  • SebastianM
  • SebastianM
15 Jun 2025 15:55
Replied by SebastianM on topic Email Notification?
Email Notification?
Category: Forum Questions
Hello my friends.
I dont receive any notifications as well.... I checked my spam folder and I checked the option to subscribe several threads... but no emails at all...
  • dunnitagain
  • dunnitagain
15 Jun 2025 15:24
Linuxcnc 2.4.5 with Ubuntu 10.04 , Terminated with Error!
i also have and error in the debug ,
'/usr/realtime-2.6.32-122-rtai/modules/emc2/hal_ppmc.ko'
:-1 operation not permitted
jetmill1_load.hal:8:exit value 1
  • matasbuk
  • matasbuk
15 Jun 2025 15:21
Replied by matasbuk on topic Qtdragon for lathe??
Category: Qtvcp
Hi, not sure if this is still in development, but I use Qtdragon on my mill and installed on my lathe retrofit. My lathe is tool down, is there an option to flip the arrow keys and jog buttons to match this? (The diameter should increase then pressing the down arrow key)
  • PCW
  • PCW's Avatar
15 Jun 2025 15:14 - 15 Jun 2025 15:17
Replied by PCW on topic Rote LED
Rote LED
Category: Deutsch
If you get constant blinking red LEDs, this indicates a problems with the 5V supply,
perhaps insufficient current capability or too long power supply wires.
A solid red init LED is normal if LinuxCNC started and then communications
have been disrupted  (it indicates a watchdog timeout)
This may be a latency related issue.
To check network latency, run:
sudo chrt 99 ping -i .001  -q -c 60000 10.10.10.10
(this will run for 1 minute and print statistics)
  • Edi_48
  • Edi_48
15 Jun 2025 14:59
Replied by Edi_48 on topic Rote LED
Rote LED
Category: Deutsch
5.01 Volt
das er die Ethernet Verbindung verloren hat
  • dunnitagain
  • dunnitagain
15 Jun 2025 14:54
I went to the file system
home/ jetmill1 / emc2 / configs / jetmill1 /
there seems to be several .ini files in that folder.
could it be looking at the wrong config file?
  • billykid
  • billykid's Avatar
15 Jun 2025 14:08 - 15 Jun 2025 14:14
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
so it's perfect! if I think how much time I wasted with a nuc i3 to improve the latency without succeeding... I need it to tune up some drives that I recovered 2 years ago, now I also have the servos. if anyone knows these maybe they can give me some advice on how to use them in the best way.
drive Sanmotion rs2aa03a0al0 motor r2aa06040fxp
  • dunnitagain
  • dunnitagain
15 Jun 2025 13:34
I cleaned up the lines , but It still wont load . In the file explorer, it looks like I have 2 different .ini files. Is there a way to properly clean up this mess , without starting over? Machine has direct drive steppers , and DRO Scales for position feedback , Tool probe also. I hate to try and reset all pins and parameters.
  • SebastianM
  • SebastianM
15 Jun 2025 13:27
Replied by SebastianM on topic Error finishing read... *sigh*
Thx.
Can’t tell if I still get would that error as I took the mesa out of the workshop and back into my “office” for bench testing and debugging.
Will apply the grub parameters today that you posted.
Currently I do have the following code in my grub customizer (guess I have to remove it).
quiet isolcpus= 3 pcie.aspm=0 r8168.eee_enable=0 pcie_aspm=off idle=poll
The arguments are slightly different (isolcpus 3 vs 2,3), but let’s see.
15 Jun 2025 12:44
Replaced Hard drive - now my 'fast move' (SHIFT->arrow |PgUp/PgDn is not working
Copy your config folder to the configs folder, open it, right click on the .ini file, choose open with, down click on use custom command, under it type linuxcnc, press enter.
Test the machine, does it work correctly?
If yes, run LinuxCNC from the main menu, left select My configs then your config, click on create desktop shortcut, click ok.
Now you have a shortcut on the desktop.
  • Beovoxo
  • Beovoxo
15 Jun 2025 11:58
Replied by Beovoxo on topic Deckel FP4A Retrofit
Category: Milling Machines
Got new cooling lines installed and pressed today :)
15 Jun 2025 11:48
Replied by tommylight on topic Rote LED
Rote LED
Category: Deutsch
Fehlermeldung?
Und mese die 5V an die Mesa karte, soll 4.75-5.25V sein
  • epineh
  • epineh
15 Jun 2025 10:33
Quick question hopefully, I'm setting up my router with closed loop to the controller, apart from getting the scale right it's all working, my question is when you setup the scale in the pwm/dir config, it sets up the axis "scale in" to that, but leaves the scale out value at 1 or zero (can't remember exactly). At this value the axis will run away similar to having the encoder wires around the wrong way.
I can set it using the machine calibrate window within Linuxcnc but it gets overwritten every time setup is run. Then if you forget about it and an axis is close to end of travel, bad things can happen.
I've most likely just missed where to put in the scale out value but I can't seem to find it.
Cheers.
Russell.
  • Edi_48
  • Edi_48
15 Jun 2025 09:12
Rote LED was created by Edi_48
Rote LED
Category: Deutsch
Hallo ich habe eine Mesa 7i96s und Linuxcnc 2.9.4Ich habe eine Installation Mesact  gemacht mit einbinden 3 Servos, 3 Endschalter, 1 Not-Aus, und WKZ Sensor. Ausgänge : Spindel out 0, out1 und RelaysWenn ich jetzt Linuxcnc starte , kann ich die die Maschine Einschalten bekomme ich eine Fehlermeldung und das Ehternet ist unterbrochen.
Auf der 7i76s blinkt LED init Rot, nur durch Neustarten der Hardware ist der Fehler weg.Meine Maschine ist mit 10.10.10.10 mit meiner Workstation verbunden.
  • unknown
  • unknown
15 Jun 2025 07:26
That's the easiest way, I think I mentioned that earlier, I like Network Manager as I can turn the wifi off whilst running a job.
Displaying 15001 - 15015 out of 15374 results.
Time to create page: 0.876 seconds
