  • Konstantin
  • Konstantin
26 Apr 2026 13:10
Replied by Konstantin on topic CiA 402 Folder Missing
Category: EtherCAT
In the weekend I had some more time to experiment but there is no success yet. I read the link about absolute homing for A6 servo again and checked all of the example files. Before I missed to copy this line
#net x-statusword lcec.0.X.status-word => cia402.0.statusword => joint.0.cia-statusword
Now, LinuxCNC reports missing pins again but there is a new pin that cannot be found - "lcec.0.0.status-word". This is the first line where error appears and LinuxCNC is terminated. The pins "joint.0.request-cia-homing" and "joint.0.start-cia-homing" are reported not found as well.
I am still confused about the guide for A6 servos, which parts need to be uncommented on the first reference run? By the way, my servo drives does not have a settings for choosing incremental or absolute encoders.
Attached are the configuration files.
26 Apr 2026 11:52
Replied by tommylight on topic MESA card (LAN) failing to connect.
If you had of followed the link It would have taken you to the exact spot about 16 minutes in where I discuss the networking in that 50 minutes. Its a very old video now but still current.
OK, that is nice, so i am sorry for bantering, i have every security feature enabled here so for me it starts from the beginning.
  • pippin88
  • pippin88
26 Apr 2026 10:52
NoHAL - Visual editor for LinuxCNC machine configuration
Category: Configuration Tools
This is a great idea.
(I'm not in a position to test it any time soon sorry).
My guess is calling it something like VisualHAL might be more intuitive?
  • Hakan
  • Hakan
26 Apr 2026 09:38
Replied by Hakan on topic JetCad3 CAD/CAM
JetCad3 CAD/CAM
Category: Show Your Stuff
I tried the plasma part a bit. Nesting and placing works very well,
really nice. Also made a quick post processor for PlasmaC.
Pretty rudimentary, remove feeds and Z movements and add a few lines in the header.
I'm not going to be part of the development of this software, just wanted to give a quick
micro-review after spending maybe an hour in it. It's nice, modern look, interactive
and I got going without instructions.
I can see myself using it occasionally, for nesting/placing many parts.
  • Omelinet
  • Omelinet
26 Apr 2026 09:03
Interface localization into Ukrainian was created by Omelinet
Category: QtPyVCP
Hello everyone, I'm new here.
I have a problem, I got a machine that has linuxcnc and Probe Basic
I tried to translate myself using QT Designer, but I was only able to do it for a few points. When I started translating more, my Probe Basic stopped running.
Maybe someone can tell me which files need to be translated. Because I even edited the .PY file but my Probe Basic still started in English.
P.S. If there is already a link to a forum or discussion, I would be grateful if you could direct me. Thanks
  • rodw
  • rodw's Avatar
26 Apr 2026 08:31 - 26 Apr 2026 08:32
Replied by rodw on topic MESA card (LAN) failing to connect.
@RodW,
50 minute video for a 3 minute setup, really?
Here is everything in one place and does not take 50 minutes:
forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
26 Apr 2026 01:38
@RodW,
  • grandixximo
  • grandixximo's Avatar
26 Apr 2026 00:57
Replied by grandixximo on topic lcnc-suite — web UI for LinuxCNC
Category: Other User Interfaces
Looks very nice, good job, keep it up ;-)
  • grandixximo
26 Apr 2026 00:34
Replied by grandixximo on topic MESA card (LAN) failing to connect.
the 7i77 needs 5v power supply as well, I think
  • rodw
  • rodw's Avatar
25 Apr 2026 23:27
Replied by rodw on topic HAL component for tangential knife
Category: HAL
We are not out of the woods yet. When I pushed this back to my GitHub, it failed some of the gcode tests.
github.com/rodw-au/linuxcnc/actions
I kind of know what's going on. I just need time to get to make some changes. Just need to add stuff to reset functions.
  • rodw
  • rodw's Avatar
25 Apr 2026 23:16
This link into one of my videos explains it, Simple networking setup. Its not plug and play
  • rodw
  • rodw's Avatar
25 Apr 2026 23:12
Replied by rodw on topic lcnc-suite — web UI for LinuxCNC
Looks fantastic. Its great seeing more UI options beyond Qt. Just curious, is the display optimized for touch or keyboard input?
Being more of a C/C++ person, I’ve been building a similar pet project focused on a C++ interface layer for LinuxCNC. The idea was to wrap both the NML and HAL polling sides in a clean, multi-client-safe bridge so the same core can support a WebSocket interface for remote clients and a Node.js addon for local UIs. The main goal is to decouple machine access from the frontend layer, making it possible to run multiple displays and control interfaces against a single machine. It's proving to be about as much work as I anticipated ;)
Don't stop this project.
  • Askjerry
  • Askjerry's Avatar
25 Apr 2026 22:52
MESA card (LAN) failing to connect. was created by Askjerry
One of my subscribers is having an issue. Unfortunately, I have not yet tried using the LAN-style MESA card, so I am unsure how to help him.
Jere is the message I got:
"Hi Jerry,I have a Mesa 7i92 card that is plugged into the Ethernet on my computer.  It is also connected to a 7i77 daughter card, and I have a 5v power supply going into the 7i92."
Do any of you have some tips that might be helpful?
Thanks,
Jerry
  • bedouno
  • bedouno
25 Apr 2026 22:30
Replied by bedouno on topic HAL component for tangential knife
Category: HAL
"Great work, Rod! This looks like a monumental step forward for LinuxCNC.
I believe this branch is the perfect strategy for implementation. It elegantly solves the real-time synchronization issues that have hindered advanced tangential control in the past.
For my part, I have an assignment to study this implementation . You have indeed laid a cornerstone for the system, and I am very excited to leverage your work for this project.
If I may add my opinion: I fully support your point of view regarding the modifications of G_1, G_2, G_3 equates in control.c. I understand the devs' concerns about real-time sanctity, but your approach to code readability (housekeeping) is crucial for the long-term maintainability of such complex code. Finding that balance is the key.
Thank you again for your incredible contribution."
  • lkavan
  • lkavan
25 Apr 2026 20:48
What board do you recommend for pull/dir for a T3D servo drive?
Hallo Peter, T3D drivers exist with encoder output also. I have them in one machine, but I have used them in STEP/DIR mode with Mesa, without encoder feedback. Works fine, but I still hope that analog control from LinuxCNC and Mesa is better. Is it right or not? I also have other machine with Simodrive, there is +-10V control, attached to 7I33 - works perfect many years. But T3D has analog control 0-10V Do you know how does this work? Is it possible to control it with analog servo Mesa cards? I am planning to upgrade next CNC milling machine and looking for motors. I would like to use T3D, but milling machine I do not want to run without encoders feedback...
Displaying 3166 - 3180 out of 13643 results.
Time to create page: 0.300 seconds
