  • akg1904
  • akg1904
04 Jul 2024 13:59
Replied by akg1904 on topic TCP 5-axis kinematics
Greetings to all.
My 5-axis machines was running fine with the same INI, But as my Motherboard died and I changed my System and I also shifted my machines to other location.
Now my 5-axis TCP is not working properly as I can see a small jump simulation of Linuxcnc but in Machine there is no jump and because of this it derails from the actual path as you can see in Image.
Now I am not able to figure out why it is doing so..
I have attached my INI and HAL file.
File Name: pre-gui_20...7-04.hal
File Size:4 KB
File Name: xyzac-trt_...7-04.ini
File Size:6 KB
Regards
Abhishek
  • yathish
  • yathish
04 Jul 2024 13:53
Replied by yathish on topic I/O expander for RPI5 to run linuxcnc
I may require a minimum of 16 input and 16 output pins, is it available in linuxcnc-rio?
  • PCW
  • PCW's Avatar
04 Jul 2024 13:25 - 04 Jul 2024 13:29
BLDC component with 8i20 - how to get to work?
Category: Driver Boards
Have you tried magnetic homing (q instead of qi)
Have you verified the encoder counts per turn?
Have you verified the number of poles?
You can do this by supplying an small current and finding the number of null positions
The number of poles is twice the number of null positions.
Have you tried with a drive offset of 90 degrees?
If you get jerky motion with a commanded move its most likely the scaling or direction
are wrong so the drive phase does not match the rotor angle
  • cakeslob
  • cakeslob
04 Jul 2024 12:56
Replied by cakeslob on topic I/O expander for RPI5 to run linuxcnc
we got a w5500 thing on remora also,
this is the cheapest i could build something probably
github.com/cakeslob/RRW_LAB
  • 777funk
  • 777funk
04 Jul 2024 12:03
LinuxCNC communicate Via SERIAL Port to existing hardware?
I was planning to gut a Techno CPM 3020 and save only the servos but with a little experimenting yesterday, I was able to get the machine to work with the demo version of the original software (Galaad Kay). Support at Galaad seems to be so so and I'd rather use LinuxCNC if it's practical.
Would LinuxCNC have the ability to replace the original software? It seems all the existing hardware is in good working order so I hate to pitch it.
  • Donb9261
  • Donb9261's Avatar
04 Jul 2024 11:34
Looking for example clp for ATC random tool changer Mill with/without carousel
Category: ClassicLadder
I am late to the party but would like to add some of my experience if it helps.
Typically, you would want to have some means to store the values of the current pocket ready, the tool number in that pocket, and whether the tool in the spindle is equal to the first 2 if power is lost. You would do this via some parameter that is written on LCNC exit and read into memory at startup. In LCNC, these parameters are stored in the var file. User assigned variables in RS274 GCODE are 31-5000 in LCNC. Typically in most controls outside the LCNC world 30-100 are volatile, while 500-999 are non-volatile. Meaning they are persistent.
With that, I would create a set of variables in the ATC routine that stores the tool numbers by pocket numbers in the drum, and also the value of the tool loaded in the spindle in thses variables. Given LCNC allows up to 5000, I would use(assuming a 12 station drum) 4000 ~4014. 4000 is the current tool in the spindle. 4001 is the current tool in the slot facing the spindle. 4002 is the current slot number/pocket number. The balance would be the slots.
Once the tool is loaded in the spindle, the value for the pocket it came from should become 0. If I have tool 1 in the spindle 4000 = 1. If it came from slot 6 and it is facing the spindle or tool arm, then 4001 = 0. 4008 = 0. If I call tool 3 and it is in slot 9 and tool 6 was in the spindle, then the drum should rotate to pocket 9, see that tool 3 is there via 4011 = 3, swap tools, 4011 = 6, 4000 = 3, 4001 = 6.
This method allows for one to assign the correct values via MDI in the event the coordination of the tools and pockets is lost because power was lost before the file was written. You can also call a python sub routine that once the tool change cycle completes writes the file but this is difficult and must be very precise.
Example:
(Assign the tool number of the spindle)
#4000 = 1
(Assign the tool number in the slot at the ready)
#4001 = 3
etc....
You can test this by assigning the values in MDI. Power of LCNC. Open the var file for your profile. Check to see the var number to the left and the value stored on the right. It should be what you assigned in MDI in the file. ex... #4004 = 10. Slot 2 has tool 10 in the slot will appear as:
~ other vars...
4000 10
~other vars
in the var file.
Hope that helps.
  • Muftijaja
  • Muftijaja
04 Jul 2024 11:27
Replied by Muftijaja on topic Touchscreen mit Debian 12 und LCNC 2.9 nutzen?
Category: Deutsch
Ja genau. Mit dem Handrad hatte ich auch Probleme (und länger gebraucht wie Du) und da war letztlich auch die Lösung einen nativen Port zu benutzen. K.A. warum ich nicht gleich auf die Lösung gekommen bin. Manchmal ist man vernagelt.
LG Arno
  • dg9mdr
  • dg9mdr
04 Jul 2024 11:24
Category: Deutsch
gern geschehen
die Sache mit dem Hub hat mich zwei Tage Zeit und Nerven gekostet, als ich mein WHB-Handrad angeschlossen habe.
  • meister
  • meister
04 Jul 2024 11:18
  • meister
  • meister
04 Jul 2024 11:15
Can I use Raspberry Pi 5 for Linuxcnc + ESP32 + W5500 for generating step pulses
wow, ok, in germany/amazon (not the cheapest):
Pi5/4GB = 67,84€
PI4/2GB = 47,80€
  • Altenthaler1988
  • Altenthaler1988
04 Jul 2024 11:14 - 04 Jul 2024 11:17
Replied by Altenthaler1988 on topic qtplasmac "torch not showing"
Category: Plasmac
ich weis habs nur ausprobiert weil man den jitter ermitteln soll. ich habe schon viel ausprobiert aber nichts hilft.
was ich noch probieren werde eine ältere als 2.9.2 zu installieren
04 Jul 2024 11:12
Sorry but i do not use RPI's at all,and that will not change untill their price drops back to under 50$.
Sorry, why not ? i like the RPI's, especially via SPI
It is 150 Euro here, be it 4 or 5, i can get a full used PC for that money.
  • Muftijaja
  • Muftijaja
04 Jul 2024 11:10
Category: Deutsch
Danke Dir, dg9mdr! Ich hatte das USB tatsächlich an einem Hub hängen, das ging nicht. Direkt am PC tada! Ging sofort mit allen Funktionen, auch Doppelklick (was wohl manchmal nicht ging). Und auch im LCNC (QTDragon GUI).
Wenn alles so einfach wäre :)
Danke und LG Arno
04 Jul 2024 11:09
Replied by tommylight on topic qtplasmac "torch not showing"
Category: Plasmac
Das muss 1000000 sien, nicht 25000.
Displaying 25456 - 25470 out of 25544 results.
Time to create page: 0.649 seconds
