  • ihavenofish
  • ihavenofish
24 Oct 2025 00:16
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
thanks
soooon
All squared up, few more mechanical things to do, and then a bit of electrical and getting linuxcnc to use modbus spindle control.
  • unknown
  • unknown
24 Oct 2025 00:05
  • SPH
  • SPH's Avatar
23 Oct 2025 23:55 - 23 Oct 2025 23:57
Help with Delta E3 Ethercat drives - hal and ethercat-conf.xml
Category: EtherCAT
I've found a setup on the forums using Leadshine EL8 drivers and trying to work from there. Setup I'm following.
I've attached the hal, ini and ethercat.xml files. It doesn't load, I get the following error.
Debug file information:
Note: Using POSIX realtime
./EL8_machine.hal:42: Pin 'lcec.0.3.cia-statusword' does not exist
14897
Stopping realtime threads
Unloading hal components
Not surprising as I've pruned the file down from 5 drives and a spindle to 1, different brand drives etc.
I've used the xml file that I generated.
Am I on the right track at all?[/code][/url]
  • f355
  • f355's Avatar
23 Oct 2025 22:48
Replied by f355 on topic Update LinuxCNC 2.9.5 on debian 13
Category: Installing LinuxCNC
well, I got totally nerd-sniped by this, so here we go: github.com/LinuxCNC/linuxcnc/pull/3587
  • Cooped-Up
  • Cooped-Up
23 Oct 2025 22:44
Replied by Cooped-Up on topic Maho MH800e Retrofit Project
Category: Milling Machines
Hit another little snag with the homing. I have it set up for index homing. I have the call out in the hal to enable it but in the halmeter I was trying to catch it hit the index but nothing popped up on the scope. I'm not sure if it is indicative of hitting the index but the x axis is very close to where it is home and each time I hit the home button it jogs either way towards it but then faults out with two "cannot unhome while homing" errors and usually a "joint0 following error." If I understand the following error that means it is not where the computer thinks it should be? I am considering bringing my actual oscilloscope out to the garage to watch the signal if I can't figure it out.
  • SPH
  • SPH's Avatar
23 Oct 2025 21:52
Category: EtherCAT
Ok, I feel a bit lost on how to proceed with actually getting my drive connected in HAL.
My previous machine was using MESA hardware and pncconf did most of the heavy lifting, at least giving me a working hal and ini file to work from. As it is I'm struggling to find good tutorials or videos online that actually spell out how to get an axis drive connected and a motor moving. The one video I found (showing a full setup from scratch) gets to the cia402 stage and just says "I wont go into detail on the cia402 setup" and then just shows a moving motor... which makes me think I'm missing something really obvious.
  • Hakan
  • Hakan
23 Oct 2025 21:32 - 23 Oct 2025 21:33
torch moving UP when it should be moving DOWN
Category: Plasmac
You can also follow the signal into the plasmac component.
​​​​plasmac.move_up and plasmac.move_down should be the same as your digital inputs.
If you want to see what the plasmac component does, it is only some 20 lines of code
github.com/LinuxCNC/linuxcnc/blob/master...s/plasmac.comp#L1911
the led up and led down reflect the move_up and move_down input to plasmac.
Can help to isolate the problem.
23 Oct 2025 21:14
Replied by tommylight on topic torch moving UP when it should be moving DOWN
Category: Plasmac
-Turn OFF the plasma
-draw a circle in the wizard, some 10cm diameter
-set the Proma THC150 to test mode with at least 5 seconds of time between changes
-put something about 3-5cm above the plate for the probing and remove after probe
-run the circle with the torch ON in QtPlasmaC
Do not turn the plasma ON while testing this.
  • PCW
  • PCW's Avatar
23 Oct 2025 20:44
Replied by PCW on topic Mesa 7i95T not responding
The 7I95T identifies as a 7I95 (even in hal) mainly so 7I95 configs will work with it.
  • distro88
  • distro88
23 Oct 2025 20:34
Replied by distro88 on topic torch moving UP when it should be moving DOWN
Category: Plasmac
I tried that too. I even reinstalled LinuxCNC and changed all the pins — same problem
23 Oct 2025 19:57
Replied by tommylight on topic Mesa 7i95T not responding
I do not know, i only had 7i95 without the T.
  • Ringardy
  • Ringardy
23 Oct 2025 19:55 - 23 Oct 2025 19:57
Replied by Ringardy on topic Mesa 7i95T not responding
Thanks, it works but one more thing.
Even tho its a 7i95T is it normal that it only says 7i95
23 Oct 2025 19:52
Category: Plasmac
Moved to "PlasmaC" section.
I am sure this same thing was posted before here, so what happened?
Checked your files twice, seems OK, so check the wiring although from your description should be OK.
Since i can not find anything wrong and there is an issue, the quickest solution would be to make a new config.
23 Oct 2025 19:46
Yes.
In a terminal
ping 10.10.10.10
should return values with the time it takes to card and back in ns (nano seconds).
  • PCW
  • PCW's Avatar
23 Oct 2025 19:44
Yes, that is the EEPROM setting.
(default EEPROM IP address is 10.10.10.10)
Displaying 12226 - 12240 out of 12877 results.
Time to create page: 0.829 seconds
