  • rodw
  • rodw's Avatar
24 Sep 2025 07:50
Going from Devian 10 to 12 has created problems
There are quite a lot of optimisations required with the later kernels (Debian 12-13). I have documented them in a PDF file available here
erpx.au/shop/trixie-linuxcnc-debian-trix...tion-pdf-download-48
There is a nominal AUD $2.00 fee for this info... Sorry but it was the only way I had to store a file.
While it refers to Debian 13 Trixie, it also is applicable to Debian 12 Bookworm.
I will say that feedback from users I've received says 2 core PCs are marginal for Debian 12-13 but some have got them working with the optimisations I describe. I have never used < 4 core PC's
  • unknown
  • unknown
24 Sep 2025 05:54
Replied by unknown on topic 8i20 power supply variation.
Hahaha I look stupid, I thought "our solar system" you meant the solar system, some kind of weird google translation. Not a solar inverter as mentioned later.
You have my permission to make as much fun at my expense as you feel necessary. I honestly feel I deserve it.
Sorry if you thought I was making fun of you. Please accept my apologies.
  • M4MazakUser
  • M4MazakUser
24 Sep 2025 04:06
Replied by M4MazakUser on topic 8i20 power supply variation.
I'm thinking more it's a bad filter cap and a rough infeed from the 3phase fronius solar inverter. It does bump the voltage up.
  • unknown
  • unknown
24 Sep 2025 03:09
I'd look at a component heating issue first. Maybe just below "bad things" when it's not sunny outside, and pushed over the edge when it's sunny outside.
TBH honest the sun is huge, like really huge current thinking has it at 99.8% of the TOTAL mass of the solar system, all the planets and sundry matter make up 0.2% of the solar system (and our sun isn't all that big). And whether it's sunny or not outside it's still fusing ~600 million tonnes of Hydrogen per second into ~596 million tonnes of helium, thus fusing continues (element by element) until all that is left is iron, then we die, and being twisted by magnetic fields and the rest. So basically it's always on, doing what the sun does best fussing atoms into other atoms, generating heat and all manner of electromagnetic radiation.
I'm pretty sure if the ripple was being caused by the solar system you'd be noticing many many more items playing up.
But if you really want to check on the cosmic microwave background grab an old CRT tv, turn it on and turn to a channel that has no terrestrial signal, it'll give a reasonable idea of the radiation around. That's what a small part of the static is.
  • PCW
  • PCW's Avatar
24 Sep 2025 03:05
Replied by PCW on topic 8i20 power supply variation.
Ripple should not make too much difference, you might plot the bus voltage in halscope
to see if there's anything suspicious.
  • snowgoer540
  • snowgoer540's Avatar
24 Sep 2025 01:43
Replied by snowgoer540 on topic No underspeed with temporary material
Category: Plasmac
It should be fixed in that version:
forum.linuxcnc.org/plasmac/53657-holes-3...iour?start=20#308841
But probably you should try updating.
I will try to make some time to have a play with your CAM code.
  • M4MazakUser
  • M4MazakUser
24 Sep 2025 01:06
8i20 power supply variation. was created by M4MazakUser
After many -many many hours of having problems with random following errors in finally have found something that links.
so, when it's not sunny outside the voltage i read on the 8i20 card is 315v dc. When the sun is in full swing it reads 325v dc. This doesn't seem to relate to anything I know, but I have no errors when the sun isn't doing much,  and  plenty when it is, I'm thinking that there is probably some induced ripple from our solar system,  and the dodgy fanuc power supply im using probably has a bad cap. Any ideas ???
24 Sep 2025 00:25 - 11 Oct 2025 02:49
fixing "raspi firmware" errors on the official amd64 ISO
Category: Installing LinuxCNC
The above link/post does not fix the issue, so try this
sudo apt purge *raspi*
Still needs those two lines from the middle of the above linked post.
  • unknown
  • unknown
23 Sep 2025 23:51 - 24 Sep 2025 02:49
  • unknown
  • unknown
  • PCW
  • PCW's Avatar
23 Sep 2025 23:46 - 24 Sep 2025 00:09
Replied by PCW on topic Python pendant logic problems
On the 7I96S there are 4 MPG channels built in with any standard firmware
These use the isolated inputs 0..7 but do not interfere with normal input use.
The count pins on the isolated I/O are:
hm2_7i96s.0.inm.00.enc0-count
hm2_7i96s.0.inm.00.enc1-count
hm2_7i96s.0.inm.00.enc2-count
hm2_7i96s.0.inm.00.enc3-count
There is also 7I96S firmware that puts MPG encoders on P1:
7i96sd_mpgp1.bin
Its MPG encoder count pins on P1 are:
hm2_7i96s.0.inm.01.enc0-count
hm2_7i96s.0.inm.01.enc1-count
hm2_7i96s.0.inm.01.enc2-count
hm2_7i96s.0.inm.01.enc3-count
These are additional to the MPG inputs available on the isolated I/O
If you are using buttons/MPG on P1, the  7i96sd_mpgp1.bin
is probably the best as it also uses the INM module so has built-in
debounce on all inputs.
Displaying 13351 - 13361 out of 13361 results.
Time to create page: 1.062 seconds
