  • HansU
  • HansU's Avatar
28 Feb 2025 21:22
Replied by HansU on topic My CAD / CAM research
Category: CAD CAM
SimplexCAM and eCam look quite the same. Couldn't find any differences so far except the price. Could you?
  • NtroP
  • NtroP's Avatar
28 Feb 2025 21:18
Replied by NtroP on topic Looking for advice retrofitting older CNC
Category: Driver Boards
Thanks for the information. One of the issues I'm running into is something to do with needing an "enable" signal or something. Still working through that.
I did the latency test. It came out around 150 nanoseconds if I remember correctly.
  • rodw
  • rodw's Avatar
28 Feb 2025 20:45
Laser Head Height Sensor – Looking for a Beta Tester
Category: Plasma & Laser
I would think a direct frequency output would be desirable as its readable
in real time by many different types of interface hardware.
Thanks Peter. What would be a good maximum frequency to work with? You will know a lot more than I do :)
  • MobiusToast
  • MobiusToast
28 Feb 2025 20:26
Replied by MobiusToast on topic StepperOnline A6 Servo
Category: EtherCAT
I made my own version of the CIA402 and custom home components for the A6 servo and put it on github -> github.com/CollinBardini/linuxcnc-a6-servo
The custom home component writes to a signal called "start-cia-homing" (from Rod's implementation), which kicks off homing in the CIA402 components. The CIA402 component then handles starting homing by writing to controlword and operation mode. While the servo is homing, the home component monitors the statusword until homing is complete.
I made it as barebones as possible to help others get started. I will write a README when I get time. For now, Rod's README is a good starting point.
  • Khan
  • Khan
28 Feb 2025 20:21
Replied by Khan on topic VFD RS485
VFD RS485
hello, for some reason delta put a sticker on for their high frequency drive VFD-H, i removed the sticker and it was actually a B drive VFD-B and i checked the manual it does support modbus,
28 Feb 2025 20:11
Replied by tommylight on topic Mesa hm2/hm2_7i96s.0: error finishing read
I deleted my post because I had the nic set to 10.10.10.10 and the ping times were quite wrong.
JT
That is what i was pointing out when the post disappeared on me! :)
  • Tniejadek
  • Tniejadek
28 Feb 2025 19:38 - 28 Feb 2025 19:43
Replied by Tniejadek on topic hot wire cutting
hot wire cutting
  • Tniejadek
  • Tniejadek
28 Feb 2025 19:29 - 28 Feb 2025 19:44
hot wire cutting
  The sensor controls the flow of current through the wire, a simple electronic circuit that operates over a wide range of voltages and gives a low state at the output when the current flow disappears. See diagram.The connectors on the left side 1 and J1 are connected to the wire and the connectors 1 and J2 on the right side are the output.
  • Tniejadek
  • Tniejadek
28 Feb 2025 19:21 - 28 Feb 2025 19:48
Replied by Tniejadek on topic feed bar in manual mode
Category: Gmoccapy
Thank you for the explanation, in the morning I checked with a friend on the milling machine and he has similar solutions, now I know that it is ok
  • JT
  • JT's Avatar
28 Feb 2025 18:43
JT
  • Aciera
  • Aciera's Avatar
28 Feb 2025 18:37
Kinematik Datei - Berechnung für B-Achse hinzufügen
Category: Deutsch
Die Konstruktion ist halt sehr nichtlinear da werden natürlich Schwenkachsenwinkel und die Position der Kugeltriebspindel auch nie in einem linearen Verhältnis zueinander verlaufen.
Wenn dir der open loop Betrieb nicht präzise genug ist dann könntest du eventuell die Encoderposition in einer hal-Komponente in die Motorposition des Kugeltriebes umrechnen und dann mit einem PID korrigieren.
Wie realistisch das in einer Regelschlaufe ist kann ich aber mangels Erfahrung nicht beurteilen.
  • Giovanni
  • Giovanni
28 Feb 2025 17:21 - 28 Feb 2025 18:06
Replied by Giovanni on topic NativeCam on LinuxCNC 2.9.3
Category: NativeCAM
Hello,
it seems you have not the folder to move.
Mybe you are in the wrong place.
If you list the folder by typing ls command, can you see the NativeCam folder listed?
  • LCR
  • LCR
28 Feb 2025 16:40
Problems with Lichuan Ethercat servo drive
Category: EtherCAT
If you aren't trying to get a gantry going don't look at what I've posted, it will only set you back.
  • LCR
  • LCR
28 Feb 2025 16:38
Category: EtherCAT
It is in the hal file I attached in a previous message. Search for probe1rising. Please note that this is a work in progress (or lack there of for a couple of weeks). I just wanted to show my hack to get a gantry going. Download all the files and search them. Be aware of the LinuxCNC underscore dash translation that occurs between various files. That's why my naming is poorly readable.
  • Philip Lydin
  • Philip Lydin
28 Feb 2025 16:09 - 28 Feb 2025 16:18
Replied by Philip Lydin on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
Why do i get that it cant find "cia402.0.probe1rising". Where does these pins get added? And in what directory should i have the .comp file?
Displaying 18286 - 18300 out of 18761 results.
Time to create page: 0.633 seconds
