  • BigDo
  • BigDo
07 Aug 2026 06:04
NativeCAM 2.0b — Python 3 & GTK3 port for LinuxCNC 2.9 / Debian 13 Trixie
Category: NativeCAM
You're right. That was the cause of the error.
Thank you very much.
  • Todd Zuercher
  • Todd Zuercher's Avatar
07 Aug 2026 05:44
Replied by Todd Zuercher on topic Ver 10 NEW install
Ver 10 NEW install
Remeber, usernames and passwords are case sensitive. (Almost everything in Linux is case sensitive.) Is it possible that a glitchy keyboard is messing with your username or password inputs? (If you got a double or dropped character when inputting them either at install or login later.) Is the caps lock or num lock key screwing with your inputs? (Linux tends to default to num lock off at start up.)
  • Aciera
  • Aciera's Avatar
07 Aug 2026 05:20 - 07 Aug 2026 08:16
Replied by Aciera on topic PUMA 200 Robotarm and some Hal/INI issues
i made a vismach model.
Looks like a lot of AI generated stuff so I'm not going to bother with it. Frankly, if you need to rely on AI to build the vismach model then you are most likely better off without it because working with an incorrectly constructed vismach model is only going to make things a LOT more difficult for you.
Generally I think you are trying to get around the tedious legwork of wrapping your head around the basic concepts of how those modified DH parameters work so my advise would be to get out the old paper and pencil and start from the beginning.
  • MeyerGreg007
  • MeyerGreg007
07 Aug 2026 04:47
Raspberry Pi5 Micro SD card wear and tear? was created by MeyerGreg007
Greetings,
This is my first post so I'm hoping I done break any protocols...
I have converted a 1959 vintage Centec AutoMill (3 axis horizontal milling machine) to CNC using LinuxCNC 2.9.10 Debian 13 Trixie PREEMPT-RT on a Raspberry Pi5 with 8 gig of ram, directly controlling three GeckoDrive 201x stepper drives via the Pi's GPIO pins. It is working very well as the Gecko 201x works with 3.3 volt logic and I very pleased with its performance. No need for a MESA board or any kind of logic level shifting.
I recently read that the Micro SD cards used in the Pi are not well suited to handle lots of read/write activity, and over time will fail.
Can anyone tell me if LinuxCNC does a lot of writing/reading of things like temporary files during the running of the machine?
TIA   Greg
  • Becksvill
  • Becksvill
07 Aug 2026 04:11
Replied by Becksvill on topic Conversational CAD CAM
Category: O Codes (subroutines) and NGCGUI
for those who are interested here is a new config that has the simulated motion in it
it's based off the lathe fanuc axis gui that linuxcnc comes with
you have two options.  you can just unzip and copy and paste the sim config. into your linuxcnc configs folder and then use the config picker to run it.  that takes 2 min and like 10 mouse clicks.  for those who want to understand it and hopefully add this to their own machines there is the manual option where you can copy the right files into the sim config and actually understand it.
i just used Claude Ai for the whole project and got it to spit out the text file that is in the config.  here is the first bit from the text file.   cheers Andrew
File Name: big-blue-sim.zip
File Size:333 KB
 RUNNING THE BIG BLUE CONVERSATIONAL TAB ON A SIMULATED LATHE
 How to graft it onto LinuxCNC's own  sim / axis / lathe-fanucy  sample config
 Written 2026-08-07.  Every step below was built and tested before writing.
WHY THIS FILE
The big-blue-lathe config drives real servos through a Mesa 7i92 and needs a
ClassicLadder E-stop chain, gearbox solenoids and sensors to even come out of
E-stop.  A friend with no hardware cannot jog it or run a program.
So instead of shipping the machine config, we bolt the CONVERSATIONAL TURNING
TAB onto a stock LinuxCNC sim.  You get a machine that homes instantly, jogs,
runs programs, does manual tool changes and simulates a spindle - and the
Turning tab writes exactly the same G-code it writes on the real lathe.
The base is  sim/axis/lathe-fanucy  rather than  sim/axis/lathe , because
lathe-fanucy already ships the T-word / wear-offset remap plumbing that big
blue depends on:  the REMAP = T line, the [PYTHON] section, remap.py and
toplevel.py.  That is most of the fiddly part done for you.
 TWO WAYS TO DO THIS - PICK ONE
  ROUTE A - USE THE READY-MADE CONFIG.  Two minutes, nothing to type.
  If you have  big-blue-sim.zip , everything below has already been done for
  you.  The whole finished config is in it.  On the test PC:
      mkdir -p ~/linuxcnc/configs
      unzip big-blue-sim.zip -d ~/linuxcnc/configs/
      linuxcnc ~/linuxcnc/configs/big-blue-sim/big-blue-sim.ini
  That is it.  Skip to STEP 4 - RUN IT.
  You do NOT need to create the lathe-fanucy sample config first.  The zip
  already contains its remap.py and toplevel.py, which is the only thing that
  was ever taken from it.
  ROUTE B - BUILD IT BY HAND.  Steps 1 to 3 below.
  Do this if you have not got the zip, or if you want to understand what is
  in it, or if you are redoing this on a future LinuxCNC version.
  The only difference between the two routes is the NAME.  Route A gives you
  and Route B gives you
      ~/linuxcnc/configs/lathe-fanucy/lathe-fanucy.ini
  with identical contents.  Wherever this file says "lathe-fanucy.ini" below,
  read it as "whichever of those two you have".
  NOTE FOR THE BIG BLUE MACHINE ITSELF: copying this text file into the
  big-blue-lathe config folder does nothing on its own - it is only a set of
  instructions.  The sim is a SEPARATE config directory.  Nothing here changes
  or touches the real machine's config.
  • aydinsen
  • aydinsen
07 Aug 2026 02:50
06 Aug 2026 21:14
Replied by tommylight on topic Driving analog galvo scanner
Category: Driver Boards
@farley,
No double posting.
  • cmorley
  • cmorley
06 Aug 2026 20:27
  • farley
  • farley
06 Aug 2026 20:04
Replied by farley on topic Driving analog galvo scanner
Hi, I saw your post about the SL2-100 interpreter — I'm an FPGA engineer working on decoding the same protocol and finding solid documentation is really tough. Would you mind sharing how far you got, or any pointers on the frame structure / encoding you figured out? Totally understand if it's not shareable. Wishing you smooth progress on the project either way!
06 Aug 2026 19:37
Replied by tommylight on topic Ver 10 NEW install
Ver 10 NEW install
Just re-read this topic ... twice, i am confused on many levels...
If you want just to test use the live version, do not install it.
And that never asks you for a "password" ... that is a thing since the inception of personal computers.
  • CNC_Manni
  • CNC_Manni
06 Aug 2026 18:44
Category: NativeCAM
F-WORD = F = feed rate, it can not have a negative value as far as i know, although there might have been talks about that for EDM probably, but i do not recall the end result.
06 Aug 2026 18:41
Remora on NVEM board - unable to upload new configs
@CNC_Manni
This is the third post with the same subject, although one is in German, abd this one has more info, so do not do multiple posts, that makes a mess for us and for whoever tries to help you.
06 Aug 2026 18:38
Replied by tommylight on topic NVEM V5 RT1052
NVEM V5 RT1052
This is a duplicate of this topic but in German language.
forum.linuxcnc.org/42-deutsch/59075-nvem-v5-rt1052#348502
Displaying 2146 - 2160 out of 11240 results.
Time to create page: 0.383 seconds
