  • PCW
  • PCW's Avatar
03 Aug 2025 00:27
Replied by PCW on topic Spindle speed?
Spindle speed?
Category: Basic Configuration
Its a bit tricky to setup a PID speed control with a unipolar analog control
and FWD/REV signals.
I would first try eliminating the feedback by running the spindle open loop
you can do this by setting all PID terms to 0 except FF0 which should be  set to 1.0
If you need feedback (this is rare unless the spindle speed control is very poor)
The structure needs to be like this:
PID command = signed commanded spindle speed in RPM
PID feedback = encoder RPM
PID output --> ABS --> analog out
ABS sign (of PID output) determines the FWD/REV pins
  • TheTinkeringMechanic1
03 Aug 2025 00:11
Replied by TheTinkeringMechanic1 on topic Spindle speed?
Spindle speed?
Sorry, I guess the images didn't upload. "hm2_5i24.0.7i83.0.2.analogout0 <= spindle-speed-DAC" reads in forward and reverse. In reverse it shows a reading of 8.25 and stays there, doesn't move when trying to adjust the speed.. In forward it stays around 2.69 with some variation in the next 5 digits. It moves up and down with speed adjustment.
  • Cysign
  • Cysign
02 Aug 2025 22:37
Replied by Cysign on topic Interfaces & linear scale for LinuxCNC
7I95T looks good. But I couldn't find a cheap German oder european source. There's a German shop that has none in stock. Just contacted them to see when it'll be re-stocked :)
Will this be a good choice for a hobby machine?
de.aliexpress.com/item/1005005087476488.html
02 Aug 2025 20:56
Replied by tommylight on topic Voron Life , for anyone going into 3D printing !
Category: Additive Manufacturing
Is the Phoenix the 600x600x600 one with cnc machined parts?
If yes, probably will not be released, i recall they mentioned it was made for a client so they might not approve.
Adding my view here, there are 3D models for Voron with 9 or 10mm wide belts, i built one with those at a 460x460x1200mm size, so no need to wait, just print the gantry and toolhead parts for wide belt and size it up as you see fit.
Resizing a Voron is easy, use their wizard on the website, it spits a complete list of parts with actual sizes.
  • scotta
  • scotta's Avatar
02 Aug 2025 20:46
Post to change the title back to Remora - NVEM / EC300 / EC500.
  • PCW
  • PCW's Avatar
02 Aug 2025 20:39
Replied by PCW on topic Interfaces & linear scale for LinuxCNC
A 7I95T combines the functions, or a 7I96S+ a 7I85, or 7I85S can do it in two cards
  • Cysign
  • Cysign
02 Aug 2025 20:29
Sure, but I would get rid of the LPT-port requirement and could use any computer, not only this specific one (if broken one day...).
Which Mesa card would be your go-to in 2025?
And is there a card combining outputs (for the stepper drivers) as well as inputs for linear magnetic encoders or would this be a combination of two cards?
  • MaHa
  • MaHa
02 Aug 2025 20:11
SolidCam error in output gcode for thread milling.
Category: Post Processors
N25 G0 X0. Y0. Z25.
N26 M99
O3
N27 G91 G0 Z-23.
N28 G1 Z-12. F300
When i Look at this lines, there is incremental rapid from Z25 to Z2 and feed move incremental to -10
The moves with G3 are all incremental G91, so a pitch of 1, with lead in and out exactly to Z0
Line 44 switch back to abs G90
  • snowgoer540
  • snowgoer540's Avatar
02 Aug 2025 19:59
Replied by snowgoer540 on topic PlasmaC Voltage Divider
Category: Plasmac
Sounds like it did not get an Arc OK signal.
The criteria is different depending what Mode you are using:
linuxcnc.org/docs/devel/html/plasma/qtplasmac.html#plasma:modes
  • Sekai
  • Sekai
02 Aug 2025 19:44 - 02 Aug 2025 19:53
Hi .
I'm trying to output an operation with thread milling but the gcode output for z position is static.
(THM_DRILL.NGC)
( 2-AUG-2025)
N1
N2 #12=1
N3 #13=0
N4
N5 #14=1
N6 #15=0
N7  G21 G49 G0 G54 ( ABS mm clr_Z_offset rapid_motion )
(MSG, Óñòàíîâè T1.
N8 M9 (turn all coolant off)
o106 repeat [#14]
o105 repeat [#12]
S3500 M3
G0 X0. Y0. Z25.
N9 M98 P2
N10 g0 x0 y0
N11 g92 x-#13
N12 o105 endrepeat
N13 g92.1
N14 g90
N15 g92 y-#15
N16 o106 endrepeat
N17 g92.1
N18 g90
N19 M30
O2
N20 (
N21 (THM-DRILL - THREAD)
N22 (
N23 G0 X0. Y0. Z25.
N24 M98 P3
N25 G0 X0. Y0. Z25.
N26 M99
O3
N27 G91 G0 Z-23.
N28 G1 Z-12. F300
N29 G41 G1 X7.379 Y-1.516 F800
N30 G3 X0.286 Y8.692 Z0.12 R6.15
N31    Z1. I-7.665 J-7.176
N32    Z1. I-7.665 J-7.176
N33    Z1. I-7.665 J-7.176
N34    Z1. I-7.665 J-7.176
N35    Z1. I-7.665 J-7.176
N36    Z1. I-7.665 J-7.176
N37    Z1. I-7.665 J-7.176
N38    Z1. I-7.665 J-7.176
N39    Z1. I-7.665 J-7.176
N40    X2.835 Y-7.176 Z0.88 R-10.5
N41    X-6.15 Y6.15 Z0.12 R6.15
N42 G40 G1 X-4.35 Y-6.15
N43 G0 Z24.88
N44 G90 M99
The Z axis stays at 1 mm.
I did discover if you open the machine editor of youre machine and go to Working Style => General and you put Software Transform to YES , the gcode output gives the corect z output:
N16 (
N17 (THM-DRILL - THREAD)
N18 (
N19    X0. Y0. Z25.
N20    Z2.
N21
N22 G1 Z-10. F300
N23 G41
N24 G1 X7.379 Y-1.516 F800
N25 G3 X7.665 Y7.176 Z-9.88 R6.15
N26    Z-8.88 I-7.665 J-7.176
N27    Z-7.88 I-7.665 J-7.176
N28    Z-6.88 I-7.665 J-7.176
N29    Z-5.88 I-7.665 J-7.176
N30    Z-4.88 I-7.665 J-7.176
N31    Z-3.88 I-7.665 J-7.176
N32    Z-2.88 I-7.665 J-7.176
N33    Z-1.88 I-7.665 J-7.176
N34    Z-0.88 I-7.665 J-7.176
N35    X10.5 Y0. Z0. R-10.5
N36    X4.35 Y6.15 Z0.12 R6.15
N37 G40
N38 G1 X0. Y0.
N39
N40 G0 Z25.
The problem is there is no more subroutines, the o call does not exist anymore so is M98 , M99.
The post processor is from here: github.com/G-S-E/SolidCAM-postprocessor-for-LinuxCNC
  • MaHa
  • MaHa
02 Aug 2025 19:33 - 07 Aug 2025 19:59
Replied by MaHa on topic Flex Gui preset buttons
Category: Flex GUI
Thats what i got so far
  • zzrzzr
  • zzrzzr
02 Aug 2025 19:06
Replied by zzrzzr on topic PlasmaC Voltage Divider
Category: Plasmac
I tried it again without changing anything and the plasmacutter started without firing at startup. Then I loaded the materal and tried to make a cut through 10mm mild steel. The torch fired, but the machine didn't move. And the torch went on and of a few times.
Why does that happen ? And why doesn't the machine move ?
  • ihavenofish
  • ihavenofish
02 Aug 2025 18:35
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
more fun
i think im almost ready to order the atc parts.
Displaying 14041 - 14055 out of 14204 results.
Time to create page: 0.682 seconds
