  • langdons
  • langdons's Avatar
07 Jan 2025 19:18
Replied by langdons on topic Mach3 machine, some questions.
Category: CNC Machines
Toroidal transformers are REALLY expensive.
If you replace the transformer with a switching power supply (which I do not recommend), keep or resell the transformer.
  • Unlogic
  • Unlogic
07 Jan 2025 19:09
Calculating step length/space timings for Delta B3 servo drives
Huge thanks for the explanation and calculation PCW!
I'm using differential wiring, should have mentioned that in the first post
  • blazini36
  • blazini36
07 Jan 2025 18:54
Replied by blazini36 on topic Building and configuring a stmbl v5
Category: Driver Boards
Would probably be cool if they added support for the DMM servo encoder protocol since they're relatively cheap. It's not "open" but I have the documentation for it.
  • blazini36
  • blazini36
07 Jan 2025 18:44
Replied by blazini36 on topic Flexible GUI
Flexible GUI
Category: Flex GUI
Yeah that looks much nicer than the tabwidget when it's run....
The frames on the list and plain text editor aren't visible in the dark-touch theme. For now I'm just sticking them on frame widgets because they blend in with the background otherwise.
  • Martin.L
  • Martin.L
07 Jan 2025 18:43
Exercise: Turn on output led on EL2809 when machine is turned on
Category: EtherCAT
Thank you all, I have missed the HAL basic document somehow, the manual is really tough to start with. I have some questions related,
1 - Whats the difference between "lcec.0.OUT.dout-0" and "lcec.0.OUT.dout-0-invert" they have the same behaviour
2- I also have a EL 1809 that is rated as input current "typically 3 mA (EN 61131-2, type 3)" Is it usually considered a min or max data? can I feed it with more current or should I limit it?
  • DaZeller
  • DaZeller
07 Jan 2025 18:31 - 07 Jan 2025 18:39
New installation only boot with "nomodeset"
Hi there,
I've installed LinuxCNC 2.9.3 on a Dell Optiplex 755 with Intel Pentium Dual-Core and on-board GPU.
GRUB is working fine, but I'm only able to boot with "nomodeset" option. Otherwhise the pc freezes with black screen, no switch to console possible, just hard switch of is able to get out.
Now with "nomedeset" I'm able to use the system, but with quite poor grafics. I'd be glad if someone could assist me in finding the issue and fix it.
I'm looking forward your suggestions to deep dive the issue.
BR DaZeller
07 Jan 2025 18:25
Replied by tommylight on topic Gould Gettys Servo Amplifier Drifting User Guide
Do NOT fix drift!
All analog servo systems will have a bit of drift at 0V input.
Wire the control, it takes care of it when encoders are in use.
  • RogEnk
  • RogEnk
07 Jan 2025 18:21
probe basic - toolpath/file preview loading error
Category: QtPyVCP
Is there a reason why to not install SSH Server?
I usually install it and actually use it for any config or GCode edits using Visual Studio Code editors ssh function.
  • JT
  • JT's Avatar
07 Jan 2025 18:18
Replied by JT on topic Mesact 2 Setup
Mesact 2 Setup
Category: Configuration Tools
Using LinuxCNC Bookworm. Have downloaded file from packages.debian.org/sid/python3-distro. Not sure what to do with it.
Also tried adding linuxmint to Synaptic repositories. Not doing it correctly.
Some guidance would be appreciated.
Thanks.
What are you trying to do? Mesact is not in debian packages.
JT
  • rmavalente
  • rmavalente
07 Jan 2025 18:10
Hello Mates,
my milling machine is based on 3 N360 / A121 (I guess) servo amplifiers from gould. I believe they need a little adjustment to reduce drift (about 12 to 16V whe 0V at analog in). Thing is I can not find their manuals anywhere! Gould gettys has been dissolved, their tech support could no care less about my request. There is a guy selling one manual on ebay, but he will not ship to Brazil. Can anyone help?
Greetings!
  • JT
  • JT's Avatar
07 Jan 2025 18:09 - 07 Jan 2025 18:09
Replied by JT on topic Flexible GUI
Flexible GUI
Category: Flex GUI
I just added the dynamic properties section to the docs and put links to it where dynamic properties are mentioned
gnipsel.com/linuxcnc/flexgui/property.html
JT
  • Aciera
  • Aciera's Avatar
07 Jan 2025 17:59
  • gbsd86
  • gbsd86
07 Jan 2025 17:51
Replied by gbsd86 on topic Mesact 2 Setup
Mesact 2 Setup
Thanks.
  • Martin.L
  • Martin.L
07 Jan 2025 17:39
Replied by Martin.L on topic Raspi5 + VH229 no HDMI0 audio
Category: Installing LinuxCNC
Hi, still I can't figure out whats the issue, sigh
Displaying 20521 - 20535 out of 21671 results.
Time to create page: 0.383 seconds
