  • BlownCorona
  • BlownCorona
30 Jul 2025 09:32
Replied by BlownCorona on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
Category: Installing LinuxCNC
Cancel that request, it turns out my second hand and still not very cheap monitor is just broken :(
i suspect the large amount of conflicting "mine works just fine vs mine wont work no matter what" comments online about these quanta optical touch screens are simply a case of one of the dumb little cameras failing. I would learn from my error and avoid!!
back to square one, thanks all the same!
  • ChironFZ16
  • ChironFZ16's Avatar
30 Jul 2025 09:07 - 30 Jul 2025 09:10
7i37-COM was created by ChironFZ16
7i37-COM
I'm looking for a 7i37-COM. Does anyone have one to spare, or is there any way to get a replacement?
Can the old card be repaired? Are there still spare parts available? My old card had a short circuit.
  • jimmyrig
  • jimmyrig
30 Jul 2025 06:06
Replied by jimmyrig on topic Unwinding Rotary Axis for Homing
Few ways of doing this.
The way I handled it on a 4th axis plasma build was with a magnet on the rotary and a hall effect sensor sensor to read it. Then sending the rotary back to 0 at the end of the gcode via the post processor.
It's not fool proof (power failures) but it works well enough as I just drive past the home switch then home again the one in 1000 times I have a power failure during running
Could use a 3d printed gear reducer to get a 1:4 rotation and put the sensor on that....so 720 turns into 180.
  • miha92768
  • miha92768
30 Jul 2025 05:28 - 30 Jul 2025 06:30
qtvcp was created by miha92768
qtvcp
Help me solve the problem. When creating a panel in qt and embedding it in linuxcnc, a window constantly pops up with the inscription: Qtvcp encountered an error; No handler file was found.
Would you like to copy a basic handler file into your config folder?
This handler file will allow display of your screen and basic keyboard jogging. This happens every time I launch my configuration.
Installing Linuxcnc 2.9.4
  • cadcam
  • cadcam
30 Jul 2025 04:48
Replied by cadcam on topic NativeCam on LinuxCNC 2.9.3
Category: NativeCAM
Thanks! Unfortunately for turning this change allows it to run but breaks the code for this function.
  • jschulze
  • jschulze
30 Jul 2025 04:04
Replied by jschulze on topic Unwinding Rotary Axis for Homing
I've considered picking up an absolute encoder for it. I already had the servos, so I was just trying to use them up. Each axis has a 100:1 harmonic reducer that's belt driven. The belts made the package a bit smaller and allowed me to route the cables through the center of the gear reducers. I'm not concerned about unwinding during a program. I just don't want to shut down the machine at say 400deg and then add another 320deg by always homing in the same direction.
I've got a half baked solution in mind. A while back I made a tool changer and spindle homing procedure from the home all button by calling a halui mdi command and then using g code and I think I might be able to do something similar for this.
  • jschulze
  • jschulze
30 Jul 2025 02:33
Here's the file for the head assembly. It's a fusion archive, so hopefully it included all the components properly. If you want a different format just let me know.
drive.google.com/file/d/1jZTfEVjwmL9wT5n...b-K/view?usp=sharing
  • cakeslob
  • cakeslob
29 Jul 2025 22:48
Replied by cakeslob on topic Probe panel for Axis GUI
Category: AXIS
instructions for that are in the readme
  • PCW
  • PCW's Avatar
29 Jul 2025 22:07 - 29 Jul 2025 23:08
Replied by PCW on topic Mesa 7i96S MPG encoder on P1
Category: Driver Boards
Not sure what the issue is, it works for me:
Built a 7I96S bitfile, flashed to 7I96S and ran it with LinuxCNC
( This is on Mint 20.3 = Ubuntu 20.04, Efinity 25.1 patched with the July 24,2025 patch )
  • GuiHue
  • GuiHue's Avatar
29 Jul 2025 20:50
Replied by GuiHue on topic LinuxCNC and Beckhoff AX5000 servo drives
Category: EtherCAT
i've got the AX5106 and A5203 up and running. db1981 helped al lot regarding the homing and pos_mode issues.
The project itself is still work in progress, but the main features are working. See attached files. These are the relevant snippets from *.hal: [..]
Hi deedee: Are the referenced ax5206.xml and ax5203.xml in the ethercat-config.xml the files attached or are they different ones?
  • atrex77
  • atrex77's Avatar
29 Jul 2025 19:21 - 29 Jul 2025 19:25
W5100S-EVB-PICO stepgenerator and encoder driver
started a proper configurator tool in python, early version, if you want to try it clone the test repository.
early sample, most of the functions are not working yet, you can move the components by grab it, make connections by click the pin and click to another pin, and delete the connections using the list in the right side and the "Del conn" button.
git clone -b test https://github.com/atrex66/stepper-ninja.git
sudo apt install python3-pygame
cd stepper-ninja/configurations/configurator
python3 configurator.py
  • PCW
  • PCW's Avatar
29 Jul 2025 18:24
I'll try with 2025.1 today
Did you apply the 2025.1 patch?
  • roland100
  • roland100
29 Jul 2025 18:11
Replied by roland100 on topic Mesa 7i96S MPG encoder on P1
I tried efinity 2025.1.When I try to open the project seveni96s.xml i get the error:
The previous synthesis run has failed. To avoid potential problems or unreliable data, please run it again.
I click O then I get the message:
The family or device maybe invalid. Click OK to proceed with default family and device. Click Cancel to close project and abort.
Then I click OK the next message:
Encounter internal error. Please get help from support team
What does this all mean ? Do I have to choose a family or device first ?
I`m working on xubuntu 24.04
Do you have any suggestions ?
  • COFHAL
  • COFHAL
29 Jul 2025 17:23
Replied by COFHAL on topic Probe panel for Axis GUI
Category: AXIS
When I press any of the keys X0 YO ZO X this error Unknow command M: M130 appears. What could be the cause?
  • PCW
  • PCW's Avatar
29 Jul 2025 13:21
Replied by PCW on topic Connecting my 7i96s to the VFD
They all connect to the VFD COM pin
(Spindle-,Out4b,Out5B --> VFD COM)
Displaying 14176 - 14190 out of 14202 results.
Time to create page: 0.386 seconds
