21 Oct 2025 21:27
Replied by tommylight on topic Stepper motors should hold position when error.
In your case, you should have gotten a servo/stepper with brake for Z axis.
It is a hardware feature, so software can not help, but if the loop is closed in LinuxCNC at least it will know the position.
PCW's idea with enabling fast after fault and if loop is closed in LinuxCNC is very good.
As for your question, drive fault will disable the motor in the drive, so nothing LinuxCNC can do about it (except above), and so will LinuxCNC disable everything when it gets a fault error.
  • JT
  • JT's Avatar
21 Oct 2025 20:47
linuxcnc.command().mdi() vs .program_open()
auto(int[, int]) run, step, pause or resume a program.
This is how I open then run a program in Flex GUI
github.com/jethornton/flexgui/blob/maste...exgui/actions.py#L13
github.com/jethornton/flexgui/blob/maste...xgui/actions.py#L296
assuming you're using a probe you can store the probe results in a file.
JT
  • LeonDolnicar
  • LeonDolnicar
21 Oct 2025 19:48
Replied by LeonDolnicar on topic Stepper motors should hold position when error.
I have built my CNC just this month so I have only conducted test cuts, and have not gotten a driver error while machining yet, i just thought such a setup would make more sense if it did happen.
How are errors on drivers on CNC mills usually set up.
I am using Motor Driver CL-HSS860 driver with nema 34 stepper motor.
  • rodw
  • rodw's Avatar
21 Oct 2025 19:41
Replied by rodw on topic Update LinuxCNC 2.9.5 on debian 13
Category: Installing LinuxCNC
Maybe if I stuck with Mach3 I wouldn't spend so much money, bugger I said the quiet part out load.
But lets face it you might have slashed your wrists by now....
  • rodw
  • rodw's Avatar
21 Oct 2025 19:37
Replied by rodw on topic Ohmic sensing with IPTM-60
Category: Show Your Stuff
Yes, standard = height set on probing up.
Yes, I saw that hesitation which I think is reducing velocity at probe height which is normal.
Early in the piece, I added a set screw to reduce float switch hysteresis to the barest of minimum.
the second video depends on the float switch to absorb over travel/inertia due to travel speeds.
Yes I don't think a float switch us necessary if you have reliable ohmic probing. In fact my float switch proximity sensor was broken for months and I didn't even know.
I'm not sure about the probing with ethercat, I know some commercial machines sense the material by torque. But if you have torque homing set up and working, perhaps you can use it for material sensing. Maybe you would use the probing function instead. It will be a good experimental project for someone like you :)
  • rodw
  • rodw's Avatar
21 Oct 2025 19:20
This is dependent on the outputs and inputs of the stepper driver you are using. Can you share more?
Personally, I don't think you can achieve what you want.
But getting faults on the drive implies an incorrectly set up stepper. Fix that and the problem goes away.Try reducing the current on the drive.
  • Grandberg
  • Grandberg
21 Oct 2025 19:17
7i97T stepgen outputs dead, encoders & I/O OK - suspect damaged P2 interface
Category: Driver Boards
Thank you for your quick responses!  Please tell me, am I correct in understanding that U22 refers to this chip? Could you also tell me where else in Europe it can be found, or any suitable equivalents?
  • Razvan_Pop
  • Razvan_Pop
21 Oct 2025 19:06
Automatic tool changer was created by Razvan_Pop
Hello!
I'm kind of a newbie with the LinuxCNC stuff. I enjoy working with this stuff. It's kinda fun...
But serious question now. I have a MESA board, 7i96s model and I want to make an automatic tool changer using the board I/O to control all the moving pieces and so. But I honestly have absolutely no clue ...
Can someone help me with anything to pull this thing off?
Thank you in advance!
  • TooTall18T
  • TooTall18T's Avatar
21 Oct 2025 18:38
Replied by TooTall18T on topic tool length probe subroutine for Probe Basic
Category: Mill Library
Hi
Welche Versionen benutzt du gerade?
LCNC, Probe Basic und meine Routine
Hast du vielleicht in der Werkzeugtabelle noch die Pockets aktiv? Ich weiß nicht ob es relevant ist, ist jetzt erstmal nur eine Idee.
Muss gestehen, dass mir der Fehler neu ist.
  • scsmith1451
  • scsmith1451's Avatar
21 Oct 2025 17:50
Replied by scsmith1451 on topic linuxcnc.command().mdi() vs .program_open()
Follow-on:
I'm working on a python program to check the levelness of my table.
I have several o<word> functions that are currently attached to buttons on the gmoccapy vcp, one to set zero_z, one to make the measurement and one to reset the spindle back to zero_z preparatory to the next measurement. All work as expected.
The python program is an attempt to automate the process measuring the four corners and the center of the table, then record the values into a spreadsheet. The hope is that overtime I can create run charts for each point to evaluate accuracy and precision.
Currently, the application moves to the Z height and sets zero_z calling the first .ngc function as expected. Next it moves the spindle to the first corner and calls the measurement.ngc. The spindle is lowered to the touch plate, but fails to move up and back down for the final measurement. It appears as though the function is failing to execute all of the commands before returning to the application complaining that the spindle failed to reach the touch plate.
I'm wondering if calling an o<word> function is limited to executing just one command when called by c.mdi("o<word>")?
Perhaps o<word> commands need to be processed with c.program_open. However, your previous response indicates that the code would be loaded but, not executed. 1) How do I get the file to execute after opening it, 2) Will loading a program preempt the execution of the running python program?
Any hints to get around this SNAFU?
Regards,
  • LearningLinuxCNC
  • LearningLinuxCNC's Avatar
21 Oct 2025 16:59
Lcnc_Dialog Issue was created by LearningLinuxCNC
Lcnc_Dialog Issue
Category: Qtvcp
I am trying to call the Lcnc_Dialog widget from python code.
My code is as follows.
        color = QColor(255,0,0,150)
        msgdict = {
            "NAME": "MESSAGE"
            "TITLE": "A-Axis Ready?",
            "MESSAGE": "Is the A-Axis aligned?",
            "TYPE": 'YESNO',
            "ICON": 'QUESTION',
            "FOCUSCOLOR": color
        ACTION.CALL_DIALOG(msgdict)
When the dialog pops up it lists all of the text in the msgdict variable and does not show the dialog as expected.
I know the issue is something simple I just can't seem to see the issue.
Thanks,
  • PCW
  • PCW's Avatar
21 Oct 2025 16:20
Can you reset the drive by disabling and immediately re-enabling the drive?
That is something that could be done in hal (at least for Z)
(assuming you have the drive enable connected)
  • Routerworks
  • Routerworks
21 Oct 2025 16:17
How to create profile for path that is not closed loop
Category: CAD CAM
Thanks a lot. Been using the same old things for too long. I'll have to look into this.
Thanks again
  • LeonDolnicar
  • LeonDolnicar
21 Oct 2025 16:08
That is what I am trying to figure out. I searched online but found nothing.
Displaying 12361 - 12375 out of 12888 results.
Time to create page: 3.346 seconds
