  • unknown
  • unknown
21 Nov 2025 00:10
LinuxCNC 2.9.3 .xz image for RPi 5 is not available in the ISO directory
No idea why it was removed.
I've only been involved in creating the images from 2.9.4 and the above experimental image.
The 2.9.4 image is based on Bookworm & 2.9.7 is Trixie based.
  • Jensner
  • Jensner
21 Nov 2025 00:00
Aufschaukeln mit JMC iHSS60-36-30-21-38 in Verbindung mit Linear Encodern
Category: Deutsch
Becouse of this speed-problem i had a look at the documantation for the INI.
There are many more questions, but maybe I found some answers.
  •  In [TRAJ] i lowered the DEFAULT_LINEAR_VELOCITY and MAX_LINEAR_VELOCITY
    By the way, at the moment I do not check exactly how there where Velocity and acceleration-variables in TRAJ, AXIS_ and JOINT_
  • One more thing i found, was the DEADBAND = 0.0
    In the documentation it means that this is the tolerance-variable for the PID if the position is between the tolerance.
    So in my config this is 0.0 this should be to less an leads to "Servo Hunting"
  • 4ashishkr
  • 4ashishkr
20 Nov 2025 23:25
Thanks for reply.
Any idea why it was removed ?
I have being using it for long. Any known alternative link for the same ?
20 Nov 2025 22:52
Replied by tommylight on topic How do you vote in the hardware survey?
It got to 3 now.
I also have the option to reset the vote and to change it. After changing need a refresh to be able to change again.
  • unknown
  • unknown
20 Nov 2025 22:47
Replied by unknown on topic How do you vote in the hardware survey?
That would be correct, could it be, I guess only admins can reply to the topic, only admins can vote ?
20 Nov 2025 22:44
How many votes?
It is stuck at 2 for the last 2 hours.
  • unknown
  • unknown
20 Nov 2025 22:41
I can see the poll results, but for the life of me can't see a way to vote.
Perhaps a screenshot may help some of us Luddites. ;)
  • unknown
  • unknown
20 Nov 2025 22:31
Replied by unknown on topic linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
Not the best suggestion if the user wants to be able to upgrade to 2.9 or 2.10.
Unless a user specifically wants to use the parallel or has an ancient PC it may not be the best suggestion .
It would also be worth noting that Debian wheezy is end of life, updates haven't been available for a few years. Also wheezy had Python2 so the upgrade path for Linuxcnc is rather limited.
So when recommending the Debian Wheezy ISO it would be best to mention these facts.
  • kn612
  • kn612
20 Nov 2025 22:18
Replied by kn612 on topic Servo Driver Plasma Retrofit
Category: Plasmac
That fixed it.
Are there plans to develop pnnconf further for support for the 7i97t?  All the manual changes have been working great.
  • rodw
  • rodw's Avatar
20 Nov 2025 22:02
Replied by rodw on topic CNC AXIS IN PARKING MODE
You should be able to create  component that sets feedback = commanded pos when the handwheel is engaged. the cia402 component does this...
20 Nov 2025 19:54
Replied by tommylight on topic Servo Driver Plasma Retrofit
Category: Plasmac
To replace the above, in the text editor hold down CTRL and press H, it will open two fields at the bottom, type inm in the top one and inmux on the bottom one, then click replace all, click save, do NOT close the text editor, first test and make sure the config works, then close.
20 Nov 2025 19:49
Did you check above the post?
I kept looking ... :)
  • PCW
  • PCW's Avatar
20 Nov 2025 19:48 - 20 Nov 2025 19:56
Replied by PCW on topic Servo Driver Plasma Retrofit
Category: Plasmac
That's an error in the configuration utility, you can fix it by globally replacing
"inm" with "inmux" in the hal file.
  • kn612
  • kn612
20 Nov 2025 19:43
Category: Plasmac
Great info as always. Thank you.
Setting up inputs now, getting an error on startup again related to inputs.  It states input pins do not exist.  Is this a common problem? Did I miss a simple step on configuring the 7i97t?
Displaying 11176 - 11189 out of 11189 results.
Time to create page: 0.352 seconds
