  • juliankoenig87
  • juliankoenig87
06 Nov 2024 13:57
Replied by juliankoenig87 on topic Suggestion for a PCI EPP card for 7i43
Hi.
It doesnt really matter, but I would prefer PCI.
06 Nov 2024 13:54
Mint 22 with stock kernel preempt=dynamic works flawlessly with 7i76e
Is that the default mode?
I did test with stock Mint22, but the latency was not ok, and i waguely recall mentioning Dynamic somewhere, but i had no isolcpu in use.
Will have another look later, thank you.
BTW i did install 6.10RT and that works, did not boot with 6.11 or 6.12 at all.
06 Nov 2024 13:50
06 Nov 2024 13:48
Installing LinuxCNC 2.9 on Raspberry Pi 4B with Preempt-RT kernel
Category: Installing LinuxCNC
A shot from the hip, but usually those drive/steppers will have wrong encoder wiring, would be prudent to double check.
06 Nov 2024 13:45
Replied by tommylight on topic Which Mesa Card Should I Buy?
Category: Driver Boards
Replied on the other topic in German, so here it is again:
Get a 7i96S, it has less IO, so if you need more get a 7i84 with 32 in and 16 out, can be usually found at www.eusurplus.com and easy to wire together with a cut LAN cable.
06 Nov 2024 13:42
Replied by tommylight on topic Suche Mesa 7i76E
Suche Mesa 7i76E
Category: Deutsch
7i76 oder 7i76E?
Die 7i96S hab venig IO und es gibt beim eusurplus.com immer, nem ein 7i84 mit 32 eingange und 16 ausgange und einfach zu verkablen.
  • PedroSMS
  • PedroSMS
06 Nov 2024 13:38
Replied by PedroSMS on topic Suggestion for a PCI EPP card for 7i43
I use the SUNIX brand. I see them on ebay etc... They have a variety of PCI variants, and single & dual ports.
I hope this helps.
Kind regards
Pedro
06 Nov 2024 13:38
Replied by tommylight on topic 5-DRV8825 Questions
5-DRV8825 Questions
Category: Configuration Tools
14:1 at 60rpm would require the stepper motor (Nema16??? ) to run at 840rpm, and that is usually to much for a stepper (they can be run even at 3500rpm with good drives and high voltage but the torque will be very low), so even if it does run, it will not have any torque left.
Basically, drive is not the limiting factor for rpm, it is the voltage the drive can handle, in this case 24V.
Try it, see if it works for you, if not, tell us exactly what you need.
06 Nov 2024 13:25
Replied by tommylight on topic LinuxCNC Error
LinuxCNC Error
Not sure what changed in 2.9.3, vut that was the procedure for 2.9.1 i think.
Let us know if it works.
Thank you.
  • stickys
  • stickys
06 Nov 2024 13:17
Hey guys!
Successfully installed firmware, now it's moving :)
Do you have a full config .file, for spindle, inputs, outputs etc. for sample?
Tried to add homing switches, I wrote remora.input.03 but it said unkown pin.
I have dual Y axis, I followed the tutorials but only one motor is moving, if I set sync home sequence it will be OK?
  • Grotius
  • Grotius's Avatar
06 Nov 2024 13:09
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
Hi Robh,
I was reviewing the video and saw something was not ok in the output.
Here is a revised video.
It shows clearly the waitcomplete cycle at the abc interpreter.
And shows the internal updated variable list, wich is interesting to evaluate.
readme how it works
Your comments about path offset given a value, is interesting.
To work with multiple tools on the same path, given a offset.
Have to think about how to achieve this.
The idea so far is to use the super imposed interpreter as a front end solution.
Wich now simplyfies the source code drasticly.
Path planning, etc. is then done by the machine controller itself.
Then for a path offset, we could pass a gcode or mcode from the super imposed interpreter to
the machine controllers, telling it to one controller stay behind the tp given a offset.
When working with multiple tools on the same path,  a collision detection in the form of boundary boxes
is no prohibited luxury.
Greetings.
  • Thayloreing
  • Thayloreing
06 Nov 2024 13:00
Replied by Thayloreing on topic change the ini with the axis interface open
Is there a way to change the acceleration while the program is running? I tried to use m68 to change the acceleration during the program, but the planner ignores the change commands, but when I only run m68 it changes the acceleration as I determine.
  • tommy
  • tommy
06 Nov 2024 12:59
Replied by tommy on topic Rotary axis Display
Rotary axis Display
DISPLAY = ! BXYZ
did the thrick
but after applying G54 on X, it becomes a mess:
  • tommy
  • tommy
06 Nov 2024 12:54 - 06 Nov 2024 12:56
Rotary axis Display
Version 2.9.3
  • Aciera
  • Aciera's Avatar
06 Nov 2024 12:38
Replied by Aciera on topic Compensating For Angled Cut
Category: Plasma & Laser
Positional compensation for tool side rotation is something that can be done using custom kinematics and there are several sim configs that use it for TCP mode in 5axis machines:
Displaying 22351 - 22365 out of 22546 results.
Time to create page: 1.218 seconds
