  • Hakan
  • Hakan
13 Oct 2025 09:09
Issue with OP Entry Delay and Failures in LinuxCNC + EtherCAT System
Category: EtherCAT
It was just an "apt upgrade", I am using debian trixie on that computer.
It may not be the kernel for you. It may not have been for me either, I messed around with many things that day.
You can always try an "apt update" followed by "apt upgrade". That should install the latest kernel and many more upgraded apps.
The messages you get is what I got using Realtek network interface.
What network interface do you have? Find out with "lspci"
13 Oct 2025 09:03
Upgrade of CNC Plasma Cutting Table with Mesa 7i96S, THCAD-2 And MyOhmic PRO
Category: Driver Boards
If using a THCAD for ohmic sensing has issues with water. the most likely issue
is that the sense  resistor is too high a value.
I agree and I am pretty sure i mentioned somewhere a long time ago that a lower value resistor should be used for sensing. Something that will result in 20-50mA current should do just fine, maybe more as the water used will get lower resistance the more cuts are done and as it evaporates.
  • GuessWho
  • GuessWho
13 Oct 2025 08:11
Thanks everyone for the feedback. I’ll keep you posted as things progress.
  • shaying526
  • shaying526
13 Oct 2025 08:04 - 13 Oct 2025 08:09
Category: EtherCAT
Thank you for your response!
I'd like to try your method and hope it can resolve my current issue.
I haven't worked on updating the preempt-rt kernel before.
Are there any tutorial posts you could recommend to me?
Also, where can I download the 6.12-48 version you mentioned?
Current Kernel: Linux debian 6.1.0-23-rt-amd64
  • Hakan
  • Hakan
13 Oct 2025 07:54
Replied by Hakan on topic Servo analog command, PID and El5101
Category: EtherCAT
You can also investigate if it is possible to wire the glass scale directly to the servo drive.
The servo drive will then use the glass scale instead of the servo's encoder.
  • laurentl38
  • laurentl38
13 Oct 2025 06:34
increment 4 MPG jog wheels with Basic Probe
Category: QtPyVCP
Hello,
I'm using 4 MPG jog wheels. I don't have a physical button to change the increment.
With Axis, there's a HAL pin to get the GUI information about the jog increment.
Now, I'm transferring the configuration to Basic Probe, but I can't find the information about the increment selected in the GUI (pictured).
Is there a simple way to get the information about the increment selected in the GUI?
Regards
  • endian
  • endian's Avatar
13 Oct 2025 03:39
Replied by endian on topic Ethercat, EL6751 and CANOpen
Category: EtherCAT
okay ... thats kind weird ..
it should not runs like you described ...
maybe help convert setpoint to bool and there will be signal enable ... or use some general enable to enable spindle.0 too
  • cmorley
  • cmorley
13 Oct 2025 03:14
Replied by cmorley on topic installing QTVCP
installing QTVCP
Category: Qtvcp
What version of linux are you using?
  • bnet
  • bnet's Avatar
13 Oct 2025 02:49
Fanuc Serial Pulse Coders - Red cap servos, mesa 7i76e, how to?
Here's a version that uses the digitally settable preset velocity mode to seek for the index of the encoder:
#  LinuxCNC HAL — Ultra3000 preset velocity index seek
#  Board: 7i76e main + 7i84 (outputs) + 7i85 (encoder)
#  Axis: X
loadrt threads name1=servo-thread period1=1000000
# --- Load components ---
loadrt bldc count=1
loadrt encoder num_chan=1
loadrt mux2 count=1
loadrt and2 count=1
loadrt not count=1
loadrt timedelay count=1
loadrt oneshot count=1
addf encoder.update servo-thread
addf bldc servo-thread
addf timedelay servo-thread
addf oneshot servo-thread
#  Encoder setup (7i85)
setp hm2_7i85.0.encoder.00.scale 800
setp hm2_7i85.0.encoder.00.counter-mode 0
setp hm2_7i85.0.encoder.00.filter 1
net x-enc-a     hm2_7i85.0.encoder.00.input-a
net x-enc-b     hm2_7i85.0.encoder.00.input-b
net x-enc-z     hm2_7i85.0.encoder.00.input-index
#  BLDC Hall synthesis (for Ultra3000 commutation)
# 8-pole motor = 4 pole pairs
setp bldc.0.pole-pairs 4
setp bldc.0.encoder-scale 800
setp bldc.0.hall-offset 0      # will be updated after index alignment
net x-enc-pos       hm2_7i85.0.encoder.00.position => bldc.0.enc-pos
net hall-u          bldc.0.hall-u => hm2_7i84.0.output-00
net hall-v          bldc.0.hall-v => hm2_7i84.0.output-01
net hall-w          bldc.0.hall-w => hm2_7i84.0.output-02
#  Preset Velocity Control Output (7i84)
# Choose an available output (here output-03)
net preset-vel-enable => hm2_7i84.0.output-03
#  Step/Dir control enable (7i76e stepgen 0)
net stepgen-enable => hm2_7i76e.0.stepgen.00.enable
#  State control logic for startup alignment
# --- Delay after power-up before preset allowed ---
setp timedelay.0.on-delay 0.25
net startup-delay timedelay.0.out => preset-allow
net always-true timedelay.0.in <= true
# --- Oneshoot from encoder index detection ---
setp oneshot.0.width 0.05
net x-enc-index hm2_7i85.0.encoder.00.index => oneshot.0.in
net index-found oneshot.0.out
# --- Preset velocity enable logic ---
# When not yet found index and startup delay done -> enable preset rotation
loadrt and2 count=1
net not-found-delay and2.0.in0 <= preset-allow
net not-found-delay and2.0.in1 <= not-index-found
net preset-active and2.0.out => hm2_7i84.0.output-03
# --- index found logic ---
loadrt not count=1
net index-found oneshot.0.out => not.0.in
net not-index-found not.0.out
# --- On index detection, disable preset and enable stepgen ---
net index-found stepgen-enable
# (this ties directly; optionally route through another delay)
  • bnet
  • bnet's Avatar
13 Oct 2025 02:29 - 13 Oct 2025 02:51
The problem with the setup with the Fanuc encoders in my case was that I couldn't find a way to return quadrature encoder pulses back to the Ultra3000 drives which it requires to run. They need both, encoder and commutation pulses. Had I been using a motor drive that was controlled by LinuxCNC on a lower lever [such as the Mesa ones?] it would have worked (I think?) with BLDC component and original encoders. That would have been a slick setup. Also by the time I bought the Ultra3000's and the new encoders I am probably close to the price of those Mesa drives. Next time.
Now onto generating commutation signals for the drives now that they have the encoder connected to them. ChatGPT seems to think its possible to do with BLDC. I've already spotted one error which is that the ultra3000s don't have an option to set low torque mode via the digital inputs.. So that leaves me unsure of if the rest of it will work.
#  Fanuc Redcap → Ultra3000 setup (X axis)
#  Mesa 7i76e + 7i85 + 7i84
# --- Load required components ---
loadrt bldc cfg=qiH
loadrt toggle count=1
addf bldc.0 servo-thread
addf oneshot.0 servo-thread
addf toggle.0 servo-thread
#  Encoder Input (7i85)
# Encoder channel 0 on 7i85 → 800 counts per rev
net x-rawcounts     hm2_7i85.0.encoder.00.rawcounts => bldc.0.rawcounts
net x-index-enable  hm2_7i85.0.encoder.00.index-enable => bldc.0.index-enable
net x-index-pulse   hm2_7i85.0.encoder.00.index => oneshot.0.in
setp oneshot.0.width 0.1
net x-index-detected oneshot.0.out => toggle.0.toggle
net x-index-found    toggle.0.state
#  BLDC synthetic Hall generation
setp bldc.0.scale           800          # encoder counts per mechanical rev
setp bldc.0.poles           4            # 8-pole motor = 4 pole pairs
setp bldc.0.encoder-offset  0.0          # adjust once aligned
setp bldc.0.output-pattern  25
# Output Hall states to Ultra3000 (7i84)
net hall1 bldc.0.hall1-out => hm2_7i84.0.output-00
net hall2 bldc.0.hall2-out => hm2_7i84.0.output-01
net hall3 bldc.0.hall3-out => hm2_7i84.0.output-02
#  Step/Dir setup (X Axis)
# Step/Dir on 7i76e output 0
setp hm2_7i76e.0.stepgen.00.dirsetup   5000
setp hm2_7i76e.0.stepgen.00.dirhold    5000
setp hm2_7i76e.0.stepgen.00.steplen    2500
setp hm2_7i76e.0.stepgen.00.stepspace  2500
setp hm2_7i76e.0.stepgen.00.position-scale 10000
setp hm2_7i76e.0.stepgen.00.maxvel     60
setp hm2_7i76e.0.stepgen.00.maxaccel   300
net x-pos-cmd axis.x.motor-pos-cmd => hm2_7i76e.0.stepgen.00.position-cmd
net x-pos-fb  hm2_7i76e.0.stepgen.00.position-fb => axis.x.motor-pos-fb
net x-enable  axis.x.amp-enable-out => hm2_7i76e.0.stepgen.00.enable
#  Torque Limit Select control (7i84 output-04)
# Before index found, TorqueLimitSelect = ON (low current)
# After index found, TorqueLimitSelect = OFF (normal torque)
# This drives a digital input on the Ultra3000.
net torque-low hm2_7i84.0.output-04
net torque-low <= not-x-index-found
# Use toggle to remember index found across servo cycles
net not-x-index-found toggle.0.state
# (If logic inverted, swap TRUE/FALSE below)
setp toggle.0.state 0   # default = index not found
#  Auto jog-to-index at startup
# At boot: torque low active, start slow jog
setp hm2_7i76e.0.stepgen.00.velocity-cmd 0.05
net torque-low hm2_7i76e.0.stepgen.00.enable
# Once index found: stop motion, switch torque to normal
net x-index-found => hm2_7i76e.0.stepgen.00.enable-not
net x-index-found => hm2_7i76e.0.stepgen.00.velocity-cmd 0
  • unknown
  • unknown
13 Oct 2025 01:34 - 16 Oct 2025 01:19
fixing "raspi firmware" errors on the official amd64 ISO
Category: Installing LinuxCNC
Thoughts changed, situation is little more complex.
  • unknown
  • unknown
13 Oct 2025 00:05
Found the underlying issue:
#!/bin/sh
set -e
lb config noauto \
	--architectures amd64 \
	--linux-packages linux-image-rt \
	--debootstrap-options "--include=apt-transport-https,ca-certificates,openssl" \
	--distribution bookworm \
	--binary-images iso-hybrid \
	--debian-installer live \
	--archive-areas "main contrib non-free non-free-firmware" \
	--iso-application "LinuxCNC-2.9.6" \
	--iso-preparer "rmurphy@gmx.com" \
	--iso-volume "LinuxCNC_2.9.6" \
	--image-name "LinuxCNC_2.9.6" \
	--iso-publisher "www.linuxcnc.org" \
	--apt-recommends true \
	--security true \
	--updates true \
	--apt-options " --yes --allow-change-held-packages" \
	--bootappend-install "ipv6.disable=1" \
	--parent-mirror-bootstrap http://deb.debian.org/debian \
	--parent-mirror-binary http://deb.debian.org/debian \
	--parent-mirror-chroot-security http://deb.debian.org/debian-security \
This line
is missing from auto/config file
Booting into a live seesion dpkg --list has no entries for raspi-firmware
  • PCW
  • PCW's Avatar
12 Oct 2025 23:45
Replied by PCW on topic Servo analog command, PID and El5101
Category: EtherCAT
If you do not connect the pid.N.feedback-deriv pin, the PID component will calculate
the velocity (for the D term)  via D/DT of position, so its not required to generate
and independent velocity signal. This may not be quite as good as velocity estimation
but it should be pretty good if the scale resolution is high.
  • richcolvin
  • richcolvin's Avatar
12 Oct 2025 21:37 - 12 Oct 2025 21:38
Zero the DRO was created by richcolvin
Zero the DRO
Category: GladeVCP
I want to put a button on the Glade panel which will zero out the DRO.  I don't want to HOME the axis as I want it to be good where it is.
On the panel, I am currently displaying the DRO value from position-fb:
HAL file:
net x-pos-fb    => pid.x.feedback
net x-pos-fb   <=  hm2_7i92.0.stepgen.02.position.fb
net x-pos-fb   => joint.0.motor-pos-fb
PostGUI HAL file:
net x-pos-fb    => gladevcp.X_DRO             This is what gets displayed
I am assuming that I need to add a HAL button to GladeVCP and then call a function in the handler python program.
Within that function, how do I write a 0 to this?
  • vibram
  • vibram
12 Oct 2025 21:36
Servo analog command, PID and El5101 was created by vibram
Category: EtherCAT
Hello
I run the follow configuration el4034 to command analog servo drive.
I have a glass scale wired to an EL5101 device.
I saw several posts regarding pid tuning but I have the feeling (or I understood that way) the velocity was mandatory.
On the mesa, for each encoder we have the velocity available but it's not the case for the EL5101.
How is it possible to generate it?
Thank you in advance
Displaying 12781 - 12795 out of 12958 results.
Time to create page: 0.648 seconds
