  • rodw
  • rodw's Avatar
25 Mar 2026 20:40
too long hm2_7i97.0.read.tmax or something else?
Category: Driver Boards
What CPU do you have? How many cpus does it report?
what does echo $(nproc) say?
Its possible you are trying to isolate a nonexistent core
  • rodw
  • rodw's Avatar
25 Mar 2026 20:34
Replied by rodw on topic El5101 Config
El5101 Config
Category: EtherCAT
One would like to have a speed output from the drive but there isn't one.
Should be possible to get rps or rpm in the frequency output
by setting proper scaling factor in frequency-scale.
Have not tried it, though.
Should be possible
    65  float OUT             0  lcec.0.El5101.enc-frequency
    65  float I/O          0.05  lcec.0.El5101.enc-frequency-scale
  • Tach0
  • Tach0
25 Mar 2026 20:25
Connect Spindel with 7i96s was created by Tach0
Hello guys,
im new in Linux CNC i wat to connect Linux CNC with my Spindel+YL620a Frequency Converter
via a 7i96s and failed. I dont understand what im doing wrong.....
I connectet the Components like the Picture.
Added this to the Hal
setp hm2_7i96s.0.pwmgen.00.output-type 1
setp hm2_7i96s.0.pwmgen.00.scale [SPINDLE_0]OUTPUT_SCALE
net spindle-vel-cmd-rpm => hm2_7i96s.0.pwmgen.00.value
net spindle-enable => hm2_7i96s.0.pwmgen.00.enable
Added this to the ini
MAX_OUTPUT = 24000.0
OUTPUT_SCALE = 24000
OUTPUT_MIN_LIMIT = 0
OUTPUT_MAX_LIMIT = 24000
Changed the Frequency Converter Settings like in the Picture.
Im grateful for any help or tips.
Thaks in advance
Tach0
  • Xnke
  • Xnke
25 Mar 2026 20:16
Replied by Xnke on topic Mitsubishi Meldas Control and Motors
Category: Milling Machines
Which series of drives do you have? If they are fibre-optic controlled, Dmitry has the cleanest, fastest solution to controlling the drives over the SSCNET III/H control fibres.
If they are copper controlled network drives, then Dmitry has a control for that as well, but you can also run the MESA cards for step/direction interfaces.
  • spumco
  • spumco
25 Mar 2026 20:02
Replied by spumco on topic Lathe C axis homing
Lathe C axis homing
I thought I'd added my HAL file, guess not.
The M-code files still have remnants of my first attempt at switching the drive (internally) between velocity and position modes as in @Aciera's example.  That stuff is commented out; just ignore it if you aren't switching your drive.
If you ARE switching your drive internally, you'll probably want stuff like "M66, check for drive mode" in your M-code file.
  • spumco
  • spumco
25 Mar 2026 19:43
Lathe C axis homing
Good job!
I've renamed my m-codes from the original example, and due to some jitter (servo dithering) when the motor/drive is in position mode I just leave the drive in velocity mode.  LCNC is switched between spindle/orient/positioning.
My M-codes and main spindle HAL file are attached for your review; maybe they can help.
There is quite a bit commented out, but the gist of it is M254/M255 are used to switch between C-axis and spindle mode, using spindle-orient to realign the spindle before re-connecting the C-axis encoder.
M102 & M103 are 'backstage' M-codes used to adjust stepgen & c-axis PID settings (and disconnect index-enable) in a way you can't (I think) do from inside a normal .ngc g-code file.
Let me know if anything is really unclear.
  • PCW
  • PCW's Avatar
25 Mar 2026 19:34
That does not look bad but the max servo thread time shows the issue
( 1624528  clocks at 1.7 Ghz is ~.95 ms)
It may be that the CPU/BIOS-Setup are simply not capable of the needed
network performance for a 1 KHz servo thread.
A last ditch is to use a newer kernel as the 6.1 kernel in the LinuxCNC distribution
is fairly bad latency wise.
7.0.0-rc1-rt1 #1 SMP PREEMPT_RT
Is the current one
  • m0602232
  • m0602232
25 Mar 2026 18:43
whoops, sorry about that.
PING 192.168.1.121 (192.168.1.121) 56(84) bytes of data.
--- 192.168.1.121 ping statistics ---
60000 packets transmitted, 60000 received, 0% packet loss, time 60060ms
rtt min/avg/max/mdev = 0.095/0.118/0.250/0.001 ms
The spikes in following error were indeed caused by graphics. It settled down when I removed one of 2 screens I had attached. Realtime delay error persists though.
  • PCW
  • PCW's Avatar
25 Mar 2026 18:25
Looks like you are pinging the host rather than the 7I97
  • Hakan
  • Hakan
25 Mar 2026 17:01
Replied by Hakan on topic El5101 Config
El5101 Config
Category: EtherCAT
  • m0602232
  • m0602232
25 Mar 2026 16:29
--- 192.168.1.120 ping statistics ---
rtt min/avg/max/mdev = 0.017/0.018/0.079/0.001 ms
All power management disabled.
IRQ coalescing disabled.
pinning the Ethernet IRQ to the last processor does not affect, still getting realtime delay message.
Also tried without hm2.read-request.
I just managed to verify the cause for the spikes visible in halscope. They appear to happen the same interval than the pyvcp graphics refresh. I just can't figure out if it's more of a symptom than a cause.
  • jetbadger
  • jetbadger
25 Mar 2026 16:19
Replied by jetbadger on topic Lathe C axis homing
Lathe C axis homing
I found the error on my part just minutes ago. I had set HOME_SEARCH_VEL != 0 and that was the issue. Caused half a day of headache for myself, but now the C axis homes and after a few tweaks responds to commands to some extent, yay :)
I was homing it from the gmocappy GUI and now the homing bit works great! Now the other problem is with the mcodes and remaps. Calling m419/420 causes errors with "ngc file ended with no % sign or program end" and unknown m119/120 code. Will try to figure that out next.
I have to thank you and Aciera as your work let me actually attempt this :)
  • spumco
  • spumco
25 Mar 2026 16:05
Lathe C axis homing
I based my C-axis config on Aciera's example as well; he really saved my bacon discovering the index-enable synchronized motion bug.
I don't see anything really obvious in your config at first glance...you've got HOME_USE_INDEX in INI set right...
Index-enable signal appears to be connected to everything:
  • encoder
  • spindle
  • orient
  • joint
  • pid-spindle
  • pid-orient
  • pid-axis
Have you tried orienting the spindle yet?
How are you trying to home joint 2?  Home-all, or just that joint/axis?  halui or something else?
What actually happens when you try to home joint 2?  Keep spinning forever, doesn't move, or something else?
Just for reference, my config starts up in C-axis mode, and there are (software) restrictions so I can't put it in spindle mode until the Caxis is homed.
# MAIN SPINDLE IS-HOMED SIGNAL - SWITCH FROM CAXIS TO SPINDLE MODE
setp oneshot.s0home.width   1
net SPIN0-CAXIS-IS-HOMED    <=  joint.2.homed           #TO 02IO.HAL, M254/M255, AND PID.C MAXOUTPUT
net SPIN0-CAXIS-IS-HOMED    =>  oneshot.s0home.in
net SPIN0-HOME-MODE-SWITCH  <=  oneshot.s0home.out
net SPIN0-HOME-MODE-SWITCH  =>  halui.mdi-command-02    #CALL M255 TO PUT MAIN SPINDLE BACK TO SPINDLE MODE AFTER INITIAL CAXIS HOMING
I could post my config, but it's really complicated and not in a final-final state just yet.  If you/we cant get yours sorted out quickly I'll post it for you to try to digest.
  • AntonioT
  • AntonioT
25 Mar 2026 15:57
THC not getting active even when "all seemingly needed" requirements are met
Category: Plasmac
i see, will look at it too. Was the HF start giving you issues with THC?
  • PCW
  • PCW's Avatar
25 Mar 2026 15:40 - 25 Mar 2026 15:41
read-request is only intended for use with multiple Ethernet cards
What does:
sudo chrt 99 ping -i .001 -q -c 60000 10.10.10.10
report? (it will run 1 minute and print timing statistics)
(replace 10.10.10.10 by card IP address if that differs)
Is all power management disabled in the BIOS?
If the PC has a Intel MAC have you disabled IRQ coalescing (man hm2_eth)
One further step is to pin the Ethernet IRQ to the last processor
Displaying 4486 - 4500 out of 13556 results.
Time to create page: 2.711 seconds
