  • spumco
  • spumco
22 Jan 2025 13:44 - 22 Jan 2025 13:46
Replied by spumco on topic Spindle location on the opposite side
Category: AXIS
The one labeled Remora
I just edited my last post after having a think.  Ignore the STEP_SCALE value from the wrong INI... but apply the concept and put a minus sign in front of your existing value.
  • Murphy
  • Murphy
22 Jan 2025 13:40
Replied by Murphy on topic Spindle location on the opposite side
Category: AXIS
  • JT
  • JT's Avatar
22 Jan 2025 13:23
Replied by JT on topic Flexible GUI
Flexible GUI
Category: Flex GUI
Didn't get a chance to update and try the label yet as I'm working on the hal file at the moment. Couple of things I'm noticing now that I'm running some sims......
Since I added a qss, INPUT = TOUCH seems to not have an effect anymore. Pretty sure I had the touch style file browser before the qss but now it is back to the normal one.
The file browser is a little hard to navigate because it doesn't show the current directory, easy to get lost. Any chance you can add current directory at the top or something?
The flood and mist push buttons disable when a program is running. I'm used to Gmoccapy where you can still operate the mist and flood while running a program. Sometimes I forget to add coolant to the program and need to turn it on when it's running. Not quite sure why yet but as soon as the GUI disables coolant even if I stop the program I can't control it again with the hal buttons until I first turn it on with the GUI buttons.
The ini entry INPUT is now THEME gnipsel.com/linuxcnc/flexgui/ini.html#themes
Which file browser, the keyboard or the touch screen?
Good point on the flood and mist and I see no reason to disable them at any time and that has been fixed.
JT
  • behai
  • behai
22 Jan 2025 12:35
Replied by behai on topic network configuration.
I would not use the 192.xxx.xxx.xxx range, but rather set the 7I96s
to 10.10.10.10 = W4 down W5 up +power cycle and set the host address
to 10.10.10.100:
auto eth0
iface eth0 inet static
address 10.10.10.100
hardware-irq-coalesce-rx-usecs 0
Thank you for your reply. I would like to use 10.10.10.10 also: I have read the manual on this part and I have watch some set up vidoes for this card too. But I am not entirely certain about the jumpers. Please refer to the attached image:
To pull W4 down, do I just push that shiny piece pointed to by the green arrow down, please?
Thank you and best regards,
...behai.
  • behai
  • behai
22 Jan 2025 12:28
Please watch my video
start at about 16 minutes in if you want to get to the section on networking
Thank you very much for your suggestion, I did watch the entire video. I understand your explanation on the TCP/IP protocol.
Best regards,
...behai.
  • spumco
  • spumco
22 Jan 2025 12:12 - 22 Jan 2025 13:43
Category: AXIS
Which of the three INI files is yours?
EDIT -
The search velocity for home is a positive number. It should be negative? But I change it it goes the wrong way.
Your home/limit switch is to the operator's left (towards spindle) - i.e. Z-negative.
If you edit your INI file so that the initial home search is negative, but the Z-axis moves to the right, this suggests your Z-axis motor direction is backwards.
You can change the Z motor direction in INI by changing the sign of the step scale (to positive):
[JOINT_1]
STEP_SCALE = 50799.998
Try changing the motor direction and set your homing direction as negative and latch velocity as positive:
HOME_SEARCH_VEL = (negative number)
HOME_LATCH_VEL= (positive number)
Once you get this sorted, you may also want to adjust your home offset so that the Z-positions are more like 'normal' CNC lathes.  "Normal" lathes have G53 Z0 at the extreme limit away from the chuck/spindle.  Commanding a 'G53 G0 Z0' will result in the turret/slide moving to the safest position (extreme right end).
If you leave the home position (G53 Z0) near the spindle end you'll have to be very careful about G53 and G28 homing moves since LCNC has no idea what chuck is mounted or what stock is in the chuck.
  • blazini36
  • blazini36
22 Jan 2025 12:09
Replied by blazini36 on topic Flexible GUI
Flexible GUI
Category: Flex GUI
  • Murphy
  • Murphy
22 Jan 2025 12:05 - 22 Jan 2025 13:42
Category: AXIS
I tried every possible combination with the X axis limits and homing. Still isn't working. I noticed something with the Z axis. The search velocity for home is a positive number. It should be negative? But I change it it goes the wrong way. My limits for Z are 250 positive away from the spindle. And 40 negative pass homing.Iv attached two other working ini files from other people. Iv noticed in one of them that for X axis the search velocity is positive. That would bring it up but the home switch is in the negative direction. Is there other settings somewhere else in a file for machine setup ?
  • juliankoenig87
  • juliankoenig87
22 Jan 2025 11:15
Replied by juliankoenig87 on topic scurve trajectory planner
Ok. As long as I am aware of it I can handle with it and I will choose smaller values.
Right now I am trying to get a 4 axis Machine running. Right now the scurve tp is making a lot dump things.
Grotius, do you have a 4 axis sim machine running to play with?
22 Jan 2025 11:08
Replied by Cant do this anymore bye all on topic Homing an axis moves away from home switch!
Category: StepConf Wizard
Boot into Ubuntu, mount the linuxcnc partition and bingo you have access to the files.
But if you can’t do that what’s more annoying, copying the files or not being happy with your machine ?
If you want to be helped you need to provide the info.
Without the info it’s hard to impossible for those helping and you don’t get the answers you require.
  • Aciera
  • Aciera's Avatar
22 Jan 2025 11:05 - 22 Jan 2025 13:20
Replied by Aciera on topic scurve trajectory planner
Yes, the problem with using a fixed blend radius on all segment intersections would be that the path deviation depended on the angle at which the two segments intersect, which would be rather unfortunate (If that is indeed what it is doing). For angles larger than 60° the blend radius and thus the feed rate could actually be larger for a 0.1mm deviation while angles below 60° would require a smaller blend radius to stay within a maximum deviation of 0.1mm.
  • vpomerleau
  • vpomerleau
22 Jan 2025 10:04
Replied by vpomerleau on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi Cakeslob! Thank you for your reply. I attached some picture of my mill for clarity. So I got 1710 RPM motor with a fixed 1.8:1 pulley ratio, the encoder is on top of the second pulley, after that I have a lever for High/Low lever that with a 8.3:1 ratio. It's possible to put the encoder after all that but a lot of work. So my ultimate goal is when I call M3 S1650 the control output what he think is the correct 0-10v voltage, read the value from the single pulse Hall sensor and adjust the voltage to hit the target perfectly. I think it's closed loop. The cherry on top would be the ability of rigid tapping but not sure if it is possible with my current configuration. Probably a lot of work and if I need another kind of encoder i'm willing to replace it, i started this project 5 years ago and i'm not in a hurry. If I understand correctly, the remora PRUencoder doesn't work with single pulse hall sensor so your code is probably not suitable for my setup. The maximum pulse frequency is 5000/minute, does the EC-500 can handle that?
Displaying 19786 - 19797 out of 19797 results.
Time to create page: 0.428 seconds
