  • PCW
  • PCW's Avatar
20 Jan 2026 16:22
hm2/hm2_5i25.0: invalid config name, got 'HOSTLOT2', expected 'HOSTMOT2'
Category: Driver Boards
Looks like a bad bit on the PCI interface.
If the card has not been mechanically damaged, the most likely
cause would be dirty contact fingers on the 5I25 or dirty slot
contacts on the PCI slot.
As a first attempt to fix, I would clean the 5I25 contact fingers
and PCI slot contacts with 99% IPA or other contact cleaning solution.
  • fraiddy
  • fraiddy
20 Jan 2026 13:39
version 2.9.4 je n'y arrive pas was created by fraiddy
Category: StepConf Wizard
Bonjour a tous je fonctionne depuis un moment avec la version 2.8.2 et tout okje voulais passer en version 2.9.4 mais meme si je programme tout pareil sur stepconf  la machine n'est pas commandée bien quelle le soitlorsque je test les axes sur stepconf il y un report que je vous joint si quelqu'un peut m'aider je suis preneur
File Name: linuxcnc.txt
File Size:6 KB
  • jtc
  • jtc's Avatar
20 Jan 2026 12:51
Hi to all!
After some months without using the machine and waste some time to bring the pc running again, I got this error trying load linuxcnc.
jtc@jtc-linuxcnc ~ $ /home/jtc/linuxcnc-dev/scripts/linuxcnc /home/jtc/linuxcnc-dev/configs/kondia/kondia.iniLINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/jtc/linuxcnc-dev/configs/kondia'
Machine configuration file is 'kondia.ini'
Starting LinuxCNC...
Found file(REL): ./kondia.hal
Note: Using POSIX realtime
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:05:00.0
hm2_5i25.0: board fails HM2 registration
RTAPI_PCI: Unmapped 65536 bytes at 0x7f59c3c27000
Driver probe function failed!
hm2_pci: error registering PCI driver
hm2_pci: rtapi_app_main: Operation not permitted (-1)
./kondia.hal:8: waitpid failed /home/jtc/linuxcnc-dev/bin/rtapi_app hm2_pci
./kondia.hal:8: /home/jtc/linuxcnc-dev/bin/rtapi_app exited without becoming ready
./kondia.hal:8: insmod for hm2_pci failed, returned -1
Running HAL shutdown script
hm2: unloading
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/jtc/linuxcnc_debug.txt
and
    /home/jtc/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Any help will be welcome,
Regards
  • prokopcio
  • prokopcio's Avatar
20 Jan 2026 10:56
Laser Head Height Sensor – Looking for a Beta Tester
Category: Plasma & Laser
Unfortunately,  Rod couldn't continue testing this sensor with the Linux CNC.
So, I have a question:
Would anyone be willing to test the device?
I'm looking for someone with knowledge who will find the time to do so soon and share their honest observations here, especially the shortcomings.
New User Manual:
proma-elektronika.com/download/c2v_laser_sense_en.pdf
  • my1987toyota
  • my1987toyota's Avatar
20 Jan 2026 10:13 - 20 Jan 2026 12:48
Replied by my1987toyota on topic ARE YOU KIDDING ME YOUTUBE !!!
  Due to the insanity that has been going on in the US I have been staying quiet. Yes it's very embarrassing
what has been going on. And then to have these heavy handed, very corrupt bills being introduced, is
shameful to say the least. They have done it with Drones( Rc Airplanes, Helicopters, and Multirotors ) now
they want to do the same with micro scale manufacturing, and E-bike stuff. All in the name of safety and
security.
  The worst part is even if someone were to leave the US the rest of the world will see any American individual
in the same light.
Guilt by association.
Now back to going quiet
  • freemoore
  • freemoore
20 Jan 2026 09:56
7i80HD+7i48+7i42TA+7i84 Mesa firmware request (morbidelli author 503 retrofit)
Thanks PCW, this got us our first axis movements on the Morbidelli since starting the project. Yes, I did want 2x modbus ports and 2x smartserial on this if possible. Could you confirm that this should work (with the RS422/485 adapters) through 7i42TA pins also?
  • Studi
  • Studi's Avatar
20 Jan 2026 09:25
Mesa 7i96S step ausgangsignal =5V , Schrittmotortriber eingang 12V was nun?
Category: Deutsch
Hab Nachricht vom Kumpel bekommen,
Sein Plan: "Es gibt sogenannte MOSFET-Treiber, die werden gebraucht um MOSFET-Transistoren zu steuern. Diese Transistoren benötigen eine Schaltspannung > 10V"
Was hältst Du davon?
  • mariob
  • mariob
20 Jan 2026 09:11
Linuxcnc erste Schritte und erste Probleme, NVEM und Remora
Category: Deutsch
Hallo,
und danke für die Antwort Luca, mein Problem ist das der NVEM zusätzlich zu seiner Firmware, da gibt es zwei Versionen, auch noch eine Konfigurationsdatei braucht die zu .hal und .ini passt. Und da weiß ich nicht was da zusammengehört, das ist irgendwie unzureichend dokumentiert. Mein Erkenntnisprozess ist hier zu finden:
forum.zerspanungsbude.net/viewtopic.php?p=1095645#p1095645
Ich quäle mich gerade durch den Thread vom Scott mit über 200 Beiträgen um da genaueres herauszubekommen.
Gruß
Mario
  • meister
  • meister
20 Jan 2026 05:55
Category: Deutsch
hmm, ok, also, die meinte ich, aber ich bin mir sicher das da früher mal uln's drauf waren.
Ok dann vergesst was ich gesagt habe.
  • timo
  • timo
20 Jan 2026 03:52 - 20 Jan 2026 03:53
Replied by timo on topic G Codes not working
G Codes not working
Category: G&M Codes
Isn't it the point of CNC that every program can be different?
Joking aside:
I guess if you post the two codes, you might have more replies quicker.
  • spumco
  • spumco
20 Jan 2026 00:43
Replied by spumco on topic ARE YOU KIDDING ME YOUTUBE !!!
Can i renounce my US citizenship? Granted i never went there, but still i feel ashamed about what is going on there as i have two brothers living there.
Understandable, but keep in mind this is a Washington state bill, not federal.
Depending on how it plays out I'd be surprised if federal reps from similarly-leaning states don't introduce similar legislation at the federal level.
  • Davidson55
  • Davidson55
19 Jan 2026 22:24
G Codes not working was created by Davidson55
G Codes not working
Category: G&M Codes
Good day. I am new to Linux CNC. I have been working with the owner of Sherline. Great guy but he's too busy to help me on every issue I have. So, I am coming to the Linux CNC community for help.
I am using BobCAD-CAM for my CAD/CAM. After I complete my drawing and create my G-Code, I then transfer it to my Sherline program. I have a Sherline 4400 lathe. I am using version LinuxCNC/Axis 2.9.0. I was given a sample program from Sherline. I ran the program with no issues.
I am looking at the g-codes I created and the sample code, they're totally different.
If someone has the time to give help would be much appreciated. If I need to post the g-codes, let me know. Thanks in advance.
  • juliankoenig87
  • juliankoenig87
19 Jan 2026 22:03 - 19 Jan 2026 22:10
Category: Deutsch
Er meint denke ich diese hier(Anhang).
Jedenfalls bei meinem sind 74hc245d drauf. Die können keine 12V. Aber who knows. Vielleicht gibt es breakout boards (bob) die das können. Würde mich interessieren.
Hab dein pdf überflogen. Nochmal anders als in deinem vorherigen Bild. Genau wie bei meinen Endstufen. 12V hochohmiger Pullup an Schmitt Trigger.
Kannst du dann plug n play mit dem Darlington Array auf Masse ziehen.
Kann dir morgen mal den Schaltplan schicken. Hab die Platinen unbestückt hier liegen oder eine noch teilbestückt (ohne Relais). Bauteilkosten und was für die Kaffeekasse reicht mir, falls wir nicht noch andere Lösungen hier genannt bekommen.
Displaying 7591 - 7605 out of 13514 results.
Time to create page: 0.383 seconds
