  • Rune_cnc
  • Rune_cnc
27 Dec 2024 14:20
Replied by Rune_cnc on topic Boxford 260 CMC 1989 mod
Category: Milling Machines
Yeah just showing off the machine.Im putting mesa card as replacement. Do you know if there is a retro look user interface. For the linuxcnc.
  • hans48
  • hans48
27 Dec 2024 14:14
Replied by hans48 on topic Ein Neuling sucht Hilfe
Category: Deutsch
Hallo
So habe ein Foto gemacht von den Zeilen wie ich das reingeschrieben habe und von der Fehlermeldung. Vielleicht findet wer den Fehler.
  • B.Reilly01
  • B.Reilly01
27 Dec 2024 14:02
Replied by B.Reilly01 on topic mill 4th axis
mill 4th axis
This is really a big big question. I've noticed most of the commercial 4th axes are worm gears driven by servos in the 30:1 to 100:1 range. That said, I've read good things about harmonic drives driven by servos or steppers. The biggest concern I had when deciding on my 4th axis was backlash. Harmonic drives and commercially built worm drives are really low backlash. I've always favored servos for their built in feedback, but steppers can also run encoders. I've never been a fan of open-loop axes of any sort.
  • Lcvette
  • Lcvette's Avatar
27 Dec 2024 13:46
Replied by Lcvette on topic To Probe Basic from Gmoccapy
Category: QtPyVCP
post up your error message
  • CaspianCmonster
  • CaspianCmonster
27 Dec 2024 13:36
Replied by CaspianCmonster on topic Tool setter setup
Tool setter setup
Category: Basic Configuration
thank you, that is clearly something I need to fix :)
It would be really nice if I could just start with the demo files and adjust them to my machine's specs but I haven't figured out how to get that to work.
Luke
  • Aciera
  • Aciera's Avatar
27 Dec 2024 13:25 - 27 Dec 2024 13:30
Skew correction/perpendicularity correction (millkins or millkins_xyz)
So my approach (which may be wrong though) would be to start end the kinematic chain with a matrix for the skew (also called 'shear') which has the form:
The inverse looks the same with the shear elements (ie lambda and mu) negative
  • B.Reilly01
  • B.Reilly01
27 Dec 2024 13:16
Adding 4th Axis to LinuxCNC with 7i92/7i77/7i76, Use absolute encoder or incr?
So I'm adding a Tsudokama RZ-160 rotary as a full 4th axis.   I'm replacing the existing TPC-JR with a standalone drive and wiring everything direct.  I have a good handle on most of this, however I'm left with the choice in the title.  The encoder is an absolute encoder wired directly to the drive.  The drive then either passes along the serial absolute position OR has outputs for a simulated incremental encoder.  I know how to wire the incremental, it's the same as my other 3 axes, and can get wired directly into "Axis 3" on the 7i77 board.  However, the RZ-160 of course does not have homing switches (that I'm aware of), so repeating the same location with the incremental encoder output through a power cycle may prove challenging.  At the very least, I'd have to break out an indicator and indicate in the 4th if I understand correctly.  With the Absolute encoder, in theory, I'll always know where the rotary table is at.  I don't know that that is accurate, and it may only remember location within 1 rotation of the motor, which is 1/60th a rotation of the table.  Is that accurate?  Can the PSO /PSO output be wired into the 7i77 SSerial port easily?  Is it worth it?How would you set up your 4th axis given this choice?  My drive is a Sigma II Yaskawa drive (SGDM-04ADA, same as what is in the TPC-JR), the servo is a Sigma II (SGMPH-04A1A-TF11).
Thank you
  • Aciera
  • Aciera's Avatar
27 Dec 2024 13:06 - 27 Dec 2024 13:11
For an easier start on how to use jupyter notebook and ipython to derive the kinematic linked above you can directly load the notebook used to create it and the documentation to study/modify:
github.com/Sigma1912/LinuxCNC_Demo_Confi...0Kinematics%20.ipynb
This contains all the python code blocks that handle the math.
  • nicton
  • nicton
27 Dec 2024 13:02
Is the encoder feedback loop inside 7i92 (5ABOB_Enc)?
Category: Driver Boards
I want to make a machine with two 7i92 (configuration 7i92_5ABOB_Enc), at first I decided that one would stand on the machine and collect signals from the rulers and sensors, the second in the control cabinet and output step/dir, i.e. it turns out that feedback from the ruler goes through the computer, but then I came across information that mesa is not just an input/ conclusion, it almost recycles g-codes, i.e. hypothetically, the encoder feedback control loop can be closed inside mesa, and it is not advisable to break it, is this the case, or does the circuit in any case go through the core, and in mesa only the encoder counter and the step generator?
  • slowpoke
  • slowpoke
27 Dec 2024 12:46
Replied by slowpoke on topic 7i96S MPG input
7i96S MPG input
Just a side question: Why do you need a separate Controller for the manual operation?
Isn*t everything possible to do in the LInux CNC. Slaving axis, Using MPG to move the axis manually?
 I think all of the functionality is available in LinuxCNC, however I developed a little touchscreen GUI for the existing ELS and I really like the ease of use when using the lathe in manual mode.
  • MaHa
  • MaHa
27 Dec 2024 12:28
Replied by MaHa on topic Tool setter setup
Tool setter setup
The path for python is missing in the ini
linuxcnc.org/docs/stable/html/remap/rema...emap:embedded-python
[PYTHON]
# where to find the Python code:
# code specific for this configuration
PATH_PREPEND=./
# generic support code - make sure this actually points to Python-stdglue
PATH_APPEND=../../nc_files/remap_lib/python-stdglue/
# import the following Python module
TOPLEVEL=toplevel.py
# the higher the more verbose tracing of the Python plugin
LOG_LEVEL = 0
  • RNJFAB
  • RNJFAB
27 Dec 2024 11:55
Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
Category: Show Your Stuff
Yeah, was a bit sick at the start of the year and had 6 months off work, not much happened at this time, just me thinking about this new build.
Very busy otherwise, I work full time, and I cut steel signs, and I run a small mowing business, and I work for my brother in his fabrication workshop, AND I'm still building my own house.
New build is coming along nicely.
Machine is built, most mechanical fitout complete, and started on the wiring tonight.
Pics to follow
  • macrimarco001
  • macrimarco001
27 Dec 2024 11:28
Newbie looking for a hardware configuration based on Raspberry Pi
Hello, it's been a while... i hope you had a merry Christmas. It sounds awesome to me. But i think it will take a while because i am preparing my last exams. Maybe there's a chance i may already know the UniCal professor you're talking about, if he's in my department (DIMES).
Hope to hear you soon. Sorry for the day in my reply, but I'm studying and working too.
Thank you so much :)
  • CaspianCmonster
  • CaspianCmonster
27 Dec 2024 11:24
Tool setter setup was created by CaspianCmonster
Tool setter setup
Hi all, like many people out there I am trying to get a tool setter setup.
I am working from the example files but I think I have issues with file/folder mapping among other problems.
I get a startup error usr/share/axis/images/axis.ngc: pycall(remap.change_prolog) failed
I found a similar issue in my searches but haven't been able to figure it out.
many thanks
Luke
  • abdulasis12
  • abdulasis12
27 Dec 2024 11:18 - 27 Dec 2024 11:21
Hi
Thank you for fast reply.
Ok, I will try using the URLs you provided to study further. Maybe one day, I might be able to create it on my own.
Even though the chances are slim with my basic knowledge , I will give it a try.
The way you provided links for me to continue learning is really great I get to learn new things all the time.
Thank you so much for always helping me, from the first day I started using LinuxCNC until now (although I’ve stopped using Mint). It has been amazing!
forum.linuxcnc.org/9-installing-linuxcnc...ewbie?start=0#278679
Super Thanks  Tommylight, RodW, and you Aciera.
second thanks : Online translator
Asis
Displaying 21316 - 21330 out of 21693 results.
Time to create page: 0.459 seconds
