  • aeth
  • aeth
29 Jun 2025 10:06
Why does motion planning use linear interpolation instead of b-splines?
I see, but for cutting aluminium (i.e. my machine runs at 4000mm/min with a 8mm tool) and high speed machining applications, I'd say this probably starts to play a much bigger role?
  • JackRay
  • JackRay
29 Jun 2025 07:49
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
here are my files  .hal and .ini
  • meister
  • meister
29 Jun 2025 06:34
@mBender
you can use all pins freely and the 1.8v pins are well suited as inputs as they are 3.3v tollerant.
@Cam
Max 10 works, but not the onboard Ethernet, you need to use W5500 or SPI
Cheers,
Olli
  • Happppppppy
  • Happppppppy
29 Jun 2025 05:52
I have a Terasic DECA Max 10 (10M50DAF484C6GES) fpga dev board that i'm thinking about using as my LinuxCNC hardware step generator. If anyone has any thoughts on why this won't work that would be amazing before I jump into trying to get this to work.
Board details are here:
www.terasic.com.tw/cgi-bin/page/archive....yNo=&No=944&PartNo=1
Cheers,
Cam
  • pippin88
  • pippin88
29 Jun 2025 05:13
W5100S-EVB-PICO stepgenerator and encoder driver
Category: Driver Boards
This looks great. Thanks for your work!
I will probably use it for IO and rotary encoder counting for my control panel (servos are ethercat).
Rotary encoders for MPG / feed override / spindle override.
  • cmorley
  • cmorley
29 Jun 2025 04:22
[qt_dragon_hd] auto tool probe and gcode display issue
Category: Qtvcp
ok great.
I don't see any smoking gun.
Can you test the simulated auto tool config to see if it does the same thing?
You simulate the probe with the on screen button (when the label says probe)
  • Lcvette
  • Lcvette's Avatar
29 Jun 2025 02:50 - 29 Jun 2025 02:52
User error or a strange event on probing. Broken ruby tip.
Category: QtPyVCP
Sounds like you have some electrical noise or maybe need to add some debounce. Remove slow feed by changing to 0.0 and just try using fast feed rate. If you move to slow probes can sometimes double trigger which cause issue. It's best to use a bit more speed. As long as you calibrate at the speed you probe at, you should retain consistent repeatable results
  • SebastianM
  • SebastianM
29 Jun 2025 01:56 - 29 Jun 2025 01:57
Replied by SebastianM on topic Mesa Configuration Tool
Category: Configuration Tools
good afternoon!
today I played around with MesaCT for the first time, and I saw that the generated configuration (for my 7i76eu) has a different naming / nomenclature for my outputs than pncconf...
pncconf outputs lines like this:
net dust-removal-out motion.digital-out-03 => hm2_7i76e.0.7i76.0.0.output-03
while mesact creates these lines:
net flood-output iocontrol.0.coolant-flood => hm2_7i76e.0.gpio.031.out
where does this "gpio" come from? is this redundant or did I do something wrong in the tool?
regards!
  • kubes
  • kubes
29 Jun 2025 01:47
Category: QtPyVCP
I have had probing working for a bit and its been solid.  But today I had a strange event happen, not sure if it was me or something else.  I don't believe the settings are different than before.  Not sure what to even check.
I was probing Z only, and things started fine, the probe was going at the slower rate, tripped, then instead of backing off (Z+) it continued at the fast feed rate (Z-).  Another ruby tip smashed.
I tried again, and it did the same thing.  For a third test, I jogged x-y away from the part, and also jog z+, and tried on a "test" part (just a flat pen held off), and it worked fine, and now it seems to work fine.
What would cause a probe cycle to continue vs backing off?  Or did I make some mistake.  Either way, I want to avoid this again... probe tips are expensive.
  • kubes
  • kubes
29 Jun 2025 01:33
Replied by kubes on topic How to probe Z prior to a corner
Category: QtPyVCP
Thanks! I should have been able to figure that out. I went deep into a deep dark hole. Sorry, I missed the obvious. Again Thanks!
  • Lcvette
  • Lcvette's Avatar
29 Jun 2025 01:28
Replied by Lcvette on topic How to probe Z prior to a corner
Category: QtPyVCP
Probe z in the fixture, then mount your part, select probe position only, probe corner, then zero x and y.
Probe only proves and finds the corner without setting a new work offset. But will be positioned over the corner.
  • kubes
  • kubes
29 Jun 2025 01:20
How to probe Z prior to a corner was created by kubes
Category: QtPyVCP
I have a part that I need to probe.  The Z is from the bottom of the part, as the thickness is very important.  So I want to probe Z prior to probing the edges (corner) of the part as the part will cover the Z (top of fixture /bottom of part).  I know I can do the corner first, remove the part then probe z, but that requires to put the part back in the same X-Y postion.
  • Thayloreing
  • Thayloreing
29 Jun 2025 00:57
Replied by Thayloreing on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
After a long time I managed to compile Remora for the cloud, but it does not enable the emergency button, I believe the manufacturing is correct, the ping is 10.10.10.10, I read a little and saw that I had to play the .tx file to the cloud, it gives a timeout warning for error traffic and does not play the file, reading a little more I saw that there is a short window to be able to play this file, I tried several times to turn it off and try to play the file as soon as it is turned on and reconnected, but without success, can someone help me?
28 Jun 2025 22:06
Replied by tommylight on topic Custom PC build for my brothers company and more
Category: Show Your Stuff
YAYYYYY
Got the Ryzen 7 7700 for 215 Euro, ASRock B650M-HDV/M.2 mainboard for 120, and ... drum roll please 96GB of DDR5 5200 RAM for 146 Euro!!!
Put together two nights ago, finally mounted the Arctic water cooler to CPU and .... could not plug the RGB connector for over 15 minutes! Dang it, to small holes on the plug so i will have to dig some 0.8mm drill bits i have somewhere in the shop to fix that, i like that devilish red glow it looks like the fire monster from Lord Of The Rings movie. :)
Now, i have an Intel 14400 for sale...
More pictures, after i plug the RGB and mount the tempered window.
28 Jun 2025 21:58
Using Mesa 7i95T for laser + galvo (xy2-100) control
How you will implement this because
raster engraving with mesa not supported to linuxcnc.
That is not correct, i use LinuxCNC with and without Mesa for engraving and it works perfectly.
forum.linuxcnc.org/show-your-stuff/46752...ver-etcher-scratcher
Configs should be attached there, and yes, it is the same thing as laser, it uses PWM for pressure control.
Displaying 14476 - 14490 out of 15150 results.
Time to create page: 0.441 seconds
