  • andypugh
  • andypugh's Avatar
08 Feb 2026 18:32
Need to install newest Linux Debian Bookworm with the newest Linuxcnc preempt-rt
Category: Installing LinuxCNC
1) Why Bookworm and not Trixie?
2) Why not just install from the ISO image?
It looks like the automatic updater has not updated the manual page to reflect anything since 2.9.4.
You can see what the page is meant to currently say here:
github.com/LinuxCNC/linuxcnc/blob/master...etting-linuxcnc.adoc
  • amanker
  • amanker
08 Feb 2026 18:28
Thanks a lot.
I am attaching my ldscript which I made based on existing ldscripts included in repository. And attaching my platformio.ini.
File Name: STM32F446X...L.ld.txt
File Size:5 KB
File Name: platformio.ini
File Size:3 KB
  • andypugh
  • andypugh's Avatar
08 Feb 2026 18:23
Replied by andypugh on topic Hurco BMC 30 AP
Hurco BMC 30 AP
Category: CNC Machines
It sounds like the servo amps are being enabled without the PIDs being enabled.
Start LinuxCNC from the command-line and make sure that there are no error messages in there.
  • andypugh
  • andypugh's Avatar
08 Feb 2026 18:16 - 08 Feb 2026 18:18
Replied by andypugh on topic HURCO KMB-1 Control Update
Category: Milling Machines
I don't think that Orient uses index.
(It probably should, and adding spindles to the homing sequence is something that I meant to do and seem to have forgotten).
If you were to set the spindle-index-enable in the HAL file then the encoder would be aligned to index as soon as it does a revolution in spindle mode.
The "orient" component exists specifically to account for the many thousands of accumulated turns accumulated in the spindle encoder counter.
If you wanted to re-index on every orient then one way would be to create a modified version of "orient" that outputs an index-enable and that also commands an initial position command morfe than one turn from the starting postition until the index reset is detected.
  • DerKlotz
  • DerKlotz
08 Feb 2026 17:00
Hello,
I've been trying unsuccessfully all weekend to get the latest Debian Bookworm with the latest Linuxcnc preempt-rt up and running. Since I have little experience with Linux, I'm reaching my limits.
I downloaded and installed Debian Bookworm 12.13. Now I wanted to follow these instructions linuxcnc.org/docs/html/getting-started/g...th_preempt_rt_kernel , point 7 (with preempt-RT kernel). Would that be correct so far?
At point 3, Open Applications Menu > System > Synaptic Package Manager, search for linux-image, right-click on the original non-rt, and select Mark for Complete Removal, I don't know which original non-rt I have to select. I have attached a screenshot.
Otherwise, please attach Linux terminal commands so I can quickly achieve my goal.
Greetings from Germany and many thanks.
Translated with DeepL.com (free version)
  • BIBIGUL
  • BIBIGUL
08 Feb 2026 16:35
403 Forbidden was created by BIBIGUL
403 Forbidden
Category: Forum Questions
I created a topic, went into it and - 403 Forbidden. What is it? How to fix?
  • 5_Zylinder
  • 5_Zylinder
08 Feb 2026 16:12
Replied by 5_Zylinder on topic Hurco BMC 30 AP
Hurco BMC 30 AP
Hello everyone, we've now integrated several pushbuttons and switches. The signals are being received and are functioning correctly. However, a new problem has arisen: as soon as I switch on the machine, the X and Y axes start moving immediately, and Linux CNC goes into error mode. I don't recall ever having this problem before. Nothing has been changed in the wiring. Perhaps someone has a crucial suggestion.
  • PCW
  • PCW's Avatar
08 Feb 2026 15:37
Configure Mesa 7i96s and pktuart with Omron MX2 (wj200)
You might try increasing the interval (it's in microseconds so 1000 is just one ms)
And that may be too fast for the Omron
I will look into getting a MX2 to try to have some way of duplicating the issue.
The GS10 setup was straightforword
  • Fl4tty
  • Fl4tty
08 Feb 2026 14:57
Replied by Fl4tty on topic StepperOnline A6 Servo
Category: EtherCAT
I guess you summarize all your servo drives, so 4x400W would roughly be a FN 2090-16-06?
  • Nkbhvid
  • Nkbhvid
08 Feb 2026 13:55
Replied by Nkbhvid on topic Linuxcnc 2.9.4 and Mesa 7i97T
OK
I have given up on making it work after messing up several versions of my hals and inis
Instead i now want to make new ones by using mesaCT like i did from the beginning (the way that so far let me get the most successfull result)
I get an "OK" when trying to test the configuration
But when building the configuration i get this message from meseCT:
File "../../usr/lib/python3/dist-packages/libmesact/buildconfig.py", line 61, in build
    parent.updateini.update(parent, iniFile)
  File "../../usr/lib/python3/dist-packages/libmesact/updateini.py", line 135, in update
    self.update_key(item[0], item[1], item[2])
  File "../../usr/lib/python3/dist-packages/libmesact/updateini.py", line 765, in update_key
    start = self.sections[f'[{section}]'][0]
KeyError
'[MESA]'
First download the deb and reinstall
to be sure you have the latest build date
Then please file an issue at
github.com/jethornton/mesact/issues
  • BIBIGUL
  • BIBIGUL
08 Feb 2026 13:06 - 08 Feb 2026 13:10
Replied by BIBIGUL on topic socket raw Eth.
socket raw Eth.
Hello everyone. Who has ever worked with socket raw on linux cnc? raw socket requires a set cap, does it break Linux Cnc? I wrote a test driver, on raw socket, receiving data via mmap. As a controller, I use STM32F7 (4 PWM encoders). Maybe I'm doing something wrong, I don't understand the specifics of Mesa, but the first tests show some kind of prohibitive bandwidth, the jitter is lower than on mesa.
  • Looby
  • Looby
08 Feb 2026 11:58
Lenovo T14 Gen2 AMD - CRAZY High Latency - Am I screwed?
Ill try the other release and see how it shakes out. Its killing me because I see the T470/T480 in use in that thread and this is just the newer version of that laptop. Also I figured I was safe because this one can be bought from Lenovo with Debian preinstalled.
Sorry to clarify the bios is not password locked its just extremely limited by the manufacturer. Locked down in terms of restricted to basics.
  • Nkbhvid
  • Nkbhvid
08 Feb 2026 11:47 - 08 Feb 2026 13:48
ip a:
File Name: ipareturn.txt
File Size:1 KB
  • Nkbhvid
  • Nkbhvid
08 Feb 2026 11:45
It seems that the connection is ok
mesact finds and recognizes board
ip a return
BROADCAST, MULTICAST, UP, LOWER_UP at 10.10.10.10
  • Mr1576
  • Mr1576
08 Feb 2026 11:12
Replied by Mr1576 on topic HAL Edits for RS485 / VFD Spindle Control
Category: HAL
@andypugh I relocated the net commands after the motmod .......
IT WORKS!
I cannot tell you how grateful I am -- I've been going round in circles for so long and now cannot stop smiling.
Displaying 6541 - 6555 out of 13541 results.
Time to create page: 0.396 seconds
