  • ihavenofish
  • ihavenofish
11 Jan 2025 00:46
  • resmond
  • resmond
11 Jan 2025 00:28
Confusing error - I think from QtPCP / QtDragon_HD
Having trouble with uploading the report file... trying again.
File Name: linuxcnc.r...1-10.txt
File Size:11 KB
  • resmond
  • resmond
11 Jan 2025 00:23
AttributeError: 'Info' object has no attribute 'MIN_SPINDLE_0_SPEED'. Did you mean: 'MIN_SPINDLE_SPEED'?
I've added instances of each setting in several places, so I don't understand.
I'm attaching my .ini and HAL file plus the error report.
File Name: 7i95_Download.ini
File Size:5 KB
File Name: main5.hal
File Size:9 KB
File Size:9 KB
File Size:5 KB
File Size:5 KB
File Name: linuxcnc_i...1-10.txt
File Size:4 KB
  • vre
  • vre
11 Jan 2025 00:22
Replied by vre on topic Mesa modbus and pktUart
Category: Other User Interfaces
With this config for mb2hal i have a working system
[TRANSACTION_00]
LINK_TYPE=serial
SERIAL_PORT=/dev/ttyS0
SERIAL_BAUD=19200
SERIAL_BITS=8
SERIAL_PARITY=none
SERIAL_STOP=1
SERIAL_DELAY_MS=5
MB_SLAVE_ID=1
#address here is in DEC base
FIRST_ELEMENT=129
PIN_NAMES=01,02,03,04,05,06,07,08,09,10,11,12,13,14,15,16
HAL_TX_NAME=in
MB_TX_CODE=fnct_03_read_holding_registers
[TRANSACTION_01]
MB_TX_CODE=fnct_16_write_multiple_registers
FIRST_ELEMENT=1
HAL_TX_NAME=out
MAX_UPDATE_RATE=0.0
And i have this config for mesa modbus.
Is that correct ?
#define MAX_MSG_LEN 16   // may be increased if necessary to max 251
static const hm2_modbus_chan_descriptor_t channels[] = {
/*  {TYPE,    FUNC, ADDR,   COUNT, pin_name} */
    {HAL_S32, 3,  0x0081, 0x07,     "in"},
    {HAL_S32, 16, 0x0001, 0x07,     "out"},
  • PCW
  • PCW's Avatar
10 Jan 2025 23:35 - 11 Jan 2025 00:01
Replied by PCW on topic 7i96s Questions
7i96s Questions
Category: Driver Boards
That looks OK
Where things go bad with bare FPGA inputs is that say a VFD is running and an encoder wire connects
to frame ground accidentally, well unfortunately this frame ground has ~1 usec 1V negative high current
spikes  from the VFDs 350V square wave output and finite inductance of the frame ground to earth ground.
These spikes will easily short the input clamp diodes. ("Ground" is just a tapped inductor for high frequencies)
The encoder pin/parameter specifications are in the hostmot2 manual page:
man hostmot2
It may be that firmware that better matches your application can be made
(MPGs are better with MPG encoders rather than motion encoders because
MPG encoders support 1X mode which works better with MPGs having detents)
  • stirra
  • stirra
10 Jan 2025 23:34
Replied by stirra on topic Missing link in homing LC10E
Category: EtherCAT
Forgot to say that the lcec.0.0.home-mode 34 should be changed to the home mode you want. 34 is just handy for testing without external switches connected (34 just returns to index).
  • stirra
  • stirra
10 Jan 2025 23:32
Category: EtherCAT
After many hours of studying homing.c, cia402.comp, cia402_homecomp.comp and various forum posts, I finally found the last key to making LC10E drive homing work.  Here is my summary of all the changes needed to RodW's example custom homing configuration.  I can now click "Home All" in Axis and have it do a proper mode 6 home.  It still leaves all the axes with "H" in the preview window (rather than the round "survey marker" symbol), but MDI works and everything else seems to function normally.
Changes to get Lichuan LC10E homing working:
1. cia402.comp line 240
      change (statusword >> 10) to (statusword >> 12)
2. ethercat-conf.xml
      add to pdo 1600 section the lines:
           <pdoEntry idx="6098" subIdx="00" bitLen="8"  halPin="home-mode" halType="u32"/>
           <pdoEntry idx="6099" subIdx="01" bitLen="32" halPin="home-hi-speed" halType="u32"/>
           <pdoEntry idx="6099" subIdx="02" bitLen="32" halPin="home-lo-speed" halType="u32"/>
           <pdoEntry idx="609A" subIdx="00" bitLen="32" halPin="home-acc" halType="u32"/>
           <pdoEntry idx="2005" subIdx="24" bitLen="16" halPin="home-timeout" halType="u32"/>
3. cia402.hal
       after loadrt's add lines:
           setp lcec.0.0.home-mode 34
           setp lcec.0.0.home-hi-speed 50000
           setp lcec.0.0.home-lo-speed 50000
           setp lcec.0.0.home-acc 100000
           setp lcec.0.0.home-timeout 5000
      after # homing signals change nets x-home* to:
           net x-home-request joint.0.request-cia402-homing   cia402.0.home joint.0.index-enable
           net x-homing       joint.0.is-cia402-homing       cia402.0.stat-homing
           net x-homed       joint.0.cia402-homing-finished  cia402.0.stat-homed
4. cia402.ini
       in [joint_0] be sure:
           HOME_SEQUENCE = 0 (or whatever sequence number is appropriate)
           HOME_USE_INDEX = YES
           HOME_SEARCH_VEL = 0
           HOME_SEARCH_VEL = 1 (or any non-zero value)
I hope this helps somebody else.
-- Ralph
  • RNJFAB
  • RNJFAB
10 Jan 2025 23:31
Replied by RNJFAB on topic QtPlasmaC estop stuck
Category: Plasmac
Thanks Guys,
Changed settings to reflect e-stop as a button and i'm able to select it now.
Still have a blank or other shadow in the box where you would normally see what you have loaded. Not sure why.
An now that everything has been double and triple checked, i can't form any connection to the motors.
  • rodw
  • rodw's Avatar
10 Jan 2025 22:36
Replied by rodw on topic 7i96s Arc Voltage + Encoder Fault
Category: Plasma & Laser
When I turn on QTPlasmaC the value of Arc Voltage is 145.
The encoder velocity pin seems to be working fine on halshow.
Sounds like you have not correctly calibrated qtplasmac for your THCAD settings
The THCAD 0 volt frequency should be what you observe on the encoder velocity pin give or take some bouncing around.
This offset needs to be entered in qtplasmac.
If you read the QTplasmac docs, there is a link to a calculator to determine your settings.
  • slowpoke
  • slowpoke
10 Jan 2025 22:27
Replied by slowpoke on topic 7i96s Questions
7i96s Questions
The first P1 encoder is  encoder 1 so the position would be:
hm2_7i96s.0.encoder.01.position
and the most important parameter for that encoder would be:
hm2_7i96s.0.encoder.01.scale
After your warning (thanks) I was going to solder up a little proto-board with some protection diodes for the negative rail. Then decided to just do a quick and dirty actual PCB. I will obviously be careful when connecting, and to your point chassis ground is not zero volts. I inserted a 100r series resistor and TVS, please see attached and let me know if you think this is adequate?
I'm ready to press the send button for a free PCB, but I can tweak if you have any suggestions.
Re: hm2_7i96s.0.encoder.01.scale, can I assume that's a float value? Is there documentation available for the finer details of the 7i96s_p1encd.bin?
This browser does not support PDFs. Please download the PDF to view it: Download PDF
  • rodw
  • rodw's Avatar
10 Jan 2025 22:23
Replied by rodw on topic Mach3 machine, some questions.
Category: CNC Machines
You say LinuxCNC is way way better than Mach 3.
How so?
A work in progress by a user in NZ but try commanding a pallet changer on a horizontal 5 axis machines like this in Mach3.
This machine fills a shed.
Many people use Linuxcnc to retrofit big commercial machines because of its flexibility and extensibility.
Here the user had hit the limits of using classic ladder and wrote a custom Linuxcnc C component to do this. A week earlier, he knew nothing about programming and is now loving it!
  • rodw
  • rodw's Avatar
10 Jan 2025 22:09
Solved - LinuxCNC does not work with new Delta ASDA-A2 drive
cool.
downside to the ethercat is its ONLY ethercat. i wish it has pulse as well. would be more versatile.
It does if you use an Ethercat stepper driver. There are many. I use rtelligent ECT86
10 Jan 2025 22:08
Asservissement de la vitesse de broche avec une carte MESA 7i96s
From google translate
Is it possible to configure a speed-controlled spindle with a Mesa 7i96s board using the spindle encoder as speed feedback?
does not make much sense....so
VFD or Servo?
With VFD, yes, 7i96S can be used as it has the 0-10V control and has encoder inputs.
  • scotta
  • scotta's Avatar
10 Jan 2025 22:05
Hi, the outputs on the NVEM are not an output voltage like your thinking. They are as shown in the diagram attached. Basically a switch sinking to ground.
10 Jan 2025 21:47
Replied by Cant do this anymore bye all on topic LinuxCNC on Raspberry Pi 5
Category: Installing LinuxCNC
These are Linux kernel patches, so I guess where the kernel devs hangout.
Displaying 19921 - 19935 out of 21882 results.
Time to create page: 0.389 seconds
