  • schnellmued
  • schnellmued
13 Nov 2024 20:34
Replied by schnellmued on topic Mesa 7i96s / Network no longer working
Category: Driver Boards
Sounds like something has gone wrong with the Ethernet section of the 7I96S card.
It should be repaired/replaced under warranty, Contact Mesa or your dealer for instructions
Ok, i fear that too. But i will hook it to this Jtag debugger thingy at work, just for curiosity :)
Will post if i got some insights ..-
schnellmued
  • schnellmued
  • schnellmued
13 Nov 2024 20:31
That looks OK.
Did you use the Network Manager to set up the network?
If yes, you need to check the "use this connection for local ..... " not sure what exactly it says as i am on the phone.
That is for wired network only, IPV4 settings.
You also have a wireless network and if that connects before the Lan, it will send all trafic through wifi, if the above is not set for wired network.
I think i used networkmanger, but iam also able to set the ip with ifconfig  :)
The Ip Stack will notice 10.10.10.10 is on the same subnet  as 10.10.10.2/24, so it will allways send packets for 10.10.10.0/24 to that interface. (unless statics routes exist)  It also worked for like >1 year in this config and it still works for the lathe mesa with the same ip as the "broken" one. I also tried some other Laptop, with no luck
schnellmued
  • Gluca
  • Gluca
13 Nov 2024 20:18
Replied by Gluca on topic Remora rp2040 compile issues.
>>are you compiling with release or debug?
I'm just compiling with this sequence:
/tmp$> cmake -DPICO_SDK_FETCH_FROM_GIT=on ./Remora-RP2040-W5500-main
/tmp$> make
>> idk which one but people report trouble with one
Explain me better ...
  • AA
  • AA
13 Nov 2024 20:17
Multiple controller boards was created by AA
Greetings,
I'm wondering,  it's it possible to connect a couple of controller boards  (like Arduino) to LinuxCNC, i.e.one for XYZ, anothe for ABC, one more for adding a turret or a double spindle..?
Why not, it seems to me there must be a way now as computers got super processing powers.
If yes, is there a specific controller board type(s) that can be connected together? Maybe several types may inter communicate with LinuxCNC and to themselves too?
Or maybe connect a number of these boards to a number of servo motors and drivers and other boards to other stepper motors and drivers?
Exactly, I am just at a beginner, trying to figure out how to make my super fancy machine., so do you think my dreams are valid, or can be true soon?
Is there some hardware that I have to buy prior to others, you know in order to plan the priorities and budget, but make sure I want to build the fancy CNC?
I'm sure there are many like me.
Thanks,,
Byes
  • juliankoenig87
  • juliankoenig87
13 Nov 2024 20:05
Replied by juliankoenig87 on topic Suggestion for a PCI EPP card for 7i43
Could it be a FAN5308MPX?
13 Nov 2024 20:00
Replied by tommylight on topic Pipe Cutting Plasma CNC
Yes it is mine, it is the old one with my full name as channel name. Plenty of stuff there also, wanted to transfer videos to new channels but there is no easy way.
My other channels just in case:
www.youtube.com/@toma.cnc1/videos
www.youtube.com/@toma.3d/videos
www.youtube.com/@tomapc/videos
13 Nov 2024 19:53
Solution fo "hm2 error finishing read" with no good PC
This is what i get:
cnc@15ALC7:~$ ls -1 /sys/class/net/ | grep -v lo | xargs -I{} bash -c 'echo -n {} :" " ; basename `readlink -f /sys/class/net/{}/device/driver`'
enxc84d44297a21 : r8152
wlp2s0 : rtw_8822ce
cnc@15ALC7:~$
13 Nov 2024 19:52
Replied by tommylight on topic General Questions about using ethercat
Category: EtherCAT
You are welcomed, always.
  • juliankoenig87
  • juliankoenig87
13 Nov 2024 19:38
Ok. I had a moment.
For me it looks like U10 and U6 had a issue. I iced the board and attached 2A to the 3,3V Rail. Both get warm.
I will desolder them when I have time. For the case. Where can I get spareparts?
  • HansU
  • HansU's Avatar
13 Nov 2024 19:20
Replied by HansU on topic Receiving GStat messages in GladeVCPs
Category: GladeVCP
This sounds like a question for Chris, and might do better on the dev mailing list.
Yes and I was pretty sure he will read this ;-)
Sorry for my late reply but I was expecting to get an email notification...
From hal_glib.py:
Thinking more about it...
If your gladevcp panel does not have gremlin object in it, you will not get gcode properties generated in that pythons context.
Why do you think so? It's just a textual message giving some information about the G-code.
From hal_glib.py:
Specifically ignores loading with the same filename (reloading)
Okay but why do I get a signal though when I run it as a user command file?
In detail, I have this VCP:
#!/usr/bin/env python3
from hal_glib import GStat
GSTAT = GStat()
class HandlerClass:
    def __init__(self, halcomp, builder, useropts):
        self.builder = builder
        GSTAT.connect("graphics-gcode-properties", self.gcode_properties)
        GSTAT.connect("file-loaded", self.file_loaded)
        GSTAT.connect("line-changed", self.line_changed)
    def gcode_properties(self, obj, data):
        print("[VCP] G-code properties:", data["name"], data["size"].replace("\n",", "))
    def file_loaded(self, obj, data):
        print("[VCP] File loaded:", data)
    def line_changed(self, obj, data):
        print("[VCP] Line changed:", data)
def get_handlers(halcomp,builder,useropts):
    return [HandlerClass(halcomp,builder,useropts)]
and I have a user command file in gmoccapy running with
USER_COMMAND_FILE = custom_init.py
def gcode_properties(obj, data, widgets):
    print("[rc] G-code properties:", data["name"], data["size"].replace("\n",", "))
def file_loaded(obj, data):
    print("[rc] File loaded:", data)
def line_changed(obj, data, widgets):
    print("[rc] Line changed:", data)
hal_glib.GStat().connect("graphics-gcode-properties", gcode_properties, self.widgets)
hal_glib.GStat().connect("line-changed", line_changed, self.widgets)
hal_glib.GStat().connect("file-loaded", file_loaded)
When first open a file, I get this output:
[VCP] File loaded: /home/cnc/linuxcnc/nc_files/3D_Chips.ngc
[rc] G-code properties: 3D_Chips.ngc 200509 bytes, 4714 gcode lines
[rc] File loaded: /home/cnc/linuxcnc/nc_files/3D_Chips.ngc
On reload I get only the messages from the user command file:
When staring the program, I get the line-changes from both:
[VCP] Line changed: 24
[rc] Line changed: 24
[VCP] Line changed: 25
[rc] Line changed: 25
[rc] Line changed: 26
[VCP] Line changed: 26
  • nick_namsep
  • nick_namsep
13 Nov 2024 18:35
Replied by nick_namsep on topic General Questions about using ethercat
Category: EtherCAT
Ohh amazing that is exactly what i need to hear thanks! I think i will order a servo and driver and will start on getting to know linuxcnc some more thanks!
  • PCW
  • PCW's Avatar
13 Nov 2024 18:28
Can you run this script:
File Name: edrivers.txt
File Size:0 KB
and post the results here?
first make executable with:
chmod +x edrivers.txt
then
./edrivers.txt
  • Aldenflorio
  • Aldenflorio's Avatar
13 Nov 2024 17:57
Replied by Aldenflorio on topic Pipe Cutting Plasma CNC
Yes exactly like that! I tried looking for more information about that build specifically but couldn’t seem to find the right keyword to pull it up.
I would love more information on the design of that, the motor used, the way Linuxcnc is best incorporate to fit that, and all.
i don’t think I realized that was your video, is it?
13 Nov 2024 17:45
Replied by tommylight on topic Mesa 7i96s / Network no longer working
That looks OK.
  • PCW
  • PCW's Avatar
13 Nov 2024 17:39
Replied by PCW on topic Mesa 7i96s / Network no longer working
Displaying 22051 - 22065 out of 22560 results.
Time to create page: 0.833 seconds
