  • Lcvette
  • Lcvette's Avatar
03 Aug 2025 16:31
Replied by Lcvette on topic probe basic conversational macros missing?
Category: QtPyVCP
there is no documentation link for writing conversational macros unfortunately that is something you need to know how to code yourself. you could make some subroutine variants fairly easily with the help of chatgpt but test them carefully. existing conversational in the mill was done by someone else outside of the qtpyvcp coding resource pool, and they haven't be active in several years which is why its only partially completed.
  • Lcvette
  • Lcvette's Avatar
03 Aug 2025 16:26
Replied by Lcvette on topic Surfacemap Z compensation with Probe Basic
Category: QtPyVCP
kcjengr.github.io/probe_basic/probe_basic_parameters.html
these are all the parameters used by probe basic, they need to be listed in the var file for them to be persistent otherwise they will be volatile per linuxcnc docs.
please feel free to rewrite the docs, i absolutely would love for someone to handle that aspect as its not the easiest to find a way that everyone understands and clearly my approach could use some expert assistance!
the docs also are meant for the develop version. I have gotten a bit side tracked on another project and haven't had time to update the release from develop to stable, but it is what will soon be the stable version. when in doubt, its always best to check and see if the sim works, if it does but your machine config does not, you can move forward knowing their is an issue with your configuration files. you can always compare to the sim config files that do work and those should give you a working installation.
  • PCW
  • PCW's Avatar
03 Aug 2025 16:14 - 03 Aug 2025 16:14
Replied by PCW on topic RPi5 and 7C81, manual control is choppy
Category: Basic Configuration
The jogging issue is probably the standard problem with KB repeat
The overshoot is likely a tuning issue, I would use the standard velocity mode/PID stepgen control
(use a pncconf created configuration for an example) Also make sure to use the DPLL for stepgen
configurations (use pncconf again as an example here)
  • PCW
  • PCW's Avatar
03 Aug 2025 16:07
Replied by PCW on topic Mesaflash is not able to find 5i25
Category: Driver Boards
Does LinuxCNC find the card?
  • TheTinkeringMechanic1
03 Aug 2025 15:54
Replied by TheTinkeringMechanic1 on topic Spindle speed?
Spindle speed?
Got it! Now that I had RPM control forward and reverse with a bonus green GUI scale in both directions it was just a matter of adjusting this:
setp scale.0.gain 0.00275
To this:
setp scale.0.gain 0.008
Which so far is the closest to s300 command. I'll know more when I get an RPM gauge on it.
It may require some adjustments in the VFD. But I'm content with the progress so far.
  • --Matt--
  • --Matt--
03 Aug 2025 15:51
Replied by --Matt-- on topic Surfacemap Z compensation with Probe Basic
Category: QtPyVCP
I think I'll have to go back a couple of steps and try to fix my probe basic config before I continue work on this.
I seem to be having the same trouble as this other user...
forum.linuxcnc.org/qtpyvcp/56674-probe-b...-parameter-variables
I was able to get basic probing routines working by manually editing the parameters in the var file. However, the link between values entered in the ui boxes and the var file seems to be broken. If you try to change a value by entering it in a box it just doesn't do anything.
Is there a place where all the necessary configuration steps are a set out clearly?
I was trying to follow these but evidently they are not totally clear and a bit lacking:
kcjengr.github.io/probe_basic/index.html
I think my config got messed up a couple of times, e.g. by copying values for an imperial machine into my metric machine's setup. The parts that need editing could be made a bit clearer.
  • my1987toyota
  • my1987toyota's Avatar
03 Aug 2025 15:19 - 03 Aug 2025 16:00
Replied by my1987toyota on topic Voron Life , for anyone going into 3D printing !
Category: Additive Manufacturing
Good point tommylight Though I may modify the models for CNC machining .
  • GDTH
  • GDTH's Avatar
03 Aug 2025 15:00
Replied by GDTH on topic Mesaflash is not able to find 5i25
I have a small HP ProDesk 400 G3 SFF. From your suggestion i have looked at both devices (same pc type) bios settings, as of now nothing sticks out yet.
03 Aug 2025 14:52
Spindle speed?
One step forward. After some digging on the internet I went into custom_postgui.hal and changed this:
net spindle-vel-cmd-rpm gmoccapy.spindle_feedback_bar
To this:
net spindle-vel-cmd-rpm-abs gmoccapy.spindle_feedback_bar
And it now shows a green status bar in the GUI in forward and reverse.
Still working on the rpm issue.
  • AkkiSan
  • AkkiSan
03 Aug 2025 14:49 - 03 Aug 2025 14:55
I had a couple of Mesa cards laying around for years and finally found some time to put it into operation.
Especially because the RPi5 comes with this massive performance boost <3
It’s all basically working, except for the pinout (had to solder an adapter), and everything seems to work in auto or MDI mode,
although I only tested a few moves; but manual control is extremely choppy.
The constant movement is just interrupted, as I would have stopped pushing the the button.
Acceleration/deceleration is working, so it’s not a communication issue.
Here:
Probably unrelated, but strange:
At the end of rapid moves, controlled via MDI, the controller or LinuxCNC creates some extra steps.
I did not count them yet, but will check this after the rest is okay:
Are these “user space” issues? Currently I exclusively have older RTAI setups working;
never used this one kernel thingy.
Did I set up anything incorrectly?
thx
AS
  • scsmith1451
  • scsmith1451's Avatar
03 Aug 2025 14:41
Replied by scsmith1451 on topic Set program zero using XY positioning laser
You are correct, Peter. When pncconf generates the configuration HAL file it include two lines that prevent LCNC from launching. A search on the forum identified the culprits and suggested the two lines be commented out. In my zeal to get on with my project, I commented out the wrong lines. Correcting the issue resolved the problems.
Kind Regards -
  • Thomas-1971
  • Thomas-1971
03 Aug 2025 14:06
ethercat verbindung zu bosch-rexroth HCS01 über eoe(ethernet over ethercat)
Category: Deutsch
Hallo zusammen,ich stehe am Anfang eines Projekts ähnlich dem von Rüdiger und möchte meine gebrauchten Rexroth IndraDrive HSC01 in LinuxCNC über EtherCAT betreiben. Aktuell sind die Antriebe jedoch mit PROFINET-Firmware ausgestattet, weshalb ich dringend die korrekte EtherCAT-Firmware benötige.Folgende Eckdaten zu meinen Regler:
  • Typ: HSC01 E1 W0003 A02 B ET EC PB L3 NN FW
  • Aktuelle Firmware: FWA INDRV MPB 20V28 D5 1 NNN NN
Meine Fragen an euch:
  • Ist R911330278  "FWS INDRV MP* **VRS NN ETHERCAT" tatsächlich die passende EtherCAT-Firmware für diese HSC01-Variante?
Rexroth selbst hilft mir nach  Nachfragen nicht weiter. Ich freue mich über jede Bestätigung, Quelle oder Hinweise zum Vorgehen!Vielen Dank im Voraus für eure Unterstützung.Viele Grüße Thomas
  • AlexMagToast
  • AlexMagToast's Avatar
03 Aug 2025 14:05
Replied by AlexMagToast on topic Arduino IO Expansion
Category: Show Your Stuff
Hi, yes that is possible. I would actually reccommend the esp32 over the Arduino, as if I remember correctly the ADC resolution is better on the ESP.
I only ever used it with USB interface.
If you know what you are doing I guess you can run it in ttl2USB too.
  • PCW
  • PCW's Avatar
03 Aug 2025 14:02
Memory at d1000000 (32-bit, non-prefetchable) [disabled] [size=64K]
is suspicious, Sometimes this is BIOS option related.
  • GDTH
  • GDTH's Avatar
03 Aug 2025 13:54
Not entirely sure if this is the correct category of the forum for this question, but here goes:I've just done a completely fresh install of LinuxCNC and I'm running into a few issues — some related to EtherCAT, but also with
mesaflash
.I'm trying to use
mesaflash
with a 5i25 board. I installed it and ran the following command:
sudo mesaflash --device 5I25 --readhmid
But I get this error:
pci_boards_init can't open /dev/mem: Operation not permitted
No 5I25 board found
The 5i25 itself isn't broken — I’ve tested it on another PC and it works fine.When I run
lspci -v
, I can see the board:
02:00.0 DPIO module: Device 2718:5125 (rev 01)
        Subsystem: Device 2718:5125
        Flags: medium devsel, IRQ 255
It feels like something went wrong during the software installation. Has anyone seen this before or know what might be wrong?
Displaying 14011 - 14025 out of 14204 results.
Time to create page: 0.448 seconds
