steps are:
  • resolve joint 0 amplifier fault when toggle machine power. This seems to happen only one time after LinuxCNC opening.
  • run and understand LinuxCNC / HAL Latency Test for a better configuration of LinuxCNC
  • set machine configuration parameters like: encoder resolution, velocity, acceleration, pitch of leadscrew...
  • implement PID control
  • customizing using PyVCP
  • DerKlotz
  • DerKlotz
  • Grandberg
  • Grandberg
02 Nov 2025 13:51
7i97T stepgen outputs dead, encoders & I/O OK - suspect damaged P2 interface
Thank you for the contact of the Eusurplus store. They responded instantly at any time of day, shipped quickly, and everything arrived quite fast — from Portugal to Bulgaria in just one day! Although people in Bulgaria aren’t the fastest, and local delivery took another three days, that’s a minor thing — plus there were weekends — still much faster than waiting for a shipment from the U.S. I’ve connected everything, and it’s all working now. I got a 7i95 board to replace my 7i97, so I can connect the motors directly in stepper mode. Now all that’s left is fine-tuning the machine’s logic.
Displaying 11596 - 11610 out of 12855 results.
Time to create page: 2.922 seconds
