  • Murphy
  • Murphy
22 Jan 2025 19:21
Replied by Murphy on topic Spindle location on the opposite side
Category: AXIS
LOL i think i need one trying to figure this out.
hal , test file and pawn attached
When i touch off g54 on X it drops the model down in the preview. Its thinking Im cutting from the top down and also the Z is inverted on the model. no matter what I do in fusion changing flipping axis or flipping the chuck placing its still the same.
  • spumco
  • spumco
22 Jan 2025 19:15
Replied by spumco on topic Spindle location on the opposite side
Category: AXIS
O.M.G.
I just watched your video.  @Aciera was right, as usual.
What you are pointing at is the tool path, not the pawn.  I've circled the 'pawn' in red.  What you are pointing at and claiming is the 'base' is, in fact the pawn's head after the cuts are made.
White = tool path (are tool will cut)
Black = pawn after material is removed
This still doesn't explain why positive SEARCH_VEL moves left during homing but we can circle back to that.
  • machinedude
  • machinedude's Avatar
22 Jan 2025 19:09
Replied by machinedude on topic Black Friday Deal got me :)
Category: Plasma & Laser
One other thing about a supported rotary set up is if you have a stock width that will fit the bore of your set up you can reduce you cutting distance compared to cutting from plate. when you look at things like duty cycle that's a big plus when your cutting @ 60% duty. On top you don't have to wear your slats down either, so you reduce your operating cost. so, it makes sense on small parts to keep this in mind.
when you get to a point where you are processing a lot of sheets the skeletons of the sheet add up to quite a bit of wasted material. this is just something you notice if you are around it all the time. i know time is money and that's why it happens but looking for savings can't be forgotten about at the same time.
  • papagno-source
  • papagno-source
22 Jan 2025 19:00
Actual master on Debian 10 was created by papagno-source
Category: Installing LinuxCNC
Hi.
One question:
The actual master , can compile on Debian 10 ?
  • Uthayne
  • Uthayne
22 Jan 2025 18:58
Integrating a BCL-AMP capacitive sensor to LinuxCNC
I'd be willing to test this out and provide some data. I currently use the BCL-AMP setup with QTPlasmac and while it works, it could definitely be faster in its tracking. The sensor outputs the nonlinear signal which is also noisy. After filtering (hardware and software), it works, however I feel as though it is not sensitive enough now due to being averaged and filtered so much that any abrupt changes in height will cause the nozzle to touch.
A cleaner, linear response signal could be the ticket, as I have fiddled with the PID parameters quite a bit as well as my Z axis velocities and accelerations and it is still not really where I'd like it to be.
Let me know how I can be of help.
  • spumco
  • spumco
22 Jan 2025 18:58
Replied by spumco on topic G33.1 synchronized tapping problem
Thank you for the tip.  I'll have a look this evening at index-enable.
If it makes any difference, I'm not using orient.comp for the main spindle... although I am using orient for the sub-spindle.
Main spindle is using caxis.comp but there aren't any references to index-enable in it other than a "//detect index-reset" statement.
If it is an index-enable issue, I wonder what would cause it to stay high?
Relevant HAL section for what it's worth:
# INDEX-ENABLE
net SPIN0-INDEX-ENABLE      <=> hm2_[MESA](BOARD).0.encoder.04.index-enable
net SPIN0-INDEX-ENABLE      <=> spindle.0.index-enable
net SPIN0-INDEX-ENABLE      <=> joint.2.index-enable
net SPIN0-INDEX-ENABLE      <=> pid.s0.index-enable
net SPIN0-INDEX-ENABLE      <=> pid.c.index-enable
  • spumco
  • spumco
22 Jan 2025 18:47
Category: AXIS
Can you post the g-code file as well as your HAL?
I'm not quite ready to suggest you call in a priest.
  • Aciera
  • Aciera's Avatar
22 Jan 2025 18:31 - 22 Jan 2025 18:38
Replied by Aciera on topic Homing an axis moves away from home switch!
Category: StepConf Wizard
You could sure make all of this SO much easier by simply providing the basic information you have been asked for.
  • Aciera
  • Aciera's Avatar
22 Jan 2025 18:23
Replied by Aciera on topic rotation plane around y axis in g18
Category: G&M Codes
with a run in place installation like yours you should be able to modify any kinematic file.
  • papagno-source
  • papagno-source
22 Jan 2025 18:17
Replied by papagno-source on topic rotation plane around y axis in g18
Category: G&M Codes
Hi.
For testing , is can modification trivkins kinematics for it , or is complicated.
  • Henk
  • Henk
22 Jan 2025 18:03
Replied by Henk on topic G33.1 synchronized tapping problem
I had a similar issue on one of my milling machines where I used a modified version of orient.comp.
At the time,not sure about latest version, orient.comp did not check the spindle encoder index each time it is enabled. I modified it so that it does, but at first I made a mistake that caused my modified comp to set the index enable pin for the spindle encoder all the time. This caused the same behaviour as described by you.
Check your index-enable pin while rigid tapping. It should go true and then false when the index is detected, the stay false until you initiate the next tapping cycle
Henk
  • Murphy
  • Murphy
22 Jan 2025 17:43 - 22 Jan 2025 17:58
Category: AXIS
Jog button is the virtual button on axis.
Looking down on the lathe from the top view in fusion. Tip is facing up. Tool can face and turn. Tool path is facing.
Iv just noticed something also what could be causing all of this :( my linuxcnc version is 2.10. That's not fully released yet.
Edit,
I read that link you posted ,that's very handy. But looks like I had everything setup right so it's not not either lol
  • spumco
  • spumco
22 Jan 2025 17:20 - 22 Jan 2025 17:40
Category: AXIS
When I loaded the linuxcnc pawn it came in as the earlier post , inverted When I made a model in fusion , it did the same thing. Messing around with fusion could it be something I'm doing wrong in fusion. The first pic is the tool orientation which looks wrong but it comes up correct in the tool path pic 2. Pic 3 is the tool orientation which I think is correct , but tool is wrong once in tool path , pic 4
Ok, starting to make a little more sense - you're getting bitten by F360's tool orientation mess and the actual program you loaded may be wrong, not your lathe.
The actual tool you plan to use looks like what?  Insert facing up (as you're looking down on lathe), tip towards centerline, and main cutting edge to left?  Or insert facing down?
EDIT -
Based on your screenshots, I think you've maybe got the spindle rotation wrong, which is why the tool appears to be reaching across the part centerline.
Here's a good explanation of tool orientation and how F360 spindle direction affects the toolpath and tool orientation display:
mgfx.co.za/blog/engineering-manufacturin...-cutting-directions/
  • spumco
  • spumco
22 Jan 2025 17:15
Category: AXIS
Yes, jog- to left, and jog+ to right is correct.
But a positive SEARCH_VEL moving left (Z-) is not right.
Something isn't right.  When you press "jog -" is that a physical button, or on the screen?
Can you post your HAL file?
  • Murphy
  • Murphy
22 Jan 2025 17:14 - 22 Jan 2025 17:15
Category: AXIS
Displaying 19711 - 19725 out of 19865 results.
Time to create page: 0.357 seconds
