  • rodw
  • rodw's Avatar
24 Jan 2026 03:31
Replied by rodw on topic LinuxCNC S-Curve Accelerations
I thought it had already been established that Tormach do not have jerk limiting.
Another possibility would be to run a gcode filter to "normalize" the gcode for performance and jerk limiting. Joco's Monokrom filters out all holes and replaces them with its own optimised code with custom leadins so it can be powerful in the right hands...
  • NWE
  • NWE's Avatar
24 Jan 2026 03:19 - 24 Jan 2026 03:21
Replied by NWE on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
They have listings of sets with the drives on Aliexpress but I messaged them direct on Alibaba to buy the drive. Had it in about 4 days ex China via DHL.
We have to get this going as its soo cheap!
I have to order one of these. Will probably take 30-60 days to get to me. About a month to cross the Pacific plus 5-10 days in customs plus 5-10 days ground freight....
  • rodw
  • rodw's Avatar
24 Jan 2026 03:19
Mesa 7i96S - Error finishing read! iter 8
Category: Driver Boards
I had a Yoga once. I even ran Linux in it. Nice laptop but no wired internet so not suitable for Mesa cards.
Even if it had one, the power savings features and very limited ability to tweak the BIOS would render it unsuitable.
If it had a PCMCIA card ( don't think it does) you might be able to install a PMCIA network adapter
  • PCW
  • PCW's Avatar
24 Jan 2026 03:13 - 24 Jan 2026 03:15
Mesa 7I76EU – Fixing „Unsupported ethernet device – No 7I76EU board found” Error
If mesaflash reported that error, update mesaflash
(instructions on the git site or above in this thread)
github.com/LinuxCNC/mesaflash
If LinuxCNC reported the issue, you need t o update LinuxCNC.
(You don't actually have to update LinuxCNC as it will work fine but will complain about the card every time you start LinuxCNC)
  • PCW
  • PCW's Avatar
24 Jan 2026 03:07 - 24 Jan 2026 03:07
Replied by PCW on topic Mesa Suppliers
Mesa Suppliers
Whats is your name on the email? (just the name not the full email address)
The 7I96S's are at assembly and should be available in 3-4 weeks
  • rodw
  • rodw's Avatar
24 Jan 2026 02:48
Replied by rodw on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
I did check, i can not find anything from Lichuan on Amazon.de, bloody hell, this would have easily been the thing to suck me into EtherCAT, but nooooo...
  • Ingo
  • Ingo's Avatar
24 Jan 2026 02:40
24 Jan 2026 02:18
Replied by tommylight on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
  • rodw
  • rodw's Avatar
24 Jan 2026 02:07
Category: EtherCAT
Sorry its from Lichuan. They also have a closed loop one too
  • rodw
  • rodw's Avatar
24 Jan 2026 02:06
Lichuan 4 axis stepper need help- was created by rodw
Category: EtherCAT
Hi guys. I've spent the morning having a go at getting a 4 axis ethercat drive working.
Just the most basic config I could devise from Dominic's sample.
I got movement from the first drive but its not right. just a whine and a bare stutter.
I wondered if one of the phases was the wrong polarity but no luck with that. The same result which was odd.
There is a windows USB config program which let me set the motor amps to 2 amps and I could see the steps/rev was 10000 which seemed high.
Any ideas would be appreciated. They are a good solution if we can get it going at USD $92 + shipping (for 4 stepper drives - $23 each stepper)
File Name: pdos.txt
File Size:2 KB
File Name: cia402.ini
File Size:4 KB
File Name: ethercat-c...1-23.xml
File Size:4 KB
File Name: config-gen.xml
File Size:5 KB
File Name: cia402.hal
File Size:4 KB
File Name: sdos.txt
File Size:48 KB
File Name: vid.txt
File Size:1 KB
  • NWE
  • NWE's Avatar
24 Jan 2026 01:58
Trying to get a wireless HDMI adapter working
For what it's worth, did you try to connect USB power to both adapters? They appear to have a 'charger port' in the side. I think HDMI can supply some power but it seems quite limited.
  • ncf250sd
  • ncf250sd
24 Jan 2026 01:49
Replied by ncf250sd on topic Probe Basic Stable error
Category: QtPyVCP
a quick follow-up on the E stop. I checked everything on my side that I could think of and the light stays on. I just upgraded from the original PB where the E stop button worked as it should. Maybe I was not clear with my issue. When I activate my e stop on my pendant the screen E stop light goes off. However if i push the screen E stop button the machine stops but the button stays on. You think its still on my side?
24 Jan 2026 01:30
Replied by tommylight on topic Trying to get a wireless HDMI adapter working
To late but would have been better and probably cheaper to get DP-HDMI cable with more length, higher quality one should be 20-30$.
Do not install NVIDIA drivers on a machine PC with RT kernel, it does not work to be happy with it, and sometimes at all.
Now some better news, boot with the add on graphic, wait for it to go blank, wait a bit more, after roughly 2-3 minutes press and hold CTRL+ALT and press several times backspace, this should reset the X server and maybe, just maybe switch to working monitor.
Tip 2: connect another monitor to VGA port, boot Linux, go to prefernces and screen or monitors or displays, there chose and turn on the monitor on WiFi link, apply. If it works, reboot to check if the settings stick.
Tip 3: power on the PC with a working monitor, press or beat the right SHIFT key till you get the GRUB menu, hit E, use arrows to go to line containing "quiet splash" or similar and add after it "nomodeset", press F10 to boot, connect the WiFi monitor and disconnect the working one, wait for it to boot.
If any of those do not work, probably the WiFi dongle does not comply with HDMI standard communication, as i doubt the DP-HDMI adapter is not working, although i have seen DP-HDMI cables failing miserably to work on some PC's while worked fine on some other PC's.
  • Japoo_Ness
  • Japoo_Ness
24 Jan 2026 01:23 - 24 Jan 2026 01:26
Replied by Japoo_Ness on topic Mesa Suppliers
Mesa Suppliers
Hi, sorry for the delay. Yes, that's exactly what it's about.
I was asking if there’s a restock schedule for some of those boards. I emailed PCW (who I was in contact with during the last months of 2025) and I also sent another one to Sales .
(Sorry PCW, I just realized you were the one who replied right above!) (EDITED)
It would be strange if they ended up in spam, but I'm asking here just to be sure. I just want to know when they'll be available so I can plan ahead and be certain I can buy the boards
  • ihavenofish
  • ihavenofish
24 Jan 2026 01:15
Replied by ihavenofish on topic How good is Ethercat motion control?
Category: EtherCAT
Hi Hakan,
If LinuxCNC always receives the position feedback ~2 servo cycles late, can I simply “ignore” this by increasing the following-error limits (FERROR / MIN_FERROR), or does this latency actually affect the LinuxCNC motion planner/trajectory execution?
In other words:
Does LinuxCNC only use the feedback for monitoring/fault detection (so the part accuracy is still fine as long as the drive itself tracks well and has near-zero internal following error)?
Or does LinuxCNC actively “react” to the delayed feedback (e.g. by slowing down, modifying the commanded motion, degrading contour accuracy), meaning I cannot machine precise parts even if the servo drive is perfectly tuned?
So the decisive question for me is:
Can I still mill accurate parts with this inherent 2-cycle EtherCAT feedback lag, as long as the servo drive is properly tuned and its internal following error stays low — or does the lag directly reduce machining accuracy?
Thanks a lot for clarifying this.
In position mode it has no impact, the drive is closing the loop. The feedback is just for "knowledge". So you set f error in linuxcnc to something reasonable (about 2mm on my machine cause its impossible to move that far in 2ms). Set the drives f error to something smaller if you need to.
Displaying 7366 - 7380 out of 13538 results.
Time to create page: 0.414 seconds
