  • jeffmaxwell
  • jeffmaxwell
10 Jun 2026 00:20
Steps to make a bootable USB to install LinuxCNC.
I am trying to  install the Trixie/Debian/linux cnc  image that RodW recommends. Can't seem to find the right steps. I have the mesa cards,
HP core I5 computer with 16 gigs of ram and 1 tb hard drive.  I have been using computers for a long time but I can't seem to make any progress
doing this install. Suggestions?  Any help will be much appreciated. I have had the Plug and Go kit for a few years and would like to get it working for the control of an engraving machine I am building.  Thanks Jeff
  • Fastfred
  • Fastfred
10 Jun 2026 00:06
How to enter tool lenght was created by Fastfred
Hi if someone could explain or give a link how to measure tool length using a ER20 and tool setter for first time to enter the length in the tool library , tool setter working using Flexgui with M6 remap working if there is a gcode example someone could show me ?
Thanks Fred
  • MarkoPolo
  • MarkoPolo
09 Jun 2026 23:28
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
Hi Cmorley
For a while now, the 50/100 "max velocity override" buttons and the slider haven't been working. It turned out the connections (signals/slots) had disappeared. I fixed the problem and also tweaked some minor things. The red LEDs in the two axis buttons were red instead of pink, like the other buttons. I removed the blank pages on the 4th and 5th axis buttons.
  • scsmith1451
  • scsmith1451's Avatar
09 Jun 2026 19:44
Replied by scsmith1451 on topic Launching gladevcp panel with gmoccapy
Category: Gmoccapy
After much frustration, I finally have the gladevcp working with GMOCCAPY. All of the features I wanted to implement are working almost as expected.
At this point I find that when I activate the laser pointer from the gladevcp panel, then jogging is blocked regardless of which tab is currently active. It appears that when the toggle is active, it blocks all other functionality of LCNC. Once the toggle is deactivated, all features return to normal. Does anyone have insight regarding this issue?
Also, I googled how to close a floating vcp panel during shutdown and implementing a python handler for the GtkWidget "destroy" signal did not appear to work. Does anyone have an python example for implementation of the "destroy" signal in a gladevcp panel or have an example of how to close a vcp panel on shutdown?
  • currinh
  • currinh's Avatar
09 Jun 2026 18:05
Replied by currinh on topic XYZA Simulation Install Problems
Category: Basic Configuration
Tommy: I finally found one as "sim.axis.wrapped-rotary". If you, or others, know of more I'd like to hear of them. But you're not missing anything I see, it's more my search skills that are missing.
Aciera's comment regarding adding a "!" to [DISPLAY] GEOMETRY line implements a rotary axis over a tilting spindle motion. That seems to be the missing link to get "axis" working for my implementation.
Thank you.
  • currinh
  • currinh's Avatar
09 Jun 2026 17:56
YES. I finally found a simulation model, sim.axis.wrapped-rotary, using XYZA. I added the line GEOMETRY = !AXYZ to [DISPLAY] and the axis display acts as it should for a rotary table on A. The "!" did the trick.
I loaded the vismach axis sim model. The axis display has the same problem as above, I'll try the "!" fix which I expect will also work here. The vismach display does function as I expected, moving part with table(s).
These should work for me. Thank you very much for the help. I will have to change units to inches and the envelope size of the machine before my code(s) will run. Also figure out how these simulations implement tool offsets. But thanks to you I see a light at the end of the tunnel.
THANK YOU!
  • Aciera
  • Aciera's Avatar
09 Jun 2026 17:48
Replied by Aciera on topic Maschine faehrt Endschlter nicht an
Was heisst sind nicht 'ansprechbar'? Die Pins scheinen angezeigt zu werden.
Kommt der Fehler gleich nach dem öffnen von 'Halshow', wenn du etwas anklickst oder wenn du einen HAL-Befehl auführst?
  • Muecke
  • Muecke's Avatar
09 Jun 2026 17:31 - 09 Jun 2026 18:07
Nach Umzug der LinuxCNC-Konfiguration auf neuen Rechner sporadische Positionsfeh
Category: Deutsch
Diese Daten stammen alle vom Debian 13 - Rechner !
Mac: Adressen.
cnc@debian13:~$ ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: MesaCard: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP mode DEFAULT group default qlen 1000
link/ether 58:04:4f:81:90:04 brd ff:ff:ff:ff:ff:ff
altname enx58044f819004
3: EtherCAT: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000
link/ether 58:04:4f:81:9a:7d brd ff:ff:ff:ff:ff:ff
altname enx58044f819a7d
4: Internet: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP mode DEFAULT group default qlen 1000
link/ether 38:d5:47:df:4c:2f brd ff:ff:ff:ff:ff:ff
altname enx38d547df4c2f
cnc@debian13:~$
> Auf alle fälle fliegt deine Mesa Karte raus.
cnc@debian13:~$ ping 192.168.1.10
PING 192.168.1.10 (192.168.1.10) 56(84) bytes of data.
64 bytes from 192.168.1.10: icmp_seq=1 ttl=64 time=0.015 ms
64 bytes from 192.168.1.10: icmp_seq=2 ttl=64 time=0.020 ms
64 bytes from 192.168.1.10: icmp_seq=3 ttl=64 time=0.024 ms
64 bytes from 192.168.1.10: icmp_seq=4 ttl=64 time=0.020 ms
64 bytes from 192.168.1.10: icmp_seq=5 ttl=64 time=0.021 ms
64 bytes from 192.168.1.10: icmp_seq=6 ttl=64 time=0.018 ms
64 bytes from 192.168.1.10: icmp_seq=7 ttl=64 time=0.016 ms
^C
--- 192.168.1.10 ping statistics ---
7 packets transmitted, 7 received, 0% packet loss, time 6135ms
rtt min/avg/max/mdev = 0.015/0.019/0.024/0.003 ms
cnc@debian13:~$
Ich bin mir nicht sicher was du meinst.
in der INI steht
[HM2]
DRIVER = hm2_eth
ADDRESS = 192.168.1.121
IPADDRESS = 192.168.1.121
cnc@debian13:~$ ping 192.168.1.121
PING 192.168.1.121 (192.168.1.121) 56(84) bytes of data.
64 bytes from 192.168.1.121: icmp_seq=1 ttl=64 time=0.170 ms
64 bytes from 192.168.1.121: icmp_seq=2 ttl=64 time=0.113 ms
64 bytes from 192.168.1.121: icmp_seq=3 ttl=64 time=0.086 ms
64 bytes from 192.168.1.121: icmp_seq=4 ttl=64 time=0.109 ms
64 bytes from 192.168.1.121: icmp_seq=5 ttl=64 time=0.057 ms
64 bytes from 192.168.1.121: icmp_seq=6 ttl=64 time=0.059 ms
64 bytes from 192.168.1.121: icmp_seq=7 ttl=64 time=0.086 ms
64 bytes from 192.168.1.121: icmp_seq=8 ttl=64 time=0.098 ms
64 bytes from 192.168.1.121: icmp_seq=9 ttl=64 time=0.069 ms
^C
--- 192.168.1.121 ping statistics ---
9 packets transmitted, 9 received, 0% packet loss, time 8198ms
rtt min/avg/max/mdev = 0.057/0.094/0.170/0.032 ms
cnc@debian13:~$
Habe die IP in der INI geändert auf:
[HM2]
DRIVER = hm2_eth
Maschine Demo2023 lässt sich nicht starten, Bericht im Anhang, da die Adresse nicht stimmt.
Adresse habe ich wieder zurück geändert.
Ich weis gerade nicht was ich bei der Installation der Mesakarte noch überprüfen soll / kann.
[EDIT]
habe gerade die Fehlermeldung, erhalten nach dem Start unten Rechts im AXIS
hm/hm_7i95.0: error finishing read! item=9
  • Muecke
  • Muecke's Avatar
09 Jun 2026 15:18 - 09 Jun 2026 15:27
Category: Deutsch
Servus,
Antwort: Eingerichtet habe ich das über die ISO ;-) von der LinuxCNC.org-Seite, also Debian 13 inkl. LinuxCNC.
Ich habe die LinuxCNC-Konfiguration „demo2023“ vom Debian-12-Rechner kopiert und 1:1 auf den Debian-13-Rechner übertragen.
> Dein Debian 12 lief auf
> enp1s0: 90:1b:0e:c4:87:3a
> enp2s0: 08:be:ac:22:81:a7
Richtig, Debian 12 hatte zwei Netzwerkkarten: eine für Internet und eine für die Mesa-Karte.
Der neue Debian-13-Rechner hat drei Netzwerkkarten, da jetzt noch die EtherCAT-Sachen dazugekommen sind.
> Jetzt auf enp3s0 und enp4s0 (zugehörige MAC-Adressen??)
Das muss ich noch nachschauen. Ich denke, ich schaffe das heute gegen ca. 18 Uhr.
> Auf alle Fälle fliegt Deine Mesa-Karte raus.
Ok, was bedeutet das genau?
LinuxCNC findet die Mesa-Karte grundsätzlich, verliert diese aber im laufenden Betrieb?
> Gehe noch mal die Installationsschritte von Mesa durch und prüfe die Zuordnungen der MAC-Adressen.
Das war damals über das mitgelieferte Tool, wenn ich mich richtig erinnere. Oder musste ich das damals separat herunterladen? Das muss ich noch einmal nachschauen.
Ganz dunkel kommt mir da noch etwas in Erinnerung, dass bei der Einrichtung der Mesa-Karte etwas wegen der Zuordnung bzw. Netzwerkkonfiguration gemacht werden musste.
[EDIT]Das ist schon etwas peinlich für mich. Die Einrichtung der Netzwerkkarte habe ich sogar schriftlich festgehalten.
forum.linuxcnc.org/42-deutsch/49291-zwei...sa-internet?start=10
  • karlhe
  • karlhe
09 Jun 2026 15:01
Maschine faehrt Endschlter nicht an was created by karlhe
Hallo ich brauche mal wieder Hilfe....
Meine Maschie startet, lässt sich in allen Achsen verfahren.
Die Refernzschalter werden nicht erkannt. Bei der Kontrolle in der Hal sind die   Endschalter nicht ansprechbar.
Fehlermeldung im Foto
  • Aciera
  • Aciera's Avatar
09 Jun 2026 13:42 - 09 Jun 2026 14:44
Replied by Aciera on topic XYZA Simulation Install Problems
For a preview with A axis work side rotation have a look at the '!' feature that can be used in the [DISPLAY] GEOMETRY setting in the ini file:
GEOMETRY = !AXYZ
Note that the above option cannot handle offsets.
See this thread for more:
forum.linuxcnc.org/10-advanced-configura...axis-display?start=0
If you want a vismach model to run the code and  have the tool path rotating  with the part have a look at:
configs/sim/axis/vismach/5axis/table-dual-rotary
This is an XYZAB kinematic with A being a work side rotation (for your purpose you can simply ignore the B axis and the 'TCP' mode):
  • rodw
  • rodw's Avatar
09 Jun 2026 11:58
Replied by rodw on topic Measurement Only Axes
I think you should use this
linuxcnc.org/docs/html/gui/mdro.html#_ini_file_options
Otherwise LinuxCNC needs to command your motion which you are not doing.
I'd love to see a config where you simply enter a bend list and it does the maths to determine the commanded position
  • gmr
  • gmr
09 Jun 2026 10:12
Measurement Only Axes was created by gmr
Hi All,
I am trying to add a measurement only axis to my press brake. The machine is hydraulic (a Promecam) and the bottom bed moves up when the pedal is pushed. I have put a linear scale on the bottom bed so I can measure how much it travels up. I want to measure how far it travels exactly, so I can relate this to the bent angle of the metal.
Anyway, I have added a W axis to the INI and introduced a new joint (joint 1) for it. I can see this in the Axis GUI and it all works nicely, when the encoder moves, the W axis value updates. But when I type "g92 w0" to set a zero point, it doesn't set it to zero. I think this is because the dummy joint I have added for it isn't getting its command position updated. Please see config snippet below:
HAL file excerpt
# Setup bed axis (W)
# (this is a DRO only, and just measures the bending depth we actually reach)
# position and velocity feedback
net w-pos-fb <= hm2_7c81.0.encoder.01.position
net w-pos-fb => joint.1.motor-pos-fb
# linear axis encoder, w axis
setp hm2_7c81.0.encoder.01.scale  -200        # this many pulses per mm
setp hm2_7c81.0.encoder.01.filter 0           # no filtering
setp hm2_7c81.0.encoder.01.index-enable true  # encoder has an index
INI file excerpt
# Axis W - this is the linear scale on the bed
# it needs a dummy joint
[AXIS_W]
MIN_LIMIT = -200.0
MAX_LIMIT = 200.0
MAX_VELOCITY = 10.0
MAX_ACCELERATION = 50.0
LOCK_VELOCITY = 0.0
LOCK_ACCELERATION = 0.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 100.0
MAX_ACCELERATION = 500.0
# axis will appear homed immediately
HOME_SEARCH_VEL = 0.0
HOME_LATCH_VEL  = 0.0
HOME_USE_INDEX  = NO
HOME_SEQUENCE   = 0
FERROR = 99999.0
MIN_FERROR = 99999.0
Any thoughts?
Thanks,
Greg
  • grandixximo
  • grandixximo's Avatar
09 Jun 2026 08:44
Replied by grandixximo on topic XYZA Simulation Install Problems
axis has 3 axis or 9, I mean 9 will work for testing 4...
  • rodw
  • rodw's Avatar
09 Jun 2026 07:06
Replied by rodw on topic Working with VLAN
Working with VLAN
It would be much easier to ditch the vlans, flick the switch on the Mesa card so it is set to 10.10.10.10
And set the PC's NIC on that segment to be 10.10.10.1
Please read man hm2_eth on how to set this up.
Displaying 2551 - 2565 out of 13408 results.
Time to create page: 1.292 seconds
