  • SertanATL
  • SertanATL's Avatar
30 Jul 2024 08:20
Replied by SertanATL on topic Stepper Motor Tuning for Leadshine M542
Category: PnCConf Wizard
Okay, the information that I was looking for is actually documented but it is a different one called STEPGEN. There I was able to find what steplen, stepspace, dirhold and dirsetup corraleted to, which are t3, t4, t2 and t2 respectively. Leadshine documentation is in micro seconds, it should be translated into nano seconds, which is x1000.
  • peterdownunder
  • peterdownunder
30 Jul 2024 08:00
Replied by peterdownunder on topic Z offset reset on run
Category: Gmoccapy
This wens away and then started coming back again, and I think I have found what is causing my error, apart from me:)
In my original post I stopped the g-code at the G0 X208.659 Y25.039 line but it is the line after the is causing the problem. That is a G43 and the H value points to a valid tool but not the one I am using. It is loading the offset for whatever that tool last touched off to.
Even if it was right tool it would be whatever the last tool touch off measurement that was stored in the tool table.
Unsure why running the job again fixes it, but pretty sure that is the problem.
Sorry for screwing you around, but thatnks for the halp.
  • SertanATL
30 Jul 2024 07:26
Stepper Motor Tuning for Leadshine M542 was created by SertanATL
Thanks to everyone I currently have 2 linuxcnc machines running but I lack the knowledge of fine tuning stepper values. I am currently using Leadhshine M542 drivers and I attached the documentation for it. I read the stepper tuning document many times over but I couldn't find the direct values mentioned in the M542 documentation.
  • Step Frequency
  • Step Pulse (0) time
  • Step Pulse (1) time
  • Direction Setup
I think the information is at page 4 there is a chart for Connector P1 Configurations and at page 8, 10. Sequence Chart of Control Signals.
These 4 values will be translated into;
  • DIRSETUP
  • DIRHOLD
  • STEPLEN
  • STEPSPACE
I will be happy if someone can explain, therefore I can use the same logic to apply to my other machine.
  • jjdege
  • jjdege's Avatar
30 Jul 2024 06:38 - 30 Jul 2024 06:44
Ethercat installation from repositories - how to step by step
Category: EtherCAT
hi Rod
everything is still broken here, I read the answer Bjarne, I don't understand if there is a way to restore things, I tried without success
many thanks
  • besriworld
  • besriworld
30 Jul 2024 06:07
Replied by besriworld on topic Tuning of servo-drive
Category: EtherCAT
You need to set up the driver manually. If there is software for the driver it is a very easy task. Automatic settings have never worked well for me.
A minimum error of 1 is too large for most machines.
  • AirRacer
  • AirRacer
30 Jul 2024 05:50
  • Krulli_Fräser
  • Krulli_Fräser
30 Jul 2024 05:28
Verify my Mesa selection was created by Krulli_Fräser
Category: Driver Boards
Hello,
I am in the process of ordering the necessary components to retrofit my CNC mill. I just worked my way through the mesa selection guide and worked with the configuration tool. Now I would like your help verifying my selection so that as a beginner I don't make a costly mistake that could have been avoided.
The requirements are as follows:
3 analog servo drives with feedback from glass scales
1 Spindle vfd
3 mpg handwheels
34 digital inputs
18 digital outputs
At some point I would like to add physical buttons to the operators console, which would be realised with an 7i73 in the console.
The PC is in the operators console as well, and can only be connected to the mesa cards via ethernet.
In another post tommylight suggested I use the 7i97t, which can support my servomotors and the mpgs as well as a few inputs. Ideally i would expand this with a 7i76, however that is not available for me in europe.
Following the guide I came up with a different setup. As FPGA card I could use 7i96s and then connect 7i77 with the 25 pin connector. That leaves the smart serial connection for later use with the 7i73.
7i96s: Main FPGA board, controls spindle, 3 MPGs(6 inputs), 5 inputs, 6 outputs
7i77: controls the servo motors, takes the feedback from linear scales, 32 inputs, 16 outputs
7i73: keys and encoders on the operator control
so that should have me covered, or am I missing something?
  • AirRacer
  • AirRacer
30 Jul 2024 04:45 - 30 Jul 2024 04:46
Replied by AirRacer on topic Mesa CT Huge Improvements Coming
I just installed mesact_2.1.5_amd64.deb over 2.1.4 but running it still shows 2.1.4-Build Date 7/16/2024 in the title bar. Any ideas? Synaptics package manager shows that v2.1.5 is installed.
Skylor
  • PCW
  • PCW's Avatar
30 Jul 2024 04:21
7I97T PWMGen Dither and Firmware Version
Its possible only the base configuration (7i97t_d.bin) has been
updated to include version 1 PWMgens
7I97T+7I76 with version 1 PWM firmware:
File Name: 7i97t_7i76d.zip
File Size:303 KB
  • PCW
  • PCW's Avatar
30 Jul 2024 02:39
You can determine module versions with mesaflash's --readhmid option
  • AirRacer
  • AirRacer
30 Jul 2024 02:02 - 30 Jul 2024 02:02
LinuxCNC Version 2.9.2
Mesa 7I97T + 7I76 Firmware 7I97t_7;i76d
Mesaflash 3.5.9
When attempting to enable PWM Dithering I'm getting the resulting error:
     ./main.hal:63: parameter or pin 'hm2_7i97.0.pwmgen.00.dither' not found
I see in the HOSTMOT2 manual that "PWMGen firmware version 1 or greater" is required for dither.  Is this the problem?  How can I determine which version of the PWMGen firmware my card has on it?  Is this the likely issue?
Thanks,
Skylor
  • Dave2024
  • Dave2024's Avatar
30 Jul 2024 01:26
Help installing samba on Debian 12 Bookworm PREEMPT-RT ISO
Nooo, that page says its part of Debian so nothing to do in the apt foders
Can you try
sudo apt update
sudo apt install samba
Yeah thats how I usually install it except when using the Debian 12 Bookworm PREEMPT-RT ISO found on the site here on the linuxcnc.org/downloads/ page it doesnt work and gives me the error: E: Package 'samba' has no installation candidate.
It installs just finew when using the ISO from the Debian site but when using the Debian 12 Bookworm PREEMPT-RT ISO from Linuxcnc.org its a no go :(
30 Jul 2024 00:44
Replied by tommylight on topic Interesting Youtube Video
Talking about developers, payed ones:
30 Jul 2024 00:29
Replied by tommylight on topic Who wants to use MODBUS ? Video.
Yes, bit that was constrained to a certain type of device (VFD for centrifuges for U238 to U235 enrichment), this is not.
On the other side, anything is vulnerable, it just takes a bit of time, and knowledge shortens that time a lot.
  • MennilTossFlykune
  • MennilTossFlykune
30 Jul 2024 00:00 - 30 Jul 2024 00:06
Replied by MennilTossFlykune on topic Flexible GUI
Flexible GUI
Category: Other User Interfaces
I wanted to be able to test it in qtdragon so it's PyQt5 instead
This one does work as a standalone window
Displaying 23866 - 23880 out of 25557 results.
Time to create page: 0.537 seconds
