  • NT4Boy
  • NT4Boy
12 Oct 2025 16:42
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
For too many months I tried in vain to fix the venerable vfd that was the original fitment in the machine and have at last inserted a Yaskawa unit . Tiny thing compared to the old one! But does actually run the motor at the speed commanded without drama and also reverses without needing to stop the spindle. Have also got the Linuxcnc spindle at speed bit to work from the encoder signal.
I think I've been round in circles on the synchronised motion implementation say for tapping.
I believe now that when pncconf writes the hal for a spindle with an encoder, then no additional entries are required to enable synchronised motion. The configuration output has spindle position, speed as well as index enabled pins, and I think that is all that is needed.
The wiki help, to me, implies some specific pin names are required, but after trying to get the suggested ones to work I find that in fact the default ones provided by pncconf work, or at least seem to.. At least I can get a sample G-code file with G33.1 to complete a cycle. Yet to cut metal with it, but nearly there.
I am also confused by the Spindle at speed notion. I can understand that it would be better if the spindle was running before the tool hits the workpiece, and notionally a good idea, but when the spindle reverses in the middle of a tapping cycle, I am guessing that the motion will continue to move as the tool delcels and accels, rather than wait to get up to speed? Must do, but was curious as to what happens under the hood so to speak.
  • andypugh
  • andypugh's Avatar
12 Oct 2025 16:34
fixing "raspi firmware" errors on the official amd64 ISO
Category: Installing LinuxCNC
Issues: asks for root passwd, my fault will fix on another build, ISO still identifies as 2.9.4, need to update the config file.
That should be fixed by this:
github.com/LinuxCNC/linuxcnc-live-build/...aller/preseed.cfg#L1
  • andypugh
  • andypugh's Avatar
12 Oct 2025 16:19
Button on Linuxcnc interface that switches an output on Mesa 7i76e on and off
Category: GladeVCP
The last row still creates an error -> custom_postgui.hal:6: Pin 'halui.machine.is-on' was already linked to signal 'machine-is-on'
A bit of HAL backgroumd. A HAL "net" command is the word "net" followed by a "signal name" and one or more HAL pins.
The signal name can be chosen fairly freely, and serves as the reference for interconneting HAL pins. There can be may HAL pins in the same net, but only one of them can be a "writer" (This might typically be called an "output" but that gets a but confusing as physical inputs are "output" HAL pins (they output a value) and physical outputs are "inputs" as they accept a value from output HAL pin)
Back to your error. It means that the HAL pin "halui.machine.is-on" is already connected to a HAL "net" somewhere else in the HAL files, and that it is connected to the net "machine-is-on".
The fix for this is to just use "machine-is-on" as the net name for anything that you want to connect to "halui.machine.is-on"
I can't see your problem HAL line from inside this editor, but if, for example, the line causing the problem was:
net some-net-name mygladepanel.pin <= halui.machine.is-on"
Then you would need to change it to:
net machine-is-on => mygladevcp.pin
(Note that the => <= and <=> don't mean anything to the computer and can be left out, but can help readabilty for humans)
  • andypugh
  • andypugh's Avatar
12 Oct 2025 16:04
Upgrade of CNC Plasma Cutting Table with Mesa 7i96S, THCAD-2 And MyOhmic PRO
Category: Driver Boards
It looks like you have most of it sorted out, but feel free to ask any questions if you get stuck.
Depending on what the mystery control board is, it might be compatible with Remora firmware.
  • Twitchy88
  • Twitchy88
12 Oct 2025 15:14
Replied by Twitchy88 on topic installing QTVCP
installing QTVCP
Category: Qtvcp
Yep, i think i typed that out fast for the forum, also the laptop will just be for learning when I cant make it out to the shop.
Selection? 3
installing common tools
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Package qttools5-dev-tools is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Unable to locate package qttools5-dev
E: Package 'qttools5-dev-tools' has no installation candidate
installing python3 tools
E: Unable to locate package libpython3-dev
create plugin link at:
~/.designer/plugins/python/
Installation complete, designer can be started with:
designer -qt=5
nate@linuxcnc-laptop:~$ designer -qt=5
bash: designer: command not found
  • DerKlotz
  • DerKlotz
12 Oct 2025 14:51 - 12 Oct 2025 15:45
Category: GladeVCP
Strange... now the first two rows of the postgui work
ok now setp gladevcp.table1 1
ok now net button gladevcp.button1 halui.machine.on
not ok net led halui.machine.is-on gladevcp.led1
This is now correct
net button gladevcp.button1 halui.machine.on gladevcp.led1
  • DerKlotz
  • DerKlotz
12 Oct 2025 14:42
Category: GladeVCP
There was an 1 missing... probably didn´t copy it.
But still many errors...
  • PCW
  • PCW's Avatar
12 Oct 2025 14:19 - 12 Oct 2025 14:19
Category: GladeVCP
Not sure about the GUI errors, but this is a showstopper:
custom_postgui.hal:4: setp requires 2 arguments, 1 given
That means you have a very basic error in line 4 of custom_postgui.hal
  • DerKlotz
  • DerKlotz
12 Oct 2025 14:04 - 12 Oct 2025 14:05
Category: GladeVCP
I used your example.ui and custom_postgui.hal now. Sorry for all... iḿ a total newbie
I used this command in the ini/Display for the ui... correct? Itś stored under that folder
GLADEVCP = /home/cnc/linuxcnc/configs/Fräse/example.ui
Still get errors
UN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.6
Machine configuration directory is '/home/cnc/linuxcnc/configs/Fräse'
Machine configuration file is 'Fräse.ini'
INIFILE=/home/cnc/linuxcnc/configs/Fräse/Fräse.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./Fräse.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: axis
83886083
['halcmd', 'loadusr', '-Wn', 'gladevcp', 'gladevcp', '-c', 'gladevcp', '-d', '-x', '81789071', '/home/cnc/linuxcnc/configs/Fräse/example.ui']
Running HAL shutdown script
task: 315 cycles, min=0.000010, max=0.019215, avg=0.009510, 0 latency excursions (> 10x expected cycle time of 0.010000s)
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:10:4c:98
hm2_eth: discovered 7I76E-16
hm2/hm2_7i76e.0: Low Level init 0.15
hm2/hm2_7i76e.0: Smart Serial Firmware Version 43
Board hm2_7i76e.0.7i76.0.0 Hardware Mode 0 = standard
Board hm2_7i76e.0.7i76.0.0 Software Mode 0 = io_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 1 = io_ana_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv
hm2/hm2_7i76e.0: 51 I/O Pins used:
hm2/hm2_7i76e.0:     IO Pin 000 (P1-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i76e.0:     IO Pin 001 (P1-14): StepGen #0, pin Step (Output)
hm2/hm2_7i76e.0:     IO Pin 002 (P1-02): StepGen #1, pin Direction (Output)
hm2/hm2_7i76e.0:     IO Pin 003 (P1-15): StepGen #1, pin Step (Output)
hm2/hm2_7i76e.0:     IO Pin 004 (P1-03): StepGen #2, pin Direction (Output)
hm2/hm2_7i76e.0:     IO Pin 005 (P1-16): StepGen #2, pin Step (Output)
hm2/hm2_7i76e.0:     IO Pin 006 (P1-04): IOPort
hm2/hm2_7i76e.0:     IO Pin 007 (P1-17): IOPort
hm2/hm2_7i76e.0:     IO Pin 008 (P1-05): IOPort
hm2/hm2_7i76e.0:     IO Pin 009 (P1-06): IOPort
hm2/hm2_7i76e.0:     IO Pin 010 (P1-07): Smart Serial Interface #0, pin tx0 (Output)
hm2/hm2_7i76e.0:     IO Pin 011 (P1-08): Smart Serial Interface #0, pin rx0 (Input)
hm2/hm2_7i76e.0:     IO Pin 012 (P1-09): IOPort
hm2/hm2_7i76e.0:     IO Pin 013 (P1-10): IOPort
hm2/hm2_7i76e.0:     IO Pin 014 (P1-11): Encoder #0, pin Index (Input)
hm2/hm2_7i76e.0:     IO Pin 015 (P1-12): Encoder #0, pin B (Input)
hm2/hm2_7i76e.0:     IO Pin 016 (P1-13): Encoder #0, pin A (Input)
hm2/hm2_7i76e.0:     IO Pin 017 (P2-01): IOPort
hm2/hm2_7i76e.0:     IO Pin 018 (P2-14): IOPort
hm2/hm2_7i76e.0:     IO Pin 019 (P2-02): IOPort
hm2/hm2_7i76e.0:     IO Pin 020 (P2-15): IOPort
hm2/hm2_7i76e.0:     IO Pin 021 (P2-03): IOPort
hm2/hm2_7i76e.0:     IO Pin 022 (P2-16): IOPort
hm2/hm2_7i76e.0:     IO Pin 023 (P2-04): IOPort
hm2/hm2_7i76e.0:     IO Pin 024 (P2-17): IOPort
hm2/hm2_7i76e.0:     IO Pin 025 (P2-05): IOPort
hm2/hm2_7i76e.0:     IO Pin 026 (P2-06): IOPort
hm2/hm2_7i76e.0:     IO Pin 027 (P2-07): IOPort
hm2/hm2_7i76e.0:     IO Pin 028 (P2-08): IOPort
hm2/hm2_7i76e.0:     IO Pin 029 (P2-09): IOPort
hm2/hm2_7i76e.0:     IO Pin 030 (P2-10): IOPort
hm2/hm2_7i76e.0:     IO Pin 031 (P2-11): IOPort
hm2/hm2_7i76e.0:     IO Pin 032 (P2-12): IOPort
hm2/hm2_7i76e.0:     IO Pin 033 (P2-13): IOPort
hm2/hm2_7i76e.0:     IO Pin 034 (P3-01): IOPort
hm2/hm2_7i76e.0:     IO Pin 035 (P3-14): IOPort
hm2/hm2_7i76e.0:     IO Pin 036 (P3-02): IOPort
hm2/hm2_7i76e.0:     IO Pin 037 (P3-15): IOPort
hm2/hm2_7i76e.0:     IO Pin 038 (P3-03): IOPort
hm2/hm2_7i76e.0:     IO Pin 039 (P3-16): IOPort
hm2/hm2_7i76e.0:     IO Pin 040 (P3-04): IOPort
hm2/hm2_7i76e.0:     IO Pin 041 (P3-17): IOPort
hm2/hm2_7i76e.0:     IO Pin 042 (P3-05): IOPort
hm2/hm2_7i76e.0:     IO Pin 043 (P3-06): IOPort
hm2/hm2_7i76e.0:     IO Pin 044 (P3-07): IOPort
hm2/hm2_7i76e.0:     IO Pin 045 (P3-08): IOPort
hm2/hm2_7i76e.0:     IO Pin 046 (P3-09): IOPort
hm2/hm2_7i76e.0:     IO Pin 047 (P3-10): IOPort
hm2/hm2_7i76e.0:     IO Pin 048 (P3-11): IOPort
hm2/hm2_7i76e.0:     IO Pin 049 (P3-12): IOPort
hm2/hm2_7i76e.0:     IO Pin 050 (P3-13): IOPort
hm2/hm2_7i76e.0: registered
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
note: MAXV     max: 25.000 units/sec 1500.000 units/min
note: LJOG     max: 25.000 units/sec 1500.000 units/min
note: LJOG default: 6.000 units/sec 360.000 units/min
note: jog_order='XYZ'
note: jog_invert=set()
[GladeVCP][[36mINFO[0m]  Logging to: [33m/home/cnc/gladevcp.log[0m (logger.py:106)
[GladeVCP.QTVCP.QT_ISTAT][[33mWARNING[0m]  INI Parsing Error, No DEFAULT_SPINDLE_0_SPEED Entry in DISPLAY, Using: 200 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][[33mWARNING[0m]  INI Parsing Error, No MIN_SPINDLE_0_SPEED Entry in DISPLAY, Using: 100 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][[33mWARNING[0m]  INI Parsing Error, No MAX_SPINDLE_0_SPEED Entry in DISPLAY, Using: 2500 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][[33mWARNING[0m]  INI Parsing Error, No MAX_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 1 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][[33mWARNING[0m]  INI Parsing Error, No MIN_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 0.5 (qt_istat.py:532)
(gladevcp:117656): Gdk-WARNING **: 16:03:36.296: GdkWindow 0x5000003 unexpectedly destroyed
/usr/lib/python3/dist-packages/gi/overrides/Gtk.py:1689: Warning: invalid (NULL) pointer instance
  return _Gtk_main(*args, **kwargs)
/usr/lib/python3/dist-packages/gi/overrides/Gtk.py:1689: Warning: g_signal_handler_disconnect: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(gladevcp:117656): Gdk-CRITICAL **: 16:03:36.296: gdk_frame_clock_end_updating: assertion 'GDK_IS_FRAME_CLOCK (frame_clock)' failed
**** GLADE VCP ERROR:    X Protocol Error: 3
117585
117633
Stopping realtime threads
Unloading hal components
  • Twitchy88
  • Twitchy88
12 Oct 2025 13:32
Replied by Twitchy88 on topic INI and HAL files
INI and HAL files
I feel like I am going to have to modify the files manually, to get the automatic tool changer working, and setting up things like servo drive enable, alarm input, estop, high and low speed on the spindle.
I could be wrong, very new to this.
  • Twitchy88
  • Twitchy88
12 Oct 2025 13:02
installing QTVCP was created by Twitchy88
installing QTVCP
Category: Qtvcp
i followed the pinned post here for installing and i get this:
nate@linuxcnc-laptop:~$ desginer -qt=5
bash: desginer: command not found
  • GuessWho
  • GuessWho
12 Oct 2025 12:38 - 12 Oct 2025 12:47
Hi all and thank you for checking this topic!
Little intro to my project and why I cam here.
I'm here asking for help with upgrading my table. I've bought a CNC plasma cutting table with the hope of starting my own thing and because it looked like a lot of fun. Couple of months down the road it turned out that the table is more on the hobbyist side than I would like. So I decided to start upgrading it in order to have higher quality cuts that I can be proud of.
My current setup.
PLASMA SOURCE
  • Unit: Sherman CNC 130 (CNC variant).
  • Divided arc output: 1:20 divider present on the machine (available for THC feedback).
CONTROL
  • Unknown motion  control board
  • Unknown THC controller
MOTION, DRIVES, AND POWER
  • Motors: stepper-based system in use - Nema 24 - 60bhh86-300e-24db
  • Stepper drivers: 3 × CW-5045 in use for X, Y1/Y2, Z. (
  • X/Y motion: rack & pinion,
  • Z motion: drive type ballscrew.
  • Installed Power: 400VA transformer labeled “230V / 12A” and “SMT 400VA”. This is a step-down transformer: it takes the 230VAC mains in and produces about 30VAC (at up to 12A) on the secondary. After a bridge rectifier and filter capacitor, that 30VAC becomes roughly 42VDC.
CONTROL AND SOFTWARE
  • CAM: SheetCam (current workflow).
  • Machine control (current): Mach3.
TABLE
  • 3.5 × 2.0 m with water bed.
My plan.
  • Move to LinuxCNC with QtPlasmaC.
  • Move to Mesa 7i96S: Ethernet motion interface
  • Move to Mesa THCAD-2: for 1:20 arc-voltage THC input
  • Move to MyOhmic PRO
  • Install limit switches
  • Use 18 AWG (0.75mm2) shielded cables for the up to 24V connections
  • Use 16 AWG (1.5mm2) shielded cables for the connections that are more than 24v
In short: to replace the controls, cables, add limit switches and keep the rest
The diagram.
I've reused a diagram from the forum (I believe that it's LOWRIDER3) which turns out to be immense help, I'm not sure I would be able to come up with anything useful if it wasn't for it!
I'm adding the diagram itself so that you good folks can make comments, recommendations, critiques. Thank you all in advance!
  • JT
  • JT's Avatar
12 Oct 2025 12:03
Replied by JT on topic User interface
User interface
Well to be fair there is the included Qtvcp too.
You can build what ever you like with it.
Qtdragon uses Qtvcp.
What toolkit is best is probably subjective :)
One of the big differences is Flex GUI uses PyQt6 while all the other PyQt gui's use PyQt5 which is at the end of it's life.
PyQt5 is based on Qt5 which was a cross-platform application framework used for building graphical user interfaces (GUIs) and other programs with C++. It was a major version of the Qt toolkit, but its support ended in May 2025
JT
  • Aciera
  • Aciera's Avatar
12 Oct 2025 11:54
Category: GladeVCP
My Ini already had the POSTGUI_HALFILE = custom_postgui.hal
In my Display Section ii this ->
GLADEVCP= -u ./hitcounter.py /home/cnc/linuxcnc/configs/Fräse/test.ui
BUT i receive the "hitcounter.py" error from my post before
Today i did a Sudo ... update and upgrade. During the upgrade i got these errors. Somewhere there the problem?
Not sure why you keep hacking away at your setup.
Any particular reason for not trying the example.ui I have attached?
  • rodw
  • rodw's Avatar
12 Oct 2025 11:07
Ethercat drives not responding, mesa error finishing read
Category: EtherCAT
You mentioned you should have an Intel driver. In which case the R8168-dkms won't be installed or do anything. Start at the beginning
what doeslspci | grep -i ethernet
report?
Displaying 12811 - 12825 out of 12958 results.
Time to create page: 0.667 seconds
