28 Jul 2024 22:45
Replied by Cant do this anymore bye all on topic Keyboard gets unresponsive from time to time
ssh into the debian pc when the keyboard disconnects and run dmesg, this should give an idea of what is happening.
- rdtsc
28 Jul 2024 22:38 - 28 Jul 2024 22:51
Replied by rdtsc on topic 2.9.3 ISO Issue
2.9.3 ISO Issue
Category: Installing LinuxCNC
I think I was able to update 2.9.2 to 2.9.3 successfully using sudo apt update. However, today I'm getting a key error:
This key error is really odd because that repo is not listed in /etc/apt/sources.list. Oh wait, found it under /etc/apt/sources.list.d/ighvh.sources. Seems it may have something to do with our EtherCAT? build.opensuse.org/projects/science:EtherLab/prjconf
Looking further, they have a page for the key: build.opensuse.org/projects/science:EtherLab/signing_keys and a link there to download an "armored version" of a supposedly newer key (says it now expires in two years.)
Thinking maybe if that key were updated, things would improve, researched how to add it and did the following:
As a temporary work-around (I'm not using EtherCAT), `sudo mv /etc/apt/sources.list.d/ighvh.sources /etc/apt/sources.list.d/ighvh.sources.disabled` will disable that source and the resulting error. But this should be investigated properly for the next .iso (if it hasn't already.)
Get:7 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease [1,575 B]
Hit:8 https://www.linuxcnc.org bookworm InRelease
Err:7 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease
The following signatures were invalid: EXPKEYSIG A94819A7CB97A204 science:EtherLab OBS Project <science:EtherLab@build.opensuse.org>
Fetched 1,575 B in 3s (564 B/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
All packages are up to date.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease: The following signatures were invalid: EXPKEYSIG A94819A7CB97A204 science:EtherLab OBS Project <science:EtherLab@build.opensuse.org>
W: Failed to fetch http://download.opensuse.org/repositories/science:/EtherLab/Debian_12/./InRelease The following signatures were invalid: EXPKEYSIG A94819A7CB97A204 science:EtherLab OBS Project <science:EtherLab@build.opensuse.org>
W: Some index files failed to download. They have been ignored, or old ones used instead.
1. Downloaded the latest `science_EtherLab_key.gpg` to `~/Downloads`
2. cd there, then `gpg --dearmor science_EtherLab_key.gpg`, which created a `science_EtherLab_key.gpg.gpg` file.
3. `su` to temporarly be root, do `cp science_EtherLab_key.gpg.gpg /usr/share/keyrings/etherlab-archive-keyring.gpg` which copies the file into the appropriate system folder.
4. `exit` to quit root. Try `sudo apt update` again: nope, keysig still invalid.
- Lpkkk
- Lpkkk
28 Jul 2024 22:22
Replied by Lpkkk on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Thank you but I've already followed that, it was very helpful . Unfortunately There is no word about connection timeout. I've ordered rs232 to usb converter to have a look what is really going on with my board, it should be here tomorrow, hopefully nvem will tell me something more. Meanwhile if anyone had similar issue or know how to fix it, please share
- my1987toyota
28 Jul 2024 22:11 - 29 Jul 2024 10:13
Replied by my1987toyota on topic 7i96 non S PWM on an output possible?
Category: Driver Boards
ok below are my current HAL, INI, and PYVCP files for the foam cutter.
the HAL file
[/code][/code][/code]
the HAL file
# Generated by PNCconf at Wed Jul 17 17:05:42 2024
# Using LinuxCNC version: Master (2.9)
# overwritten when you run PNCconf again
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=0xxxxxxx"
loadrt pid names=pid.x,pid.y,pid.u,pid.v,pid.a,pid.s
loadrt pwmgen output_type=0
addf [HMOT](CARD0).read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.u.do-pid-calcs servo-thread
addf pid.v.do-pid-calcs servo-thread
addf pid.a.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf [HMOT](CARD0).write servo-thread
addf pwmgen.make-pulses servo-thread
setp [HMOT](CARD0).dpll.01.timer-us -50
setp [HMOT](CARD0).stepgen.timer-number 1
setp [HMOT](CARD0).watchdog.timeout_ns 5000000
setp pwmgen.0.dither-pwm true
setp pwmgen.0.pwm-freq 20
setp pwmgen.0.scale 100 # Change to your spindle’s top speed in RPM
# external output signals
# --- WIRE-OUTPUT-PIN ---
net spindle-speed-cmd spindle.0.speed-out => pwmgen.0.value
net spindle-on spindle.0.on => pwmgen.0.enable
net spindle-pwm pwmgen.0.pwm => [HMOT](CARD0).ssr.00.out-05
# external input signals
# --- ESTOP-EXT ---
net estop-ext <= [HMOT](CARD0).gpio.000.in_not
# --- HOME-X ---
net home-x <= [HMOT](CARD0).gpio.001.in
# --- HOME-Y ---
net home-y <= [HMOT](CARD0).gpio.002.in
# --- HOME-U ---
net home-U <= [HMOT](CARD0).gpio.003.in
# --- HOME-V ---
net home-V <= [HMOT](CARD0).gpio.004.in
# --- HOME-A ---
#net home-A <= [HMOT](CARD0).gpio.005.in
# AXIS X JOINT 0
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.x.error-previous-target true
# This setting is to limit bogus stepgen
# velocity corrections caused by position
# feedback sample time jitter.
setp pid.x.maxerror 0.012700
net x-index-enable => pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-pos-fb => pid.x.feedback
net x-output <= pid.x.output
# Step Gen signals/setup
setp [HMOT](CARD0).stepgen.00.dirsetup [JOINT_0]DIRSETUP
setp [HMOT](CARD0).stepgen.00.dirhold [JOINT_0]DIRHOLD
setp [HMOT](CARD0).stepgen.00.steplen [JOINT_0]STEPLEN
setp [HMOT](CARD0).stepgen.00.stepspace [JOINT_0]STEPSPACE
setp [HMOT](CARD0).stepgen.00.position-scale [JOINT_0]STEP_SCALE
setp [HMOT](CARD0).stepgen.00.step_type 0
setp [HMOT](CARD0).stepgen.00.control-type 1
setp [HMOT](CARD0).stepgen.00.maxaccel [JOINT_0]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.00.maxvel [JOINT_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd <= joint.0.motor-pos-cmd
net x-vel-cmd <= joint.0.vel-cmd
net x-output => [HMOT](CARD0).stepgen.00.velocity-cmd
net x-pos-fb <= [HMOT](CARD0).stepgen.00.position-fb
net x-pos-fb => joint.0.motor-pos-fb
net x-enable <= joint.0.amp-enable-out
net x-enable => [HMOT](CARD0).stepgen.00.enable
# ---setup home / limit switch signals---
#net x-home-sw => joint.0.home-sw-in
net x-home => joint.0.home-sw-in
net x-neg-limit => joint.0.neg-lim-sw-in
net x-pos-limit => joint.0.pos-lim-sw-in
# AXIS Y JOINT 1
setp pid.y.Pgain [JOINT_1]P
setp pid.y.Igain [JOINT_1]I
setp pid.y.Dgain [JOINT_1]D
setp pid.y.bias [JOINT_1]BIAS
setp pid.y.FF0 [JOINT_1]FF0
setp pid.y.FF1 [JOINT_1]FF1
setp pid.y.FF2 [JOINT_1]FF2
setp pid.y.deadband [JOINT_1]DEADBAND
setp pid.y.maxoutput [JOINT_1]MAX_OUTPUT
setp pid.y.error-previous-target true
setp pid.y.maxerror 0.012700
net y-index-enable => pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-pos-fb => pid.y.feedback
net y-output <= pid.y.output
setp [HMOT](CARD0).stepgen.01.dirsetup [JOINT_1]DIRSETUP
setp [HMOT](CARD0).stepgen.01.dirhold [JOINT_1]DIRHOLD
setp [HMOT](CARD0).stepgen.01.steplen [JOINT_1]STEPLEN
setp [HMOT](CARD0).stepgen.01.stepspace [JOINT_1]STEPSPACE
setp [HMOT](CARD0).stepgen.01.position-scale [JOINT_1]STEP_SCALE
setp [HMOT](CARD0).stepgen.01.step_type 0
setp [HMOT](CARD0).stepgen.01.control-type 1
setp [HMOT](CARD0).stepgen.01.maxaccel [JOINT_1]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.01.maxvel [JOINT_1]STEPGEN_MAXVEL
net y-pos-cmd <= joint.1.motor-pos-cmd
net y-vel-cmd <= joint.1.vel-cmd
net y-output => [HMOT](CARD0).stepgen.01.velocity-cmd
net y-pos-fb <= [HMOT](CARD0).stepgen.01.position-fb
net y-pos-fb => joint.1.motor-pos-fb
net y-enable <= joint.1.amp-enable-out
net y-enable => [HMOT](CARD0).stepgen.01.enable
#net y-home-sw => joint.1.home-sw-in
net home-y => joint.1.home-sw-in
net y-neg-limit => joint.1.neg-lim-sw-in
net y-pos-limit => joint.1.pos-lim-sw-in
# AXIS U JOINT 2
setp pid.u.Pgain [JOINT_2]P
setp pid.u.Igain [JOINT_2]I
setp pid.u.Dgain [JOINT_2]D
setp pid.u.bias [JOINT_2]BIAS
setp pid.u.FF0 [JOINT_2]FF0
setp pid.u.FF1 [JOINT_2]FF1
setp pid.u.FF2 [JOINT_2]FF2
setp pid.u.deadband [JOINT_2]DEADBAND
setp pid.u.maxoutput [JOINT_2]MAX_OUTPUT
setp pid.u.error-previous-target true
setp pid.u.maxerror 0.012700
net u-index-enable => pid.u.index-enable
net u-enable => pid.u.enable
net u-pos-cmd => pid.u.command
net u-pos-fb => pid.u.feedback
net u-output <= pid.u.output
setp [HMOT](CARD0).stepgen.02.dirsetup [JOINT_2]DIRSETUP
setp [HMOT](CARD0).stepgen.02.dirhold [JOINT_2]DIRHOLD
setp [HMOT](CARD0).stepgen.02.steplen [JOINT_2]STEPLEN
setp [HMOT](CARD0).stepgen.02.stepspace [JOINT_2]STEPSPACE
setp [HMOT](CARD0).stepgen.02.position-scale [JOINT_2]STEP_SCALE
setp [HMOT](CARD0).stepgen.02.step_type 0
setp [HMOT](CARD0).stepgen.02.control-type 1
setp [HMOT](CARD0).stepgen.02.maxaccel [JOINT_2]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.02.maxvel [JOINT_2]STEPGEN_MAXVEL
net u-pos-cmd <= joint.2.motor-pos-cmd
net u-vel-cmd <= joint.2.vel-cmd
net u-output => [HMOT](CARD0).stepgen.02.velocity-cmd
net u-pos-fb <= [HMOT](CARD0).stepgen.02.position-fb
net u-pos-fb => joint.2.motor-pos-fb
net u-enable <= joint.2.amp-enable-out
net u-enable => [HMOT](CARD0).stepgen.02.enable
#net u-home-sw => joint.2.home-sw-in
net home-u => joint.2.home-sw-in
net u-neg-limit => joint.2.neg-lim-sw-in
net u-pos-limit => joint.2.pos-lim-sw-in
# AXIS V JOINT 3
setp pid.v.Pgain [JOINT_3]P
setp pid.v.Igain [JOINT_3]I
setp pid.v.Dgain [JOINT_3]D
setp pid.v.bias [JOINT_3]BIAS
setp pid.v.FF0 [JOINT_3]FF0
setp pid.v.FF1 [JOINT_3]FF1
setp pid.v.FF2 [JOINT_3]FF2
setp pid.v.deadband [JOINT_3]DEADBAND
setp pid.v.maxoutput [JOINT_3]MAX_OUTPUT
setp pid.v.error-previous-target true
setp pid.v.maxerror 0.012700
net v-index-enable => pid.v.index-enable
net v-enable => pid.v.enable
net v-pos-cmd => pid.v.command
net v-pos-fb => pid.v.feedback
net v-output <= pid.v.output
setp [HMOT](CARD0).stepgen.03.dirsetup [JOINT_3]DIRSETUP
setp [HMOT](CARD0).stepgen.03.dirhold [JOINT_3]DIRHOLD
setp [HMOT](CARD0).stepgen.03.steplen [JOINT_3]STEPLEN
setp [HMOT](CARD0).stepgen.03.stepspace [JOINT_3]STEPSPACE
setp [HMOT](CARD0).stepgen.03.position-scale [JOINT_3]STEP_SCALE
setp [HMOT](CARD0).stepgen.03.step_type 0
setp [HMOT](CARD0).stepgen.03.control-type 1
setp [HMOT](CARD0).stepgen.03.maxaccel [JOINT_3]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.03.maxvel [JOINT_3]STEPGEN_MAXVEL
net v-pos-cmd <= joint.3.motor-pos-cmd
net v-vel-cmd <= joint.3.vel-cmd
net v-output => [HMOT](CARD0).stepgen.03.velocity-cmd
net v-pos-fb <= [HMOT](CARD0).stepgen.03.position-fb
net v-pos-fb => joint.3.motor-pos-fb
net v-enable <= joint.3.amp-enable-out
net v-enable => [HMOT](CARD0).stepgen.03.enable
#net v-home-sw => joint.3.home-sw-in
net home-v => joint.3.home-sw-in
net v-neg-limit => joint.3.neg-lim-sw-in
net v-pos-limit => joint.3.pos-lim-sw-in
# AXIS A JOINT 4
setp pid.a.Pgain [JOINT_4]P
setp pid.a.Igain [JOINT_4]I
setp pid.a.Dgain [JOINT_4]D
setp pid.a.bias [JOINT_4]BIAS
setp pid.a.FF0 [JOINT_4]FF0
setp pid.a.FF1 [JOINT_4]FF1
setp pid.a.FF2 [JOINT_4]FF2
setp pid.a.deadband [JOINT_4]DEADBAND
setp pid.a.maxoutput [JOINT_4]MAX_OUTPUT
setp pid.a.error-previous-target true
setp pid.a.maxerror 0.012700
net a-index-enable => pid.a.index-enable
net a-enable => pid.a.enable
net a-pos-cmd => pid.a.command
net a-pos-fb => pid.a.feedback
net a-output <= pid.a.output
setp [HMOT](CARD0).stepgen.04.dirsetup [JOINT_4]DIRSETUP
setp [HMOT](CARD0).stepgen.04.dirhold [JOINT_4]DIRHOLD
setp [HMOT](CARD0).stepgen.04.steplen [JOINT_4]STEPLEN
setp [HMOT](CARD0).stepgen.04.stepspace [JOINT_4]STEPSPACE
setp [HMOT](CARD0).stepgen.04.position-scale [JOINT_4]STEP_SCALE
setp [HMOT](CARD0).stepgen.04.step_type 0
setp [HMOT](CARD0).stepgen.04.control-type 1
setp [HMOT](CARD0).stepgen.04.maxaccel [JOINT_4]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.04.maxvel [JOINT_4]STEPGEN_MAXVEL
net a-pos-cmd <= joint.4.motor-pos-cmd
net a-vel-cmd <= joint.4.vel-cmd
net a-output => [HMOT](CARD0).stepgen.04.velocity-cmd
net a-pos-fb <= [HMOT](CARD0).stepgen.04.position-fb
net a-pos-fb => joint.4.motor-pos-fb
net a-enable <= joint.4.amp-enable-out
net a-enable => [HMOT](CARD0).stepgen.04.enable
net a-home-sw => joint.4.home-sw-in
#net home-a => joint.4.home-sw-in
net a-neg-limit => joint.4.neg-lim-sw-in
net a-pos-limit => joint.4.pos-lim-sw-in
# SPINDLE
setp pid.s.Pgain [SPINDLE_0]P
setp pid.s.Igain [SPINDLE_0]I
setp pid.s.Dgain [SPINDLE_0]D
setp pid.s.bias [SPINDLE_0]BIAS
setp pid.s.FF0 [SPINDLE_0]FF0
setp pid.s.FF1 [SPINDLE_0]FF1
setp pid.s.FF2 [SPINDLE_0]FF2
setp pid.s.deadband [SPINDLE_0]DEADBAND
setp pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable => pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
net spindle-vel-cmd-rps <= spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs
#net spindle-vel-cmd-rpm <= spindle.0.speed-out
net spindle-vel-cmd-rpm-abs <= spindle.0.speed-out-abs
#net spindle-enable <= spindle.0.on
net spindle-cw <= spindle.0.forward
net spindle-ccw <= spindle.0.reverse
net spindle-brake <= spindle.0.brake
net spindle-revs => spindle.0.revs
net spindle-vel-fb-rps => spindle.0.speed-in
net spindle-index-enable <=> spindle.0.index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net axis-select-x halui.axis.x.select
net jog-x-pos halui.axis.x.plus
net jog-x-neg halui.axis.x.minus
net jog-x-analog halui.axis.x.analog
net x-is-homed halui.joint.0.is-homed
net axis-select-y halui.axis.y.select
net jog-y-pos halui.axis.y.plus
net jog-y-neg halui.axis.y.minus
net jog-y-analog halui.axis.y.analog
net y-is-homed halui.joint.1.is-homed
net axis-select-u halui.axis.u.select
net jog-u-pos halui.axis.u.plus
net jog-u-neg halui.axis.u.minus
net jog-u-analog halui.axis.u.analog
net u-is-homed halui.joint.2.is-homed
net axis-select-v halui.axis.v.select
net jog-v-pos halui.axis.v.plus
net jog-v-neg halui.axis.v.minus
net jog-v-analog halui.axis.v.analog
net v-is-homed halui.joint.3.is-homed
net axis-select-a halui.axis.a.select
net jog-a-pos halui.axis.a.plus
net jog-a-neg halui.axis.a.minus
net jog-a-analog halui.axis.a.analog
net a-is-homed halui.joint.4.is-homed
net jog-selected-pos halui.axis.selected.plus
net jog-selected-neg halui.axis.selected.minus
net spindle-manual-cw halui.spindle.0.forward
net spindle-manual-ccw halui.spindle.0.reverse
net spindle-manual-stop halui.spindle.0.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-ext => iocontrol.0.emc-enable-in
# ---manual tool change signals---
net tool-change-request <= iocontrol.0.tool-change
net tool-change-confirmed => iocontrol.0.tool-changed
net tool-number <= iocontrol.0.tool-prep-number
# ---Use external manual tool change dialog---
net tool-change-request => hal_manualtoolchange.change
net tool-change-confirmed <= hal_manualtoolchange.changed
net tool-number => hal_manualtoolchange.number
# ---ignore tool prepare requests---
the INI file
[code]# Generated by PNCconf at Wed Jul 17 17:05:42 2024
[EMC]
MACHINE = foam_cutter
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = axis
FOAM = 1
XY_Z_POS = 5
UV_W_POS = 0
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/cnc002/linuxcnc/nc_files
PYVCP = pyvcp-panel.xml
INCREMENTS = 10mm 1mm .1mm .01mm
DEFAULT_LINEAR_VELOCITY = 6.000000
MAX_LINEAR_VELOCITY = 25.000000
MIN_LINEAR_VELOCITY = 0.500000
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
#GEOMETRY = xyz
GEOMETRY = xyuv
CYCLE_TIME = 100
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
RS274NGC_STARTUP_CODE = G21 G40 G90 G94 G97 G64 P0.025
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1000000
[HMOT]
CARD0=hm2_7i96.0
[HAL]
HALUI = halui
HALFILE = foam_cutter.hal
HALFILE = custom.hal
POSTGUI_HALFILE = pyvcp_options.hal
POSTGUI_HALFILE = custom_postgui.hal
SHUTDOWN = shutdown.hal
[HALUI]
[KINS]
#JOINTS = 4
JOINTS = 5
#KINEMATICS = trivkins coordinates=XYZA
#KINEMATICS = trivkins coordinates=XYUV
KINEMATICS = trivkins coordinates=XYUVA
[TRAJ]
#COORDINATES = XYZA
#COORDINATES = XYUV
COORDINATES = XYUVA
MAX_ANGULAR_VELOCITY = 360.00
DEFAULT_ANGULAR_VELOCITY = 36.00
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 2.50
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_X]
MAX_VELOCITY = 25.0
MAX_ACCELERATION = 750.0
MIN_LIMIT = -0.01
MAX_LIMIT = 550.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
STEPGEN_MAXVEL = 31.25
STEPGEN_MAXACCEL = 937.50
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP = 20000
DIRHOLD = 20000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 1600.0
MIN_LIMIT = -0.01
MAX_LIMIT = 550.0
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = -1.000000
HOME_LATCH_VEL = -0.500000
HOME_FINAL_VEL = 0.000000
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
#HOME_SEQUENCE = 1
[AXIS_Y]
MAX_VELOCITY = 25.0
MIN_LIMIT = -0.01
MAX_LIMIT = 350.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 20000
DIRHOLD = 20000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 800.0
MIN_LIMIT = -0.01
MAX_LIMIT = 350.0
HOME_OFFSET = 0.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
#HOME_SEQUENCE = 2
[AXIS_U]
MAX_VELOCITY = 25.0
MIN_LIMIT = -0.01
MAX_LIMIT = 550.0
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 20000
DIRHOLD = 20000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 800.0
MIN_LIMIT = -0.01
MAX_LIMIT = 550.0
HOME_OFFSET = 0.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
#HOME_SEQUENCE = 0
[AXIS_V]
MAX_VELOCITY = 25.0
MIN_LIMIT = -0.01
MAX_LIMIT = 350.0
[JOINT_3]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 20000
DIRHOLD = 20000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 800.0
MIN_LIMIT = -0.01
MAX_LIMIT = 350.0
HOME_OFFSET = 0.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
#HOME_SEQUENCE = 2
[AXIS_A]
MAX_VELOCITY = 360.0
MAX_ACCELERATION = 1200.0
MIN_LIMIT = -361.0
MAX_LIMIT = 361.0
[JOINT_4]
TYPE = ANGULAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
STEPGEN_MAXVEL = 450.00
STEPGEN_MAXACCEL = 1500.00
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 4.4444
MIN_LIMIT = -361.0
MAX_LIMIT = 361.0
HOME_OFFSET = 0.0
#HOME_SEARCH_VEL = -1.000000
#HOME_LATCH_VEL = -0.500000
#HOME_FINAL_VEL = 0.000000
#HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
#HOME_SEQUENCE = 3
[SPINDLE_0]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 100
PYVCP hal
[code]# _DO NOT_ include your HAL commands here.
# Put custom HAL commands in custom_postgui.hal
# The commands in this file are run after the GUI loads
# **** Setup of spindle speed display using pyvcp -START ****
net spindle-vel-cmd-rpm-abs => pyvcp.spindle-speed
net spindle-cw => pyvcp.spindle-at-speed-led
# **** Setup of spindle speed display using pyvcp -END ****
PYVCP xml
[code]<?xml version='1.0' encoding='UTF-8'?>
<pyvcp>
<vbox>
<relief>RIDGE</relief>
<bd>6</bd>
<label>
<text>"Wire Power:"</text>
<font>;("Helvetica",20)</font>
</label>
<bar>
<halpin>"spindle-speed"</halpin>
<max_>100</max_>
</bar>
<label>
<text>"Wire ON:"</text>
</label>
<hbox>
<label>
<text>" "</text>
</label>
<led>
<halpin>"spindle-at-speed-led"</halpin>
<size>30</size>
<on_color>"red"</on_color>
<off_color>"blue"</off_color>
</led>
</hbox>
</vbox>
</pyvcp>
- rdtsc
28 Jul 2024 22:06
Replied by rdtsc on topic Pi4b and Pi5 users - What should go in a 2.9.3 image
Would an RTAI variant be applicable to the Rpi4? (Not to create more work for you Rod! But it may be more performant, or no?)
- MarkoPolo
- MarkoPolo
28 Jul 2024 21:44
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
Oh, I wrote that I don't use m70/72. I looked through my ngc again and it does indeed have m70 and m72.
Putting m5 at the beginning of the code solves the problem, maybe in qtvcp procedures such a small correction would also be enough..
- Muftijaja
- Muftijaja
28 Jul 2024 21:38 - 28 Jul 2024 21:39
Replied by Muftijaja on topic Latency Test OK, dennoch Fehlermeldung
Category: Deutsch
Thanks for your doc, meanwhile I changed to the internal Intel 82579 network adapter and the jitter grows worse. Do you think the latest Debian and LCNC versions can do better with this combination? I don't have no choice to change to another 2nd adapter, there is no alternative to the Realtec as 2nd network adapter for this computer afaik.
- Grotius
28 Jul 2024 21:33
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
@Lcevette,
In previous post somewhere:
the travelheight has to be at least the G64 P..
in this example the lift height is set at 0.005" which would mean if a P value is set at 0.004"
Then you could use : lift height 0.005 and P0.005. Then it will not go down the z.
Thanks for the gcode file. It loads, but i have some spline problems i see. Haha. I see a lot of spagetti.
So i have to look what's going on and fix it. When it's fixed i will let you know about the file fillets and how they behave.
I had solved a weird thing in the gcode parser.
To convert a string to a double value, some times this failed on other linux pc. It had to do with value using . or , as decimal seperator
as input for the std::stod function.
It's solved by adding : std::locale::global(std::locale("C"));
Thanks, let me know if you need anything else!
A bit off luck... Haha.
Today i coded some more for the look ahead.
I think based on previous post, where the red line of the graph is the velocity profile based on curvature of segments.
This then can be used to retrieve the vo,vm,ve for the trajectory planner.
Arciera mentioned earlyer, the clothoid fillets are quite small, so let we use a vo,vm,ve for each segment.
- ississ
28 Jul 2024 21:09
Raspi connect is something I would not use because of the need for cloud connection.
I advice using only services using local network for machine control.
Replied by ississ on topic I want to create a VNC in linuxcnc running in raspberry pi 5
One drawback for a terminal is that probably you are not be able to connect to a running process (in this case linuxcnc) but you have to start it inside the terminal. For us that have configuration to start linuxcnc automatically on boot this won't work.If your problem is to only view LinuxCNC on Windows and you are not interested in the desktop of the Linux machine I recommend using an X-Terminal like MobaXterm
mobaxterm.mobatek.net/
Alternatively you can see how this new feature works
www.raspberrypi.com/documentation/services/connect.html
28 Jul 2024 21:07
Replied by cmorley on topic Error in tool_offsetview.py
Category: Qtvcp
Yes spindle stop button doesn't use m5 it calls spindle off command.
Either way should call the spindle off command.
It will be something in the code that assumes that S 0 = spindle stop, which is not true anymore.
M70/M72 had something similar happen in the right situation.
IIRC it had something to do with using MDI to turn on the spindle and the stop button to turn it off then the M72 would turn it back on because it never got the M5 command.
It should be checking if the spindle is on/off rather then the Gcode M3/4/5.
Your situation sounds the same. I just don't remember if we worked around it or not.
Chris
Chris
- geostein8888
- geostein8888
28 Jul 2024 21:06
Replied by geostein8888 on topic Keyboard gets unresponsive from time to time
Hello,
parallel to the linuxcnc i use also windows on the same machine in conjunction with Estlcam and the Estlcam Board (i have still many Estlcam projects i use), here i do not see any problem with the Keyboard
28 Jul 2024 20:56
Category: Qtvcp
Qtvcp's probe routines use m70 /m72- I do think that is the source of the problem.
- oneohm
28 Jul 2024 20:16
Replied by oneohm on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Thanks for tackling the NVMPG display issue!
I've updated to 3.1.3 and the NVMPG display is now updating correctly.
I have encountered a possible bug:
While jogging with the NVMPG It sometimes changes the axis suddenly and overruns the NVMPG display value, leaving a digit to the extreme left in the X and Y position fields, partially outside the field.
The NVMPG continues to work, but on the new axis and the extra digits remain until power cycled.
Attached is an example of the corrupted display.
28 Jul 2024 20:02
Replied by Aciera on topic After updating to 2.9.3
Seems that those can be ignored:
forum.linuxcnc.org/49-basic-configuratio...-error-in-log#306221
- rdtsc
28 Jul 2024 19:57 - 28 Jul 2024 20:07
Replied by rdtsc on topic iMachI3 P2-S Pendant Install Fail
This list is once again incomplete and will likely change again in the future. Instead of posting more changes, check your errors against the following link for the correct names:
linuxcnc.org/docs/html/man/man1/halui.1.html#PINS
Time to create page: 0.844 seconds
