  • jtrantow
  • jtrantow
10 Feb 2026 20:21 - 10 Feb 2026 21:40
Replied by jtrantow on topic HAL Edits for RS485 / VFD Spindle Control
Category: HAL
Looks like you have a very simple VFD/Spindle setup. If you are using a simple spindle setup that may be enough. If you have a machine with any type of gear ration between the motor and spindle the following may be of use.I'm using RS485 VFD to control the spindle on three different machines:
  • Router - high speed spindle 24000 RPM with a CommanderSK VFD (capable of 1000hz).
  • Mill - Six pulley combinations connected to nominal 1725 RPM @ 60 hz motor with a GS2 VFD. [MANUAL BELT CHANGE]
  • Lathe - Six pulley combinations connected to nominal 1750 RPM @ 60 hz motor with a CommanderSK VFD. [MANUAL BELT CHANGE]
    With the Router I don't have to worry about gearing changes (or sending commands greater than the VFD can handle).
    With the Mill and Lathe, I only recently figured out a way to easily change scaling to match the gearing using pid FF0.
    Using PID component is nice for several reasons:
    1. I can use the gmoccapy/Calibration to change/test/save [SPINDLE_0]FF0 while running linuxcnc whenever I change belts.
    2. I can set [SPINDLE_0]MAX_OUTPUT to avoid sending illegal RPM commands to the VFD which get ignored and can cause a crash if you aren't checking the at-speed status.I added a [SPINDLE_0]MAXIMUM_MOTOR_RPM parameter to the .ini and kick off a message to change belt if the motor RPM is maxed out.
      Here are my additions to Mill.ini for this implementation:
      Mill.ini
      [DISPLAY]
      MESSAGE_BOLDTEXT = NONE
      MESSAGE_TEXT = VFD using maximum motor RPM.
      MESSAGE_TYPE = okdialog
      MESSAGE_PINNAME = VFD-max-motor-rpm
      [SPINDLE_0]
      P = 0
      I = 0
      D = 0
      FF0 = 1.135
      [code]MAX_OUTPUT = 1799
      [/code]
In the near future I intend to redo my spindle encoders and use the forum.linuxcnc.org/47-hal-examples/27071-automatic-spindle-gea idea to automatically choose FF0.
  • Elco
  • Elco
10 Feb 2026 19:35 - 11 Feb 2026 08:12
Replied by Elco on topic Problème Carte PCIE parallèle
Juste quelque mA. Par exemple depuis 5V avec 1,5 kOhm en série.
Continuons  si nécessaire dans forum.linuxcnc.org/46-francais
Robert
  • sconisbee
  • sconisbee
10 Feb 2026 19:23
Replied by sconisbee on topic G33.1 K word missing
Category: G&M Codes
Ahhh thank you, I completely missed the G0 missing from the line after g33.1
  • MaHa
  • MaHa
10 Feb 2026 19:07
Replied by MaHa on topic G33.1 K word missing
Category: G&M Codes
You need to 'cancel' G33.1,  a G0 or G1 on the next line will help
  • Mbrand1901
  • Mbrand1901
10 Feb 2026 18:57 - 10 Feb 2026 18:59
Replied by Mbrand1901 on topic Retrofitting Deckel FP4ATC
Category: Milling Machines
Hello Guys!
Finally I have some updates !
The linear scales are working! Note to my selfe: dont trust anyone in the internet.
I will make a sheet, where I will draw up the connection between the exe and the mesacard. Next on the list are the endswiches and the e stop. Hopefully it will move on its own by the end of the week.
Here a pictue of the conector of the exe:
  • turbohoolik
  • turbohoolik
10 Feb 2026 18:34
Soft limits are not working all the time... was created by turbohoolik
Category: Basic Configuration
My soft limits are not working all the time. Machine is running over them to hard limit switch. When I back off machine from hard limit switch soft limit will work until next startup.
  • Muecke
  • Muecke's Avatar
10 Feb 2026 17:18
Unterstützung bei LinuxCNC + EtherCAT + Servos gesucht (Raum Stuttgart / Remote,
Category: Deutsch
I will read through it and will certainly have questions, which I will then ask here.
Thanks in advance.
Best regards, Mücke
  • Gogonfa
  • Gogonfa
10 Feb 2026 16:50 - 10 Feb 2026 16:51
Replied by Gogonfa on topic How good is Ethercat motion control?
Category: EtherCAT
@Hakan:
I would always home using the encoder index (Z-pulse) if it’s available, since it’s the most accurate and repeatable method. When the index is latched close to the encoder or in the drive, homing accuracy is essentially independent of fieldbus or servo latency. I use it with the Probe Basic and it works perfect ;-)
You are absolutly right! For probing, the usual and sensible approach is a two-step process:
Fast search pass to find the edge
Even with e.g. 3-4 servo cycles of delay (≈4 ms), probing can be much faster than often assumed.
If you allow 1 mm total overtravel, including braking, and assume a realistic probing deceleration of about 1000 mm/s², the maximum safe speed is still around 40 mm/s ≈ 2450 mm/min.
Slow precision pass
After backing off, the second pass is done very slowly, typically 0.5–1 mm/s.
With a 4 ms delay, this corresponds to only 2–4 µm of additional travel due to latency. At that point, accuracy is dominated by machine repeatability and machine stiffness, not bus or servo delay.
So in short:
Homing: use encoder index --> highest accuracy, latency-independent
Probing: fast find + slow precision pass --> latency is not a practical limitation if speeds are chosen sensibly
Latency really only becomes an issue if someone tries to do single-pass, high-speed precision probing, which is not standard practice anyway.
  • sconisbee
  • sconisbee
10 Feb 2026 16:30
G33.1 K word missing was created by sconisbee
Category: G&M Codes
Good Afternoon all,
I have the below snippet of Gcode in a larger program, LinuxCNC gives me an error saying that K word missing for G33/G33.1 when i load or run the program.  However, the G33.1 is used on its own in a simple program or in MDI and it works fine.  The program also runs correctly but halts after the g33.1 and does not go back home or switch spindle off etc.
Any thoughts from those more knowledgable in this area?
[code
]N84 T30 M6 G43
N86 G90
N88 M8
N89 S500 M3
N90 G0 X0.0 Z15.0
N91 G0 Z5.0
N94 G33.1 Z-14.5 K1.058
N95 Z15.0
N96 M9
N97 M5
N98 G53 G0 X0.
N99 G53 G0 Z0.
N100 M30
[/code]
  • PCW
  • PCW's Avatar
10 Feb 2026 16:04
  • PCW
  • PCW's Avatar
10 Feb 2026 15:43 - 10 Feb 2026 16:05
Using 7c81 with 5v encoder on bob3 config
Category: Driver Boards
That looks OK but unless the low level signal is < 0.8V it cannot work.
That is, this is a hardware/interfacing issue.
The 7C81 inputs are fine with 5V signals but 1.8V is an indeterminate level
for the TTL level signals that the 7C81 expects
Do you have a data sheet for the encoder?
  • Bansardo
  • Bansardo
10 Feb 2026 15:16
Replied by Bansardo on topic Can the OPI5 be Configured to Run LCNC?
Sorry for the late reply, that image should also work for de OPI5 plus if you only edit in "armbianEnv.txt" the line:
fdtfile=rockchip/rk3588s-orangepi-5.dtb
to:
fdtfile=rockchip/rk3588-orangepi-5-plus.dtb
No it's wont boot (
  • Finngineering
  • Finngineering
10 Feb 2026 14:42
Replied by Finngineering on topic XHC WHB04B development?
Yes, I think its realistic to write a new firmware. The goal would be to have the pendant fully reliable and also proper detection if the RF link fails, possibly some other improvements as well.
It doesn't have to be an either/or solution. With the new firmware, I would probably strive to maintain "protocol compatibility", so the same xhc-whb04b-6 component could still be used.
Improving the xhc-whb04b-6 component is certainly possible, and hopefully that could be done as well. For this blocking wait state, I don't really see a clean/simple fix, other than reducing the max blocking time like we have done. And to be honest, the amount of abstractions used in the code makes it difficult to follow for myself.
But this is also one reason why I made this post. To see if others have similar issues (and now you have confirmed that its not only me). Maybe there is somebody else that wouldn't mind updating the xhc-whb04b-6 code, but would need inputs on what to change.
  • Henk
  • Henk
10 Feb 2026 14:19
Yet another firmware request - 7i92T + 7i77 + 7i85
HI PCW
Please be so kind as to provide firmware for a 7i92T + 7i77 + 7i85
Henk
  • Tady
  • Tady
10 Feb 2026 14:18
Gmoccapy 4 axis question was created by Tady
Category: Gmoccapy
Hello
I'm trying to retrofit a friends 5 axis machine (XYYZB) and I'm testing out the example config. The B axis on the nachine is mounted on the Z axis and I would like to visualize this. The thing is the example configs for non-trivial kinematics are based on rotary tables. The principle should work for this macine but I would love to make Gmoccapy show the tool tilting. Since examples use rotary tables the tool is mostly vertical and doesn't move (the table moves).
How can i change this?
Thank you
Displaying 6421 - 6435 out of 13542 results.
Time to create page: 0.386 seconds
