  • ihavenofish
  • ihavenofish
25 May 2025 11:47
Replied by ihavenofish on topic help with ethercat and omron drives
Category: EtherCAT
Hehe that was a joke. Although right now the machine is stuck on estop and I'm not sure why. I'm sure it will be something dumb. :)
  • JohnW
  • JohnW
25 May 2025 11:37
Replied by JohnW on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
I'm new to this and was asking Chat GPT what the problems were with Lichuan drives. It says EtherCat Master stacks on Linux CNC expect drives to follow CiQ 402 correctly, but Lichuan drives lack full state machine compliance, and incorrectly transition from Ready to Switch ON to Operation Enabled, etc. Windows stacks are more tolerant of violations. So by plugging the drive in after they have done an illegal transition, Linux CNC stacks remain happy.
  • Miller Turner
  • Miller Turner
25 May 2025 10:41
Replied by Miller Turner on topic Duplomatic BSV N 160 Werkzeugwechsler / Turret
Category: Turning
Thanks for waking me up :)
It's even worse, not only - and _ got mixed up, it should have been:
net tool-change iocontrol.0.tool-change => sauter.0.toolchange
net tool-changed iocontrol.0.tool-changed => sauter.0.toolchanged
net tool-number iocontrol.0.tool-prep-number => sauter.0.newtoolnumber
Now Linuxcnc at least starts ok again. Let's see if I can get the turret move...
  • Beovoxo
  • Beovoxo
25 May 2025 09:47 - 25 May 2025 09:48
Replied by Beovoxo on topic Deckel FP4A Retrofit
Category: Milling Machines
Cabinet almost ready for sand blasting and paint.
  • knipknap
  • knipknap
25 May 2025 09:40
Replied by knipknap on topic MESA 7i76E burning out issue
Category: Driver Boards
So, change made, AC power component is gone and first small test job ran successfully. Hoping for the best :-). Thank you again!
  • mathwld
  • mathwld
25 May 2025 09:36 - 25 May 2025 09:40
Replied by mathwld on topic Retrofit Gildemeister ct40
I’m not sure I’m the winner:))).I hoped to have something more normal than this monster. Anyway when motor or driver will brake I will be forced to replace it.:-??I’m thinking to go with 7i92tm, 7i76, 7i73.My first ideea was to use ethercat but I will use veichi analog servo in the end. I don’t want to make a hibrid system and is my first retrofit.i have also installed a heidenhain ttl 5V on spindle I hope to make it work rigid tapping. I succed to find a plate clean for motor 1:1. This is actual motor
  • billykid
  • billykid's Avatar
25 May 2025 09:23
Replied by billykid on topic sanmotion rs2a03a0al0w00
Yes the encoder must be serial, I found these motors for €190 each, I will try to lower the price :-) they are 400 watt battery-powered absolute encoder 131072 pulse... I tried to set it in the drive and it is in the list.
  • Hakan
  • Hakan
25 May 2025 09:14
Replied by Hakan on topic help with ethercat and omron drives
Category: EtherCAT
Use it?
Use the hal file from here as starting point to get the servos going.
github.com/dbraun1981/hal-cia402/tree/main/example
  • rodw
  • rodw's Avatar
25 May 2025 08:56
Replied by rodw on topic LinuxCNC S-Curve Accelerations
You have not solved anything. If you want to use cia402 devices and the component, you need to read all at the beginning of the servo thread and write all at the end of it.
My thought is you have blindly copied a config. This is not plug and play, you need to build a config to suite your devices.
  • rodw
  • rodw's Avatar
25 May 2025 08:47
Replied by rodw on topic Linuxcnc wood lathe insufficient torque
Thanks rodw, I had ordered a DM542 from Steppersonline and it arrived today. Even with the 24v and 270OZ stepper and DM542 set at 3A I now have plenty of torque. Problem solved. I guess the TB6600s weren't up to the task.
Great to hear. I really don't know why people ever recommend TB6600's. They have been known to be cr@p for years.
There is more on the table yet! Have a look at the green and red lines here showing the torque difference between 24v and 48v for a 3.2 amp nema 23 stepper
www.moonsindustries.com/p/nema-23-standa...0-000004611110011244
The temperature rise was a max of 60 deg C (40 deg in the graph) so still at a very safe level.
  • Aciera
  • Aciera's Avatar
25 May 2025 07:53
Replied by Aciera on topic versa-probe vs probe_screen_v2.9
Category: Gmoccapy
They are from the same author but 'versa-probe' has not seen any updates for a number of years.
If you are using 2.9 then you should probably use 'probe_screen_v2.9'
  • Aciera
  • Aciera's Avatar
25 May 2025 07:46
Category: Turning
seems that you are mixing underscore with hyphen in the hal
sauter_us. VS sauter-us
  • Miller Turner
  • Miller Turner
25 May 2025 07:00 - 25 May 2025 07:19
Category: Turning
please forgive my stupidity.
after compiling I should have done the next step too I now see:
sudo halcompile --install --userspace sauter.comp
This seems to get me a bit further into debugging.
I get a Pin 'sauter_us_toolchange' does not exist error, which I don't understand yet.
as I did initiate it in the main hal file:
net tool-change iocontrol.0.tool-change => sauter_us_toolchange
Anyone has a clue of what I might be doing wrong?
  • Lcvette
  • Lcvette's Avatar
25 May 2025 06:24
Replied by Lcvette on topic config tool setter
config tool setter
Category: QtPyVCP
here:
  • Lcvette
  • Lcvette's Avatar
25 May 2025 06:20
config tool setter
Category: QtPyVCP
i cannot replicate, i get the value stored in both the var and the ui even through multiple restarts it remains correct.
Displaying 15571 - 15585 out of 16111 results.
Time to create page: 0.652 seconds
